bruor 43 Posted July 19, 2024 Posted July 19, 2024 (edited) I have 2 servers that are both set up with m3u tuners that are both provided the same m3u playlist so that the tvg-id and channel numbers are identical. I'd like to know if there is a way that I can export the guide data provider and channel mapping configuration from one and apply it to the other? If so what is the best way to approach this? Should I be able to copy the livetv.xml file between servers? Or would it be better to set up the tuner and guide providers manually, read all the mappings from server 1 using the API and then try to apply them to server 2 using the API? Edited July 19, 2024 by bruor
Luke 42241 Posted July 19, 2024 Posted July 19, 2024 Hi this is part of the main Emby server backup process: Configuration Backup
bruor 43 Posted July 19, 2024 Author Posted July 19, 2024 This will copy the entire server config I think, I just want to copy the IPTV configuration.
Luke 42241 Posted July 20, 2024 Posted July 20, 2024 8 hours ago, bruor said: This will copy the entire server config I think, I just want to copy the IPTV configuration. HI, currently there is no way to do that. I was just trying to explain what can be done though.
