cobalt1000 1 Posted July 17, 2024 Posted July 17, 2024 (edited) Hello, dear Emby support. I have a problem choosing a video from the list of seasons of a series. in the "next" tab after choosing an episode. When you press a chapter, after playing it and wanting to remove the episode being played, there is a kind of abrupt screen update, and it removes the selection of the episode being played. Which makes it uncomfortable to handle the interface for selecting the episodes. The following video attached here describes the problem. I hope there can be a solution and make the selection of episodes in the "next" tab more convenient. 20240716_122016.mp4 Edited July 17, 2024 by cobalt1000 Case update
ebr 16337 Posted July 17, 2024 Posted July 17, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
cobalt1000 1 Posted July 17, 2024 Author Posted July 17, 2024 Ok, the Emby application shown in the video is Emby for AndroidTV, downloaded from the Play Store. As for that, comparing the application on AndroidTV and FireTV Stick, I will try to upload a video with Amazon Fire TV Stick to see how the Emby application behaves.
cobalt1000 1 Posted July 17, 2024 Author Posted July 17, 2024 1 hour ago, ebr said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. Ok, the Emby application shown in the video is Emby for AndroidTV, downloaded from the Play Store. As for that, comparing the application on AndroidTV and FireTV Stick, I will try to upload a video with Amazon Fire TV Stick to see how the Emby application behaves. 1
