akumaginkou 1 Posted July 16, 2024 Posted July 16, 2024 I am running emby with Container on my QNAP and cannot access the video folder in the shared folder. I am using the following code to launch it in the application What do I need to do and how do I do it? Quote version: "3.7" services: emby: image: emby/embyserver:4.9.0.12 container_name: emby environment: - PUID=1000 - PGID=1000 - TZ=Etc/UTC volumes: - /share/CACHEDEV1_DATA/Container/Emby:/config - /share/VIDEOS:/data/video - /share/CACHEDEV1_DATA/NAS/movies/:/data/movies ports: - 8096:8096 - 8940:8940 #optional devices: - /dev/dri:/dev/dri #optional restart: unless-stopped embyserver(2).txt
Luke 42239 Posted July 17, 2024 Posted July 17, 2024 HI, what about /data/movies. Is there a problem with that one?
akumaginkou 1 Posted July 17, 2024 Author Posted July 17, 2024 I can't select that folder as my TV SHOW library
Luke 42239 Posted July 17, 2024 Posted July 17, 2024 34 minutes ago, akumaginkou said: I can't select that folder as my TV SHOW library I understand, but did you set it up as a movies library?
akumaginkou 1 Posted July 17, 2024 Author Posted July 17, 2024 No Tv show select When I try to select a folder, I can't select it
Luke 42239 Posted July 20, 2024 Posted July 20, 2024 Quote - /share/CACHEDEV1_DATA/NAS/movies/:/data/movies Maybe you should remove the trailing / after movies? Not sure if that matters.
akumaginkou 1 Posted July 21, 2024 Author Posted July 21, 2024 Sorry, the movie folder is fine. The problem is in the video folder
akumaginkou 1 Posted July 21, 2024 Author Posted July 21, 2024 Sorry, I was able to resolve it myself.
akumaginkou 1 Posted July 21, 2024 Author Posted July 21, 2024 Once I changed the Docker container I was using from the official one to one made by linuxServer.io, it worked fine. I don't know why. 1
