charlesgao 0 Posted July 15, 2024 Posted July 15, 2024 May I ask why, after scanning the media library and entering the folder mode to display the cover poster image, there is still a small icon for the folder in the upper left corner. Clicking on it does not play this movie, but instead enters another folder. Did I set it up incorrectly? This question has been bothering me for a long time, please ask the staff to help answer it, thank you! Only by clicking on the folder again can this movie be played. The movie is nested in a non-existent folder. How should I set it to cancel it?
Happy2Play 9811 Posted July 15, 2024 Posted July 15, 2024 Yes this is a true representation of Folder structure as it is not Flattened like the Movies tab. With hidden library switches that can only be changed via the api now. <CollapseSingleItemFolders>false</CollapseSingleItemFolders>
chqraid 0 Posted January 11, 2025 Posted January 11, 2025 I'm facing the same problem. Should I modify the /config/system.xml file? I made changes but they didn't take effect. I propose adding a feature in the backend that allows users to select whether to collapse folders or not.
chqraid 0 Posted January 11, 2025 Posted January 11, 2025 可以了,修改/config/system.xml中的<CollapseVideoFolders>true</CollapseVideoFolders>即可。
Luke 42240 Posted January 17, 2025 Posted January 17, 2025 On 1/11/2025 at 4:59 AM, chqraid said: 可以了,修改/config/system.xml中的<CollapseVideoFolders>true</CollapseVideoFolders>即可。 Hi, we don't recommend this, but if you're happy, then we're happy
