k84lk 0 Posted July 13, 2024 Posted July 13, 2024 I have issues with Emby, but I need alternative suggestions I have an issue with Content mixed and I have an issue with TV Shows. The first is with Content Mixed when I put a folder or a video or whatever, but when the metadata doesn't appear and I can't choose a language other than English and can't even change the video to those original episodes with the metadata. The second is the same system as the first but slightly different When entering the metadata, it is not possible to change what you choose except for TV shows or videos, I hope there is a solution for it because some sites cannot get the metadata except in a foreign language or other languages. I tried with a video that does not show the metadata with TV shows, I do not find a solution to these issues and terrible differences Although the video metadata appears original when I do it manually and it's very tiring, it should be the same with TV shows. In case you don't understand what I mean, I will send a full video of this issue.
Abobader 3484 Posted July 13, 2024 Posted July 13, 2024 Hello k84lk, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 Need specific examples but Mixed Content will still require organization per their content type. You cannot just dump a bunch of episodes and movies in a folder.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 (edited) 25 minutes ago, Happy2Play said: Need specific examples but Mixed Content will still require organization per their content type. You cannot just dump a bunch of episodes and movies in a folder. that true but Why videos are not similar to TV shows The metadata is supposed to be accurate but I don't have to put each video description data because it is tiring and the folder and video are similar to TV shows so that you do not need to change the metadata will remain either video or TV shows you have freedom and also change the data description language all this is supposed to be similar to TV shows but there is no such feature so that I can change anything freely without restriction because there are some films that have episodes and some films have only one episode It's supposed to be mixed content. They are supposed to be called films Home videos & photos is dedicated to home videos and you don't need metadata. Edited July 13, 2024 by k84lk
Luke 42184 Posted July 13, 2024 Posted July 13, 2024 Right even in mixed content you still have to follow naming and organization guidelines: Movie Naming TV Naming It doesn't mean that you can just do a free-for-all and still have everything detected correctly. An example usage of a mixed content library would be having two subfolders where one is movies and the other is TV.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 2 minutes ago, Luke said: Right even in mixed content you still have to follow naming and organization guidelines: Movie Naming TV Naming It doesn't mean that you can just do a free-for-all and still have everything detected correctly. An example usage of a mixed content library would be having two subfolders where one is movies and the other is TV. Yes, I'm with you, but metadata you don't have the freedom to change the language of the country at all, and you don't even have the freedom to choose films or TV programmes when it comes to metadata
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 3 minutes ago, k84lk said: Yes, I'm with you, but metadata you don't have the freedom to change the language of the country at all, and you don't even have the freedom to choose films or TV programmes when it comes to metadata Sorry but yes you do and requires specific organization. Need a real example of the issue as TV or Movie can be set to any language a metadata provider has.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 Also, regarding the metadata for each country, it is supposed to add a link for each country regarding the metadata without having to choose what is available so that he can choose the metadata according to his country and the site link for that metadata with its own episodes, image, etc. similar to TV shows
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 No Emby only support metadata in one language it will not download every language possible.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 3 minutes ago, Happy2Play said: Sorry but yes you do and requires specific organization. Need a real example of the issue as TV or Movie can be set to any language a metadata provider has. Here's the issue, why not put a link to metadata by country or customised code number? For example, I'll give you a code from MovieDb Id: 48624 and this link https://www.themoviedb.org/movie/48624 Official English language But if you put in another language that has an accurate description in Japanese The code will not change, the same code will remain in the same official English language. It has three episodes that are supposed to be on TV. Here's the link https://www.themoviedb.org/movie/48624?language=ja-JP in Japanese with the same exact metadata Of course, this is for films, but I have to put each video with the same code, it's supposed to be on TV shows. And the same with TV shows. https://www.themoviedb.org/tv/87056-urotsukidoji-iii-return-of-the-overfiend?language=ja-JP But the code is different 87056 There is no description except (English) metadata that is not even accurate between the two and a Japanese link, so what's the point if I can't find a solution? There has to be a solution I'm sure it's not just the film, there are probably thousands of them. There should be freedom of choice
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 Then you would have to cache the entire TMDB database of metadata on your server. Personally I cannot see doing that on anyone's personal media server. A business maybe. But currently this is not an option per that existing feature request.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 5 minutes ago, Happy2Play said: Then you would have to cache the entire TMDB database of metadata on your server. Personally I cannot see doing that on anyone's personal media server. A business maybe. But currently this is not an option per that existing feature request. It's okay I'll use it for personal use on my own server as a personal, not a business, it doesn't matter, I'll pay if it's in that feature
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 (edited) Unsolved Error Edited July 13, 2024 by k84lk
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 29 minutes ago, Happy2Play said: Then you would have to cache the entire TMDB database of metadata on your server. Personally I cannot see doing that on anyone's personal media server. A business maybe. But currently this is not an option per that existing feature request. Is there a radical solution
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 Don't believe there is in Emby or any of the competing products as all are limited to one language that I know of.
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 6 minutes ago, Happy2Play said: Don't believe there is in Emby or any of the competing products as all are limited to one language that I know of. Unfortunately, there should be a variety of languages, I know that the programme is in English, but there should be metadata here through the link so that it is easy for everyone to choose what he wants from his language because when I choose the language and then the country will not help because the language of the official website becomes an official language, there must be a sub-language that puts a link to the original site and saves it automatically even if it is deleted from that site or changed.
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 (edited) Metadata and Site are two different things things as the UI has its own language. Metadata is not that lucky and not saved in every written language and limited one language currently. No media managers currently does multiple language metadata that I know of. Edited July 13, 2024 by Happy2Play
k84lk 0 Posted July 13, 2024 Author Posted July 13, 2024 39 minutes ago, Happy2Play said: Metadata and Site are two different things things as the UI has its own language. Metadata is not that lucky and not saved in every written language and limited one language currently. No media managers currently does multiple language metadata that I know of. Will paid solves the issue?
Happy2Play 9798 Posted July 13, 2024 Posted July 13, 2024 1 minute ago, k84lk said: Will paid solves the issue? No as that is not how Emby works to get Feature Requests implemented as there would have to be server core changes. And probably changes in every client.
pwhodges 2023 Posted July 13, 2024 Posted July 13, 2024 16 minutes ago, k84lk said: Will paid solves the issue? If you pay someone enough to write a replacement for Emby or Plex to your specification. Or seeing as Jellyfin is open source; pay someone to fork it and write the major changes required to make it possible. In either case, wait a long time... Paul 2
