Faust666 1 Posted July 13, 2024 Posted July 13, 2024 Hi, i want to watch an old Police Academy on my EMBY server on my FIRE STICK, i don't have any sound. Movie is in MONO. I try a few language track, all of them is MONO, no sound. The movie just play without sound. I try on my EMBY server on my PC every thing is fine, i have also test it on an old ROKU, and also it's working good. So i think there is an issue on mono sound on FIRE STICK. Anybody have an idea to solve this problem? Thank
Luke 42244 Posted July 13, 2024 Posted July 13, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Ninko 78 Posted July 22, 2024 Posted July 22, 2024 Hi, Strangely I have a user who's trying to watch a police academy film on a fire stick which has mono audio and they can't get sound to work either! Is this an Emby problem or a fire stick problem? Thanks
Luke 42244 Posted July 22, 2024 Posted July 22, 2024 6 minutes ago, Ninko said: Hi, Strangely I have a user who's trying to watch a police academy film on a fire stick which has mono audio and they can't get sound to work either! Is this an Emby problem or a fire stick problem? Thanks @Ninko Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Ninko 78 Posted July 22, 2024 Posted July 22, 2024 Not sure what more information you need, the users app version is reported as AndroidTv 2.1.14a embyserver.txt Thanks
ebr 16337 Posted July 22, 2024 Posted July 22, 2024 1 minute ago, Ninko said: Not sure what more information you need Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
Ninko 78 Posted July 22, 2024 Posted July 22, 2024 (edited) 7 minutes ago, ebr said: Can you please play that item for a few seconds and then follow the instructions to send a log from the app? The log I just gave should show that, look for Police Academy 2. Edit: sorry I misunderstood what you meant, I'll try and get the user to do that. Thanks Edited July 22, 2024 by Ninko
Luke 42244 Posted July 22, 2024 Posted July 22, 2024 Also, Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Ninko 78 Posted July 23, 2024 Posted July 23, 2024 10 hours ago, Luke said: Also, Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. I'm trying to keep this as simple as I can for this user, are they not using the correct app for their platform?
ebr 16337 Posted July 23, 2024 Posted July 23, 2024 That item also had an AC3 track which it started playing in. Was sound okay on that one? Is it a different audio stream than the other one?
Ninko 78 Posted July 23, 2024 Posted July 23, 2024 Both the AAC and AC3 track are mono, as far as I know, no audio was played with either track.
ebr 16337 Posted July 23, 2024 Posted July 23, 2024 The next best step will be to try the app Luke suggested then.
Ninko 78 Posted July 23, 2024 Posted July 23, 2024 Which is the official app used on fire sticks? I don't understand why there's more then one, it over complicates things for some users!
ebr 16337 Posted July 23, 2024 Posted July 23, 2024 Hi. We are in a transition phase right now. There is a lot of discussion on this in these forums.
Ninko 78 Posted July 23, 2024 Posted July 23, 2024 So which one are you transferring to? Also, if it works in one app, apply the fix in the other? Plus, surely it's easy for you to recreate the problem at your end if the problem seems to be related to a fire stick and playing something with mono audio, no?
Luke 42244 Posted July 24, 2024 Posted July 24, 2024 6 hours ago, Ninko said: Which is the official app used on fire sticks? I don't understand why there's more then one, it over complicates things for some users! HI, it is Emby for Android. Can you try that one and let us know how things compare? Thanks !
Ninko 78 Posted July 24, 2024 Posted July 24, 2024 5 hours ago, Luke said: HI, it is Emby for Android. Can you try that one and let us know how things compare? Thanks ! Is that not what they are using - AndroidTv 2.1.14a ?
ebr 16337 Posted July 24, 2024 Posted July 24, 2024 2 hours ago, Ninko said: Is that not what they are using - AndroidTv 2.1.14a ? No it is not. There is another app called "Emby for Android".
Ninko 78 Posted July 24, 2024 Posted July 24, 2024 46 minutes ago, ebr said: No it is not. There is another app called "Emby for Android". Ok, I'll get them to try that app. Question though, why not remove the other app from the store if your moving over? It just causes unnecessary confusion.
ebr 16337 Posted July 24, 2024 Posted July 24, 2024 4 minutes ago, Ninko said: Question though, why not remove the other app from the store if your moving over? It just causes unnecessary confusion. 14 hours ago, ebr said: We are in a transition phase right now.
Ninko 78 Posted July 24, 2024 Posted July 24, 2024 That doesn't stop new people installing the old one though does it.
Neminem 1623 Posted July 24, 2024 Posted July 24, 2024 @NinkoNo and that's sad. I like the AndroidTV app much better. Just look at the list that still need to be fixed, not seeing that in the near future. Like Luke said "It posible in the future" Fix what's what wrong with the AndroidTV, and keep it on par. Till you can satisfy people. I do have a copy of the AndroidTV apk, if I need to reinstall, and keep a copy when updated. 1
rbjtech 5344 Posted July 25, 2024 Posted July 25, 2024 AndroidTV App v2.1.12a Just tested this out of curiosity - Audio track is indeed DTS-HD Mono (haha) - played back perfectly (video direct play, software decode on Audio) on a Gen 2 FireTV.
Ninko 78 Posted July 25, 2024 Posted July 25, 2024 Thanks @rbjtechfor confirming it works in that app, I'll try to get the user in question to switch apps.
