sa2000 703 Posted February 24, 2025 Posted February 24, 2025 2 hours ago, pdeliot said: Sent in private... Tests so far on Emby Server 4.9.0.38 Cassandre S3 E2 in a library as file "Cassandre - S3E2 - Mort blanche.mp4" xmltv series recording with option to check all libraries It did not record the airing for this episode in the xmltv schedule: Mort blanche Saison:3 Episode:2 with xmltv_ns value of 2.1 So not sure yet what your issue is and if it is specific to certain episodes Will do some more tests
pdeliot 10 Posted February 24, 2025 Author Posted February 24, 2025 Thank you for your investigations. If you need more elements, please ask.
sa2000 703 Posted February 24, 2025 Posted February 24, 2025 5 minutes ago, sa2000 said: Cassandre S3 E2 in a library as file "Cassandre - S3E2 - Mort blanche.mp4" xmltv series recording with option to check all libraries It did not record the airing for this episode in the xmltv schedule: Mort blanche Saison:3 Episode:2 with xmltv_ns value of 2.1 So not sure yet what your issue is and if it is specific to certain episodes I am repeating the test - i might have shut down the server at wrong time.
sa2000 703 Posted February 25, 2025 Posted February 25, 2025 (edited) 17 hours ago, sa2000 said: I am repeating the test - i might have shut down the server at wrong time. @pdeliot I have managed to get Cassandre S7 E2 to record when it was in a library. The schedule was already in place. Then S7 E2 was added to a library. There was no guide refresh run between the time the episode was added to the library and the time of the airing. So this could be the reason why it goes wrong sometimes. If there is no trigger to check the timers. I have referred the diagnostics I captured to the development team Are you able to confirm for the ones where it has gone wrong, that there was no guide refresh between the time the episode was placed in the library and the airing of the episode in the xmltv schedule ? There may be several causes - the one I reproduced is this one Edited February 25, 2025 by sa2000
sa2000 703 Posted February 25, 2025 Posted February 25, 2025 @pdeliotFor my tests to reproduce the issue, I can confirm that doing a guide refresh after adding an episode to a library, stops the next airing of that episode from recording So if this is the cause of your issue, suggest trying to schedule guide refreshes to be hourly - see Server Settings / Scheduled Tasks
pdeliot 10 Posted February 25, 2025 Author Posted February 25, 2025 Currently, this is my recordings planning: Guide refresh do not change anything ...
sa2000 703 Posted February 25, 2025 Posted February 25, 2025 (edited) 1 hour ago, pdeliot said: Guide refresh do not change anything Need the full works ! Server debug logs after a guide refresh complete - you could send me privately zip of copy of the logs folder zip of the 2 timers json files (in data/livetv) seriestimers.json and timers.json paths / filenames for these files in the library and if you can - copy out the library db files and zip and make available to me privately - and copy of system.xml from the config folder Edited February 25, 2025 by sa2000
