zzsx644 3 Posted February 19, 2025 Author Posted February 19, 2025 On 11/17/2024 at 11:24 AM, Luke said: Since you have both cuvid and nvdec decoder options, did you try changing the priorities to test them both? Sorry, I haven't had time to look into this issue for a long time. Now I've upgraded to the latest GPU driver and also updated to version 4.9.0.38, but the problem still persists. embyserver.txt ffmpeg-remux-0fb40f54-1c22-425f-aab8-4c96c45e0440_1.txt ffmpeg-remux-9a8050f9-7d40-479f-83a9-d65720ee107b_1.txt ffmpeg-transcode-83cc33f6-08fb-4229-9155-6e4a7343c545_1.txt ffmpeg-transcode-6866e15c-00cb-4485-9368-18e75431414f_1.txt ffmpeg-transcode-881135b3-9a6e-4965-b8c0-40a6b569fe07_1.txt ffmpeg-transcode-bc4703a7-427d-47d8-a141-dcc94da38da1_1.txt ffmpeg-transcode-bf8a87ef-445a-4207-85ae-6de2d4ebe70a_1.txt ffmpeg-transcode-e53b6724-5fc0-4293-b2a1-42ac0e436150_1.txt hardware_detection-63875567453.txt
zzsx644 3 Posted February 21, 2025 Author Posted February 21, 2025 3 hours ago, Carlo said: Hi, Did you try what Luke suggested? 有的,另一个帖子里建议我升级显卡驱动,我已经升级,但是依然无效 Yes, another post suggested that I upgrade my GPU driver. I have already updated it, but the issue still persists.
Carlo 4561 Posted February 21, 2025 Posted February 21, 2025 On 11/16/2024 at 10:24 PM, Luke said: Since you have both cuvid and nvdec decoder options, did you try changing the priorities to test them both? I was referring to this by Luke.
zzsx644 3 Posted March 10, 2025 Author Posted March 10, 2025 我使用了更换硬件的方法解决了问题,购买了一个新nas,使用N100的核显进行转码,一切就正常了。 虽然没能解决问题,但是感谢大家的帮助和解答 I solved the issue by replacing the hardware. I purchased a new NAS and used the N100 integrated graphics for transcoding, and everything is now working fine. Although the original issue wasn't resolved, I sincerely appreciate everyone's help and support. 1
