MindBullet 93 Posted July 8, 2024 Posted July 8, 2024 Hey there guys, I'm experiencing this issue for quite some time already. I've setup custom Trailers (Not the Codecs ones) and they all play fine and are picked randomly, except for the trailers don't get played until the very end. Sometimes the trailer stops 1 sec before the actual movie, sometimes they suddenly stop at the half of the trailer and they just won't finish. Expected behavior would be, that the trailers play and finish, so that the actual movie automatically starts. Current behavior is that trailers play, but do not finish, so one has to press the skip button to reach the actual movie. Did anybody else witness this behavior as well? I'm coming back to Emby after a longer break, but I know that I've had this issue half a year ago already. Any hints would be greatly appreciated. Here are some logs. The time frame when I've played some trailers (and they stopped) are 22:22 - 22:24 o'clock. embyserver.txt
Luke 42288 Posted July 8, 2024 Posted July 8, 2024 Hi, if you setup this mp4 as your custom trailer, does it happen with that ? https://github.com/mediaelement/mediaelement-files
MindBullet 93 Posted July 8, 2024 Author Posted July 8, 2024 Hey Luke, wow, good catch! No, it does not happen with the big buck bunny.mp4. What's the conclusion behind this? Is there a way I can fix it?
Solution Luke 42288 Posted July 8, 2024 Solution Posted July 8, 2024 My initial guess was poorly encoded files causing the video player to never signal completion thus resulting in the Emby app not advancing to the next video.
MindBullet 93 Posted July 8, 2024 Author Posted July 8, 2024 Okay I see. That could be pretty likely. I'll try some other files then, thank you! 1
