Luke 42241 Posted November 12, 2014 Posted November 12, 2014 if by bluray you mean folder rips or iso's, then those are considered an experimental feature with regards to transcoding to roku, the browser, and mobile devices. plain video files are fine though.
MSattler 390 Posted November 12, 2014 Posted November 12, 2014 All, Have any of you tried to use Roku remotely via the internet using Media Browser Connect, and played back Blu Ray content? Via a web browser, BluRay is working fine for me from work as it is transcoded. I'm curious if this is working on Roku as well. Thanks!
MSattler 390 Posted November 14, 2014 Posted November 14, 2014 if by bluray you mean folder rips or iso's, then those are considered an experimental feature with regards to transcoding to roku, the browser, and mobile devices. plain video files are fine though. So from within the same home it is working, I will need to try it remotely. I'm assuming I can set an auto transcode setting, to transcode based upon connectivity? The playback in the same home, for bluray works well. Thanks, Marcus
