n1xkm 4 Posted July 2, 2024 Posted July 2, 2024 Hey, I just created a new music library and uploaded an album with the corresponding LRC files but they do not show in every player that I tried that has lyric support. Emby Server finds them just the players cannot display them for some reason. Is there anyway to fix this? Besides that it works great. Thanks. 02 - Bitch, Don’t Kill My Vibe.lrc
Luke 42184 Posted July 2, 2024 Posted July 2, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Solution n1xkm 4 Posted July 2, 2024 Author Solution Posted July 2, 2024 2 minutes ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! My bad, I looked at the logs and Emby was not able to open them, I gave Emby permissions and it worked good. Thanks. 1
sterremos 13 Posted August 19, 2024 Posted August 19, 2024 Hi, can you please tell how this works with LrcLib ?
Luke 42184 Posted August 19, 2024 Posted August 19, 2024 35 minutes ago, sterremos said: Hi, can you please tell how this works with LrcLib ? Lrc files are supported for song lyrics.
Happy2Play 9798 Posted August 20, 2024 Posted August 20, 2024 49 minutes ago, sterremos said: I see, but can this working with Emby? What do you mean? LRC files with media are used in Emby or they can be embedded in track. Music Lyrics | Emby Documentation @sa2000can you move the Intro skip from the bottom on Lyrics to correct location? 1 1
sterremos 13 Posted August 20, 2024 Posted August 20, 2024 1 hour ago, Happy2Play said: What do you mean? LRC files with media are used in Emby or they can be embedded in track. Music Lyrics | Emby Documentation Hi, I see it now, I was hoping that there was a connection with Emby, but you have to download the lyrics. @sa2000can you move the Intro skip from the bottom on Lyrics to correct location?
Happy2Play 9798 Posted August 20, 2024 Posted August 20, 2024 Just now, sterremos said: Hi, I see it now, I was hoping that there was a connection with Emby, but you have to download the lyrics. Yes you have to manually download do to copyright concerns. But there are automate programs out there.
sterremos 13 Posted August 20, 2024 Posted August 20, 2024 40 minutes ago, Happy2Play said: Yes you have to manually download do to copyright concerns. But there are automate programs out there. Yes, but I don't think it's possible to connect your music map to a lyric server in Emby so that you get the song lyrics right away, right? Ron
Happy2Play 9798 Posted August 20, 2024 Posted August 20, 2024 10 minutes ago, sterremos said: Yes, but I don't think it's possible to connect your music map to a lyric server in Emby so that you get the song lyrics right away, right? Ron You have to process all your music with whatever program you like to get lyrics files and Emby will see and use them if present.
sa2000 690 Posted August 21, 2024 Posted August 21, 2024 On 20/08/2024 at 16:00, Happy2Play said: can you move the Intro skip from the bottom on Lyrics to correct location? This has been done. Thank you 1
sterremos 13 Posted August 23, 2024 Posted August 23, 2024 Hi, i tried for several days LCRGET, I noticed that there are not all lyrics finding, but what really nice is, is that the lyrics are scrolling down with the music, that was not with other lyrics finders, FOO / mediahuman. are there other lyrics finders like LCRGET 1
