freebs 2 Posted May 27, 2015 Posted May 27, 2015 Another odd thing.. not sure if this is related... I installed the Vera home Automation plugin and each time I restart the server it asks to restart for the pending plugin Vera. I may just pull it all off and start from scratch. You would happen to have the old instructions for mediabrower for linux on hand just in-case I'm stuck here P.S I tried removing my folders and tried to rescan without success.
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 Okay, once you setup the symlink did you restart the service?
freebs 2 Posted May 27, 2015 Posted May 27, 2015 I did yes... restart the service service emby restart
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 (edited) Another odd thing.. not sure if this is related... I installed the Vera home Automation plugin and each time I restart the server it asks to restart for the pending plugin Vera. I may just pull it all off and start from scratch. You would happen to have the old instructions for mediabrower for linux on hand just in-case I'm stuck here P.S I tried removing my folders and tried to rescan without success. The new instructions will work, just do apt-get remove --purge, and make sure that /var/lib/emby gets removed. Reinstall with new instructions. Also ensure /etc/default/emby get's removed as well. I'm surprise your library didn't get repopulated when you did another library scan. Edited May 27, 2015 by hurricanehernandez
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 (edited) No trouble, I'm surprise that it didn't workout as smoothly as I had hoped, the symlink should have worked. Edited May 27, 2015 by hurricanehernandez
freebs 2 Posted May 27, 2015 Posted May 27, 2015 it's all good - I'm in the testing phase now anyways.. I'll let you know how it all works out.
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 I know the issue, in the db the physicallocationlist don't get update on the restart of the service. I will see about getting this on Luke's radar.
thefirstofthe300 292 Posted May 27, 2015 Posted May 27, 2015 @, We have had some users report that Emby doesn't follow symlinks for some reason so that might be what is causing the problem.
thefirstofthe300 292 Posted May 27, 2015 Posted May 27, 2015 Also, just a heads up for those upgrading your kernels to 4.0.x or newer: http://emby.media/community/index.php?/topic/21776-caution-ubuntu-and-debian-users/ 1
freebs 2 Posted May 27, 2015 Posted May 27, 2015 Thanks for the heads up! Ok I purge and re-installed and all was fine. Scanning library right now. Perhaps you should put a note on the Ubutnu install page not to upgrade from mediabrowser for the time being. I should have thought about the db and the paths myself. I've run into that with kodi and mysql. Thanks again !!
tymanthius 18 Posted May 27, 2015 Posted May 27, 2015 I can confirm that if you apt-get purge emby, del the /var/lib/emby & ../mediabrowser folders manually, then reinstall it works. Annoying. But as it's a test for me, recreating log-ins isn't a big deal.
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 @, We have had some users report that Emby doesn't follow symlinks for some reason so that might be what is causing the problem. Well that sucks and thanks for the heads up. 1
freebs 2 Posted May 27, 2015 Posted May 27, 2015 ok another issue I've found after updating to this version. I cannot add a username and password to tvheadend any longer I get the following error: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
hurricanehrndz 149 Posted May 27, 2015 Posted May 27, 2015 That's an actual emby issue, you might want try making another post, in a thread more general.
tymanthius 18 Posted May 28, 2015 Posted May 28, 2015 I have another question: Why does scanning the media library slam my processor? I can understand why it would at first install - generating all the indexes for roku, and chapter files, etc. But after that, it should only have to do a very little as not much will change (max of 15 new files a day I'd guess, usually half that).
hurricanehrndz 149 Posted May 28, 2015 Posted May 28, 2015 I have another question: Why does scanning the media library slam my processor? I can understand why it would at first install - generating all the indexes for roku, and chapter files, etc. But after that, it should only have to do a very little as not much will change (max of 15 new files a day I'd guess, usually half that). You might have chapter extraction enabled.
tymanthius 18 Posted May 28, 2015 Posted May 28, 2015 (edited) You might have chapter extraction enabled. I probably do - it sounded neat. I'll kill it and watch what happens. EDIT: I tried to uncheck it, but every time I do, it crashes emby. :/ Won't save the change. Edited May 28, 2015 by tymanthius
hiro24 0 Posted May 29, 2015 Posted May 29, 2015 Hi everybody, I'm brand new to emby, and I love it so far. But there seems to be a quirk that I can't figure out. Whenever I go to change my profile picture, I'll get various error popups. These can range from The requested value "Images" was not found There was an error processing the request. Please try again later Server is running on Ubuntu 14.04.1, I'm not sure what's going on or where to check for errors. Could somebody point me in the right direction? EDIT: I managed to pull the following from the logs if this helps 2015-05-29 08:46:19.3094 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5621.3 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.24 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. System.ArgumentException at System.Enum.Parse (System.Type,string,bool) <0x00144> at MediaBrowser.Api.Images.ImageService.Post (MediaBrowser.Api.Images.PostUserImage) <0x00062> at (wrapper dynamic-method) object.lambda_method (System.Runtime.CompilerServices.Closure,object,object) <0x00074> at ServiceStack.Host.ServiceExec`1/<>c__DisplayClass6<MediaBrowser.Api.Images.ImageService>.<CreateExecFn>b__5 (object,object) <0x0002d> at ServiceStack.Host.ServiceRunner`1<MediaBrowser.Api.Images.PostUserImage>.Execute (ServiceStack.Web.IRequest,object,MediaBrowser.Api.Images.PostUserImage) <0x00438> 2015-05-29 08:46:19.3095 Error - HttpServer: Error processing request for /emby/Users/8a40d46c35524b698835854548210fd0/Images/Primary *** Error Report *** Version: 3.0.5621.3 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.24 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. ServiceStack.HttpError No Stack Trace Available
Xtropy 4 Posted May 29, 2015 Posted May 29, 2015 Hi everybody, I'm brand new to emby, and I love it so far. But there seems to be a quirk that I can't figure out. Whenever I go to change my profile picture, I'll get various error popups. These can range from The requested value "Images" was not found There was an error processing the request. Please try again later Server is running on Ubuntu 14.04.1, I'm not sure what's going on or where to check for errors. Could somebody point me in the right direction? EDIT: I managed to pull the following from the logs if this helps 2015-05-29 08:46:19.3094 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5621.3 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.24 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. System.ArgumentException at System.Enum.Parse (System.Type,string,bool) <0x00144> at MediaBrowser.Api.Images.ImageService.Post (MediaBrowser.Api.Images.PostUserImage) <0x00062> at (wrapper dynamic-method) object.lambda_method (System.Runtime.CompilerServices.Closure,object,object) <0x00074> at ServiceStack.Host.ServiceExec`1/<>c__DisplayClass6<MediaBrowser.Api.Images.ImageService>.<CreateExecFn>b__5 (object,object) <0x0002d> at ServiceStack.Host.ServiceRunner`1<MediaBrowser.Api.Images.PostUserImage>.Execute (ServiceStack.Web.IRequest,object,MediaBrowser.Api.Images.PostUserImage) <0x00438> 2015-05-29 08:46:19.3095 Error - HttpServer: Error processing request for /emby/Users/8a40d46c35524b698835854548210fd0/Images/Primary *** Error Report *** Version: 3.0.5621.3 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.24 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. ServiceStack.HttpError No Stack Trace Available I get this same error as well adding a picture to my profile: 2015-05-29 09:17:49.5226 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.53 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. System.ArgumentException at System.Enum.Parse (System.Type,string,bool) <0x00144> at MediaBrowser.Api.Images.ImageService.Post (MediaBrowser.Api.Images.PostUserImage) <0x00062> at (wrapper dynamic-method) object.lambda_method (System.Runtime.CompilerServices.Closure,object,object) <0x00074> at ServiceStack.Host.ServiceExec`1/<>c__DisplayClass6<MediaBrowser.Api.Images.ImageService>.<CreateExecFn>b__5 (object,object) <0x0002d> at ServiceStack.Host.ServiceRunner`1<MediaBrowser.Api.Images.PostUserImage>.Execute (ServiceStack.Web.IRequest,object,MediaBrowser.Api.Images.PostUserImage) <0x00428> 2015-05-29 09:17:49.5226 Error - HttpServer: Error processing request for /emby/Users/5c7857daae87491292e1d7655172f342/Images/Primary *** Error Report *** Version: 3.0.5621.4 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby Operating system: Unix 3.13.0.53 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby Mono: 4.0.1 (tarball Tue May 12 18:04:15 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe The requested value 'Images' was not found. ServiceStack.HttpError No Stack Trace Available Seems similar to my other post related to scheduled tasks which sends similar errors.... http://emby.media/community/index.php?/topic/21765-scheduled-tasks-issue-on-ubuntu-server/
Luke 42242 Posted May 29, 2015 Author Posted May 29, 2015 what browser did you test with? i just tried with chrome and it seemed to be fine
Xtropy 4 Posted May 29, 2015 Posted May 29, 2015 (edited) what browser did you test with? i just tried with chrome and it seemed to be fine Chrome, Firefox and IE all have the issue. Tried from 2 different PC's (local subnet and WAN) as well.... May be worth noting that I am a newer user as well Edited May 29, 2015 by Xtropy
