Ubuntu
thefirstofthe300
Any tips on how I can install Emby server on Ubuntu 12.04? The following commands are okay:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 637D1286
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
But I get an error message on the next line:
myname@myserver:~$ sudo echo 'deb http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu trusty main' > /etc/apt/sources.list.d/mediabrowser.list
-bash: /etc/apt/sources.list.d/mediabrowser.list: Permission denied
Try elevating to root before running the above command:
$ sudo su
# echo 'deb http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu trusty main' > /etc/apt/sources.list.d/mediabrowser.list
Sometimes that will fix permission denied errors even if the previous command used sudo.
  • Like 1
I'm also getting this bug. Running Ubuntu Server 14.04, unable to access the web client. Doesn't matter if I restart the mediabrowser service or reboot the machine, unable to access the server through the web client at all anymore.
This is not the problem I'm having. I have full access to web ui.
However I cannot chose to use the web ui or windows phone app to remote play to my xbmc (with kodi plugin) clients. They don't show up. A DLNA client does show up after a while though. So the issue may be related to kodi plugin. Even though the clients are listed as connected when I look at settings.
Edited by KRA
That worked! Thanks! :)
$ sudo su
Progress, but I hit another snag after:
apt-get install -qy --force-yes libmono-cil-dev mediainfo wget libsqlite3-dev libc6-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2
I get:
Reading package lists...
Building dependency tree...
Reading state information...
mediainfo is already the newest version.
libc6-dev is already the newest version.
libsqlite3-dev is already the newest version.
wget is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libmagickcore-6.q8-2 : Depends: libfftw3-double3 but it is not installable
                        Depends: libfontconfig1 (>= 2.9.0) but 2.8.0-3ubuntu9.1 is to be installed
                        Depends: libjbig0 (>= 2.0) but it is not installable
                        Depends: liblzma5 (>= 5.1.1alpha+20120614) but 5.1.1alpha+20110809-3 is to be installed
                        Depends: libtiff5 (>= 4.0.3) but it is not installable
E: Unable to correct problems, you have held broken packages.
I'm installing it on Ubuntu 12.04
hurricanehrndz
I get:
Officially we only support trusty and up. Since you are on 12.04 your are on your own, my suggestion would be to use docker, if that is not an option please look into this https://help.ubuntu.com/community/UbuntuBackports
Please be aware your system's stability may be affected.
Oh. Got it. :)
I'm going through the process of trying to install emby from scratch on a clean ubuntu 14.10 mini/net install.
Just a small note in the install instructions.
after the
# install dependencies
you would need
apt-get update
before you can continue.
Also, maybe one should point out that before you start you would need to run sudo su, or simply put sudo on front of every line.
  • Like 1
cjlopez213
This is exactly what I was looking for, thanks to all of the developers this is awesome!
The only problem I have right now is I can't skip through the movies or videos? Is there anyway to be able to do that?  :(
Edited by cjlopez213
thefirstofthe300
When you say skip, do you mean something like fast forwarding while watching a movie or do you mean skipping through the library while browsing your collection?
cjlopez213
Oh yeah should have clarified I meant fast forward while watching a movie. It's just greyed out and I can't fast forward.
Oh scratch that I guess I had to wait for the video to encode or something cause I'm able to fast forward now, thanks for the fast response anyway though! I love this software!  :D
Installed 3.0.5572.0 on Ubuntu server 14.04.2 LTS and I'm getting no thumbnails for music ja home videos!
Movie posters and other stuff which are downloaded from interwebz are working fine!
  • 3 weeks later...
fantaxp7
how are you guys doing with multiple streams for cpu usage? My father has two rokus and reports it's at 100% with 10 dedicated cpus (run in a VM) and the rokus sometimes reboot.
  • 4 weeks later...
allen00se
Just FYI... I installed on Ubuntu Server 15.04 and all went well. Only issue so far is that I can't use a network path for the library, I had to mount the samba share, use the mount and then make a path substitution. When I tried to use the network path for the library it would complain that it didn't exist.
I just install the emby and previously had mediabrowser installed.
Now I can't scan my library..
It seems to look for /var/lib/mediabrowser/root  which doesn't exist now, it's emby now.
2015-05-27 12:55:00.3465 Info - App: Scan media library Completed after 0 minute(s) and 0 seconds
2015-05-27 12:55:00.3465 Error - LibraryMonitor: Error watching path: /var/lib/mediabrowser/root
How can i change this?
Any one with a suggestion.
Thanks!
Edited by freebs
  • Like 1
hurricanehrndz
/etc/default/emby is where the program data is defined. The installation process should have move /var/lib/mediabrowser to /var/lib/emby. Unless you had used other directories.
they are moved yes... i see them there, but still doesn't scan that folder.
tymanthius
Thanks!
I'm trying to test out emby again and having the same issue. VERY annoying.  I found one post that seemed to say emby can't handle ganged drives (I'm using LVM).
hurricanehrndz
Please check the permission of your folder, it should be owned by emby.
First thing I checked... this is very odd.
root@HTPC:~# ls  -l /var/lib/emby
total 208
drwxr-xr-x 19 emby emby   4096 May 24 01:28 cache
drwxr-xr-x  4 emby emby   4096 May 23 17:04 config
drwxr-xr-x  7 emby emby   4096 May 27 13:12 data
drwxr-xr-x  3 emby emby   4096 May 22 10:59 ffmpeg
drwxr-xr-x  2 emby emby   4096 May 23 19:48 fonts
drwxr-xr-x  2 emby emby   4096 May 22 10:59 localization
drwxr-xr-x  2 emby emby  32768 May 27 13:12 logs
drwxr-xr-x 12 emby emby   4096 May 24 12:22 metadata
drwxr-xr-x  4 emby emby   4096 May 27 11:23 plugins
drwxr-xr-x  3 emby emby   4096 May 22 11:00 root
drwxr-xr-x  2 emby emby   4096 May 22 11:31 ssl
drwxr-xr-x  2 emby emby 139264 May 27 12:05 transcoding-temp
hurricanehrndz
total 208
please run the following command
mkdir -p /var/lib/mediabrowser
ln -s /var/lib/emby/root /var/lib/mediabrowser/root
that indeed brought it all back...
spoke too soon.. folders are there.. nothing in emby as far as media goes.
Edited by freebs
hurricanehrndz
Glad it worked out for you.
Edited by hurricanehernandez
hurricanehrndz
It probably has to rescan. You could always adjust your library folders. Go to the dashboard. Then library. And adjust each media location. Under Media Library, under FoldersiLNF6LR.png
No no.. these are NFS mounts on my HTPC. I just pointed my folders with emby server is all.
ie; /mnt/movies , /mnt/tvshows, etc;
It was working fine before I did this upgrade.. :)
FreeNas stores all my files.
