Luke 42244 Posted February 21, 2020 Author Posted February 21, 2020 An ssl certificate is required even on a local network? even if I don’t have a tick on the permission of remote access? To use https, yes, but not to use http.
sfatula 208 Posted February 21, 2020 Posted February 21, 2020 An ssl certificate is required even on a local network? even if I don’t have a tick on the permission of remote access? It is indeed, but note it doesn't have to be a PAID certificate. I use letsencrypt and their tool to help manage the updates certbot. The info is on their site and in some tutorials on this site. Once setup, it does take some effort, it just works.
mastrmind11 722 Posted February 21, 2020 Posted February 21, 2020 An ssl certificate is required even on a local network? even if I don’t have a tick on the permission of remote access? Why would you care about SSL on a local network? It's your network and your devices.
akarpych 7 Posted February 22, 2020 Posted February 22, 2020 I'm trying to configure https on an external network. But even on the local network, it doesn’t appear on https. I get a free certificate, collect it in the right container with a password, but it still does not work ....
Luke 42244 Posted February 22, 2020 Author Posted February 22, 2020 Please see my response in post #1427. Thanks.
Luke 42244 Posted March 3, 2020 Author Posted March 3, 2020 For those looking for additional options to run Emby Server, we now have Snap packages available for testing: https://emby.media/community/index.php?/topic/83274-emby-server-snap-packages/ Thanks !
ChristiaanCIVL 0 Posted March 12, 2020 Posted March 12, 2020 Hi I am using Emby on my Ubuntu 16 ran Seedbox. It worked awesomly, but now it seems to crash all the time. We are mainly using it in combination with the SamungTV app.How to generate a log file i can post? Thanks!
Luke 42244 Posted March 12, 2020 Author Posted March 12, 2020 Hi I am using Emby on my Ubuntu 16 ran Seedbox. It worked awesomly, but now it seems to crash all the time. We are mainly using it in combination with the SamungTV app. How to generate a log file i can post? Thanks! Hi there, please start a new topic and attach the information requested in how to report a problem. Thanks !
asdffdsa6131 0 Posted April 16, 2020 Posted April 16, 2020 hello and thanks for helping a newbie. i have been running emby on windows server without problem. it has a portable mode and so no install is required. but on my ubuntu seedbox, i am forced to run an install dpkg -i emby-server-deb_4.4.2.0_amd64.deb but i get this error "System has not been booted with systemd as init system (PID 1). Can't operate.dpkg: error processing package emby-server (--install): installed emby-server package post-installation script subprocess returned error exit status 1" i am not a linux expert but systemd is for running applications as a service and for autostart. as on windows, i run emby via command line. so is there a way to run emby without systemd, to run, on demand, via command line? thanks, david
Luke 42244 Posted April 16, 2020 Author Posted April 16, 2020 Currently our packages require systemd.
mastrmind11 722 Posted April 16, 2020 Posted April 16, 2020 the bigger question is why you don't have systemd on a modern distro. Perhaps look into fixing that, since it's going to be a problem with pretty much everything else down the road. 1
TH3P1TBUL 0 Posted April 20, 2020 Posted April 20, 2020 hi i need some help with my server. i installed a second harddrive which i parted and mounted. now i want to add this to my movies library but emby does not see it. i have set the rights for the drive to 777 and emby is the owner.it still does not see it. the location is /media/bertflix(name of my user)/cb577859-364d-9fd1-be112fd8476c. when i type this into emby it sees media/bertflix but when i click it it goes back to blank. any ideas how to fix?
mastrmind11 722 Posted April 20, 2020 Posted April 20, 2020 hi i need some help with my server. i installed a second harddrive which i parted and mounted. now i want to add this to my movies library but emby does not see it. i have set the rights for the drive to 777 and emby is the owner.it still does not see it. the location is /media/bertflix(name of my user)/cb577859-364d-9fd1-be112fd8476c. when i type this into emby it sees media/bertflix but when i click it it goes back to blank. any ideas how to fix? how did you mount the drive? Thats a pretty strange folder name.
TH3P1TBUL 0 Posted April 20, 2020 Posted April 20, 2020 how did you mount the drive? Thats a pretty strange folder name. https://askubuntu.com/questions/125257/how-do-i-add-an-additional-hard-drive i used this
mastrmind11 722 Posted April 20, 2020 Posted April 20, 2020 https://askubuntu.com/questions/125257/how-do-i-add-an-additional-hard-drive i used this that doesn't explain the odd folder name. what is the output of ls -l when run from /media/bertflix? also paste the contents of your fstab
TH3P1TBUL 0 Posted April 20, 2020 Posted April 20, 2020 that doesn't explain the odd folder name. what is the output of ls -l when run from /media/bertflix? also paste the contents of your fstab here you go
mastrmind11 722 Posted April 20, 2020 Posted April 20, 2020 here you go Thats mounting the drive to /hdd. None of this was in the tutorial you followed so I'm unsure how you got here. The 2nd param needs to point to where you plan to mount the drive, so if you want it at that funky folder, you have to stick the whole path in your fstab. If you run sudo mount -a, and navigate to /hdd, thats your new drive. If it errors out, then that folder doesn't exist. Either way, figure out where you want to mount the drive and edit fstab to reflect that.
TH3P1TBUL 0 Posted April 21, 2020 Posted April 21, 2020 Thats mounting the drive to /hdd. None of this was in the tutorial you followed so I'm unsure how you got here. The 2nd param needs to point to where you plan to mount the drive, so if you want it at that funky folder, you have to stick the whole path in your fstab. If you run sudo mount -a, and navigate to /hdd, thats your new drive. If it errors out, then that folder doesn't exist. Either way, figure out where you want to mount the drive and edit fstab to reflect that. i tried it but it still does not work. here are some screenshots. any ideas on what i am doing wrong?
mastrmind11 722 Posted April 21, 2020 Posted April 21, 2020 i tried it but it still does not work. here are some screenshots. any ideas on what i am doing wrong? to start, you're mounting the wrong drive.... sda is your boot drive, sdb is your 2nd drive. you can tell this by just looking at 1). the tutorial you said you followed and 2) your original fstab (which showed sdb as the drive you are mounting). i recommend you try to understand what you're actually doing before copy+pasting stuff all over your system. it can be pretty dangerous running commands on linux w/o knowing what you're actually doing. anyway, get the correct drive in fstab and you should be good to go...
zonknz 4 Posted April 25, 2020 Posted April 25, 2020 (edited) Anyone running emby on 20.04 LTS as yet? Thinking about having a play tomorrow - anyone found any dealbreaker issues. (Know about certbot not working, and of the workaround! - https://twitter.com/IshSookun/status/1253684862726189058) Edited April 25, 2020 by zonknz
zonknz 4 Posted April 26, 2020 Posted April 26, 2020 Confirmed- all good and working on 20.04 with no issues found. 2
michalb 0 Posted June 6, 2020 Posted June 6, 2020 Hi, please bare with me, I'm new to Emby and also with limited knowledge of Linux (I know, bad mix)... I installed the Emby few days ago on Ubuntu 20.04 and all is great ! Apart when I bought and installed Nvidia gtx1660 exclusively for video hardware transcoding. I installed driver for Nvidia 440 from repository and the card is recognized by the system: sudo lshw -C video *-display description: VGA compatible controller product: TU116 [GeForce GTX 1660] vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 version: a1 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller bus_master cap_list rom configuration: driver=nvidia latency=0 resources: irq:44 memory:ee000000-eeffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:e000(size=128) memory:c0000-dffff I have only enabled Emby player, but from what I understand the server still should use the hardware for the task (hardware transcoding is selected in the server config). The app is enabled in Shield TV, and I did transcode test from my phone. That does not ask for enabling so I assume it is ok (Nvidia and the phone share the same account) If this is correct then I have a problem of Emby not using the Nvidia because the Nvidia activity stays at the same level and the CPU is getting maxed out when transcoding. So my question is, is the installing Nvidia drivers only, enough or should I do some more tasks to enable the hardware transcoding? If it is enough, then what would be the next steps for troubleshooting ? Thank you.
michalb 0 Posted June 6, 2020 Posted June 6, 2020 If tat is of any help: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder libx264 Software Encoder Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'libx264 Software Encoder' Info Check successful - selecting 'libx264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Automatic Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info ColorConversion >> False False Info SubtitleOverlay >> False False Info VideoOutput >> False False Not a hardware encoder Info libx264 Software Encoder >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Next Info hevc >> - yuv420p10 yuv420p10 >> format Info format >> - yuv420p yuv420p >> overlay Info overlay >> - yuv420p yuv420p >> Thanks.
michalb 0 Posted June 7, 2020 Posted June 7, 2020 OK, ignore the previous assistance posts. It all started to work after I bought Premiere. Cheers
Risiamu 0 Posted August 31, 2020 Posted August 31, 2020 # arxher @ arxher-desktop in ~ [10:20:06] $ sudo systemctl status emby-server ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Mon 2020-08-31 10:19:16 CST; 57s ago Main PID: 18714 (code=killed, signal=ABRT) 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 8月 31 10:19:16 arxher-desktop emby-server[18714]: Stack overflow. 8月 31 10:19:16 arxher-desktop systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT 8月 31 10:19:16 arxher-desktop systemd[1]: emby-server.service: Failed with result 'signal'. ...skipping... ● emby-server.service - Emby Server is a personal media server with apps on just about every device. Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Mon 2020-08-31 10:19:16 CST; 57s ago Main PID: 18714 (code=killed, signal=ABRT) 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. 8月 31 10:19:16 arxher-desktop emby-server[18714]: Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 8月 31 10:19:16 arxher-desktop emby-server[18714]: Stack overflow. 8月 31 10:19:16 arxher-desktop systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT 8月 31 10:19:16 arxher-desktop systemd[1]: emby-server.service: Failed with result 'signal'. Meeting some stackoverflow problem. I am running this on Jetson Nano (ARMV8) Ubuntu 18. It initialy works fine, but then i can't start it....
