concord 0 Posted September 20, 2018 Posted September 20, 2018 That's your HD Homerun model. What version of the Roku app are you running? I just plulled the lastest build, rebooted and it seems to be working now....
lordvader 2 Posted October 11, 2018 Posted October 11, 2018 Um...I'm on Ubuntu 16.04. I was running a 3.3 (I think) version of emby. I just realised that the repositories are not longer being updated, do I downloaded the latest version (3.5.x), and installed it via apt. When connecting to emby, I was greeted with the "first run" wizard! So I've basically lost my database ... Would there have been a backup created somewhere, as this is NOT what I expected from an upgrade ...
lordvader 2 Posted October 11, 2018 Posted October 11, 2018 Never mind!Just realised that the paths had changed
LeidenSpain 33 Posted November 13, 2018 Posted November 13, 2018 HiI'm using emby 3.5.3.0 and Lubuntu 18.04.1 LTS over an Intel N4100 (GPU UHD600). This chip has hardware transcodification- First I used emby with windows and IntelQuickSync and I saw how the use of the GPU increased.But now I to use ubuntu, and I can not use transcoding with emby (but if it is used in the video player). This is my info home-server@home-server:~$ vainfo libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.1.0) vainfo: Driver version: Intel i965 driver for Intel® Gemini Lake - 2.1.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointEncSlice VAProfileVP9Profile2 : VAEntrypointVLD home-server@home-server:~$ ffmpeg -version ffmpeg version 4.0.3-1~18.04.york0 Copyright © 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu 7.3.0-27ubuntu1~18.04) configuration: --prefix=/usr --extra-version='1~18.04.york0' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 And now playing a film I have ABSOLUTELY tried everything I found online, and it does not work. I have come to the conclusion that it is emby who does not use transcoding correctly. I have not found the log of ffmpeg PLEASE, IT'S VERY IMPORTANT Regards
Luke 42244 Posted November 13, 2018 Author Posted November 13, 2018 Did you add emby to the video group? 1
LeidenSpain 33 Posted November 13, 2018 Posted November 13, 2018 (edited) Did you add emby to the video group? Yes, I have followed this tutorial: https://emby.media/community/index.php?/topic/48588-confirmed-linux-intel-quick-sync-transcoding/ 12. Add the emby service account to the video group sudo usermod -a -G video emby 13. restart the emby-server service sudo service emby-server restart And try this: 1. sudo add-apt-repository ppa:jonathonf/ffmpeg-3 2. sudo apt-get update && sudo apt install ffmpeg libav-tools x264 x265 3. sudo apt update && sudo apt upgrade But using sudo add-apt-repository ppa:jonathonf/ffmpeg-4 home-server@home-server:~$ sudo apt-cache policy ffmpeg ffmpeg: Instalados: 7:4.0.3-1~18.04.york0 Candidato: 7:4.0.3-1~18.04.york0 Tabla de versión: *** 7:4.0.3-1~18.04.york0 500 500 http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu bionic/main amd64 Packages 100 /var/lib/dpkg/status 7:3.4.4-0ubuntu0.18.04.1 500 500 http://es.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages 7:3.4.2-2 500 500 http://es.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages but in this tutorial, must used "path to ffmpeg" and now this option it's not enabled regards Edited November 13, 2018 by juancarlos.castro
sfatula 208 Posted November 13, 2018 Posted November 13, 2018 Works for me, so, it can work. On the transcoding screen, did you pick VAAPI or Intel Quick Sync? VA API is the correct choice. 1
LeidenSpain 33 Posted November 13, 2018 Posted November 13, 2018 Works for me, so, it can work. On the transcoding screen, did you pick VAAPI or Intel Quick Sync? VA API is the correct choice. Hi, In Ubuntu I use the VA API option, with all the default options. What system do you have?
sfatula 208 Posted November 13, 2018 Posted November 13, 2018 (edited) I am using a NUC7i7CNKE and xubuntu 18.04.1. So, if you type the command: groups emby You see video listed? I guess so, if I read your comment correctly, the video player uses it. I am using the ubuntu ffmpeg, perhaps you have tried that instead of your later version? ubuntu uses 3.4.4, installed using apt without any third party ppa. That NUC has a Intel 620 gpu. It appears you have many newer versions not found by default on ubuntu. For example, your vainfo shows VA-API version 1.4.0, mine on 18.04.1 shows 1.1.0. Edited November 13, 2018 by sfatula 1
LeidenSpain 33 Posted November 13, 2018 Posted November 13, 2018 I am using a NUC7i7CNKE and xubuntu 18.04.1. So, if you type the command: groups emby You see video listed? I guess so, if I read your comment correctly, the video player uses it. I am using the ubuntu ffmpeg, perhaps you have tried that instead of your later version? ubuntu uses 3.4.4, installed using apt without any third party ppa. That NUC has a Intel 620 gpu. I don't know home-server@home-server:~$ groups emby emby : emby video Is it correct??? I must used a lot of diferents software, to try to find a solution My actual version is this: home-server@home-server:~$ ffmpeg -version ffmpeg version 4.0.3-1~18.04.york0 Copyright © 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu 7.3.0-27ubuntu1~18.04) configuration: --prefix=/usr --extra-version='1~18.04.york0' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100
sfatula 208 Posted November 13, 2018 Posted November 13, 2018 (edited) Yeah, I see you are on V4 of ffmpeg, I was merely wondering if it worked without any non ubuntu ffmpeg installed, especially since mine does. The only thing I did was add video group to emby user, which you did. The movie you are playing that appears to not be using VA-API, what codec is the video? I did not see it (could have missed it) in your screen captures. A useful command for your ffmpeg is this: ffmpeg -hide_banner -encoders | grep vaapi Mine shows: V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) V..... mpeg2_vaapi MPEG-2 (VAAPI) (codec mpeg2video) V..... vp8_vaapi VP8 (VAAPI) (codec vp8) V..... vp9_vaapi VP9 (VAAPI) (codec vp9) On your post 1283, I am confused (which isn't hard to do). The second set of screen captures right after where you say "And now playing a film"..... What is that supposed to represent? I don't see any ffmpeg there, just mpv, and, therefore it's not fair to compare that with emby which is using ffmpeg. i.e., I don't think that means it's embys fault. This is comparing apples to oranges. Edited November 13, 2018 by sfatula 1
LeidenSpain 33 Posted November 13, 2018 Posted November 13, 2018 Yeah, I see you are on V4 of ffmpeg, I was merely wondering if it worked without any non ubuntu ffmpeg installed, especially since mine does. The only thing I did was add video group to emby user, which you did. The movie you are playing that appears to not be using VA-API, what codec is the video? I did not see it (could have missed it) in your screen captures. A useful command for your ffmpeg is this: ffmpeg -hide_banner -encoders | grep vaapi Mine shows: V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) V..... mpeg2_vaapi MPEG-2 (VAAPI) (codec mpeg2video) V..... vp8_vaapi VP8 (VAAPI) (codec vp8) V..... vp9_vaapi VP9 (VAAPI) (codec vp9) I have tried several videos: This don't use the transcoding CPU transcoding CPU transcoding I'm using the chome to see the videos. home-server@home-server:~$ ffmpeg -hide_banner -encoders | grep vaapi V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) V..... mpeg2_vaapi MPEG-2 (VAAPI) (codec mpeg2video) V..... vp8_vaapi VP8 (VAAPI) (codec vp8) V..... vp9_vaapi VP9 (VAAPI) (codec vp9) The problem is, if I activate hardware acceleration, it is disabled when transcoding starts.
sfatula 208 Posted November 13, 2018 Posted November 13, 2018 So, you are saying in emby, if you enable VA-API, click save, and go back later, it is not enabled? Did you change it via the web interface in a browser? I had the same behavior from an IOS client. Unless I mis-understand. If it helps, my transcoding screen looks like this: 1
Luke 42244 Posted November 14, 2018 Author Posted November 14, 2018 If you enable vaapi and it fails, the server will automatically fallback to CPU. However, the 3.5 release has a defect that it also disables it in settings when this happens. This is resolved for the next release. Thanks. 1
LeidenSpain 33 Posted November 14, 2018 Posted November 14, 2018 So, you are saying in emby, if you enable VA-API, click save, and go back later, it is not enabled? Did you change it via the web interface in a browser? I had the same behavior from an IOS client. Unless I mis-understand. If it helps, my transcoding screen looks like this: Hi, It's not exactly the situation: I enable the VA API transcodification, and it remanins on until emby try to transcodificate. This is my transcoding options
LeidenSpain 33 Posted November 14, 2018 Posted November 14, 2018 If you enable vaapi and it fails, the server will automatically fallback to CPU. However, the 3.5 release has a defect that it also disables it in settings when this happens. This is resolved for the next release. Thanks. OK thanks I will try to install the latest beta
sfatula 208 Posted November 14, 2018 Posted November 14, 2018 Hi, It's not exactly the situation: I enable the VA API transcodification, and it remanins on until emby try to transcodificate. This is my transcoding options So, that would indicate that it is failing to run hardware transcoding. I suspect your problem is all of the non standard versions of your packages. This becomes a nightmare to sort out as each of those can use other non standard packages, etc. 1
LeidenSpain 33 Posted November 14, 2018 Posted November 14, 2018 So, that would indicate that it is failing to run hardware transcoding. I suspect your problem is all of the non standard versions of your packages. This becomes a nightmare to sort out as each of those can use other non standard packages, etc. yes, my system may be is dirty, after I installed everything I found to make the transcoding work Now I am away from home, when I return I will reinstall everything from 0. I tested with the latest beta, Now the hardware option is not disabled, but I do not notice any difference in performance ON OFF What do you think is the best way???? (drivers developer, ffmpeg version, etc...)
sfatula 208 Posted November 14, 2018 Posted November 14, 2018 Yes, since you were having hardware transcoding disabled, and, Luke said if hardware transcoding fails, then, it disabled it, it makes sense that the Beta would do nothing other than leave your setting on. To me, it was better that it disabled it as then you knew that hardware transcoding was indeed broken. Though, confusing. I tend to keep everything as ubuntu versions, they have done the testing and sorting out of what works with what, etc. If I have a new package and that package isn't in the ubuntu repos, I don't mind adding a ppa for it, but, for everything already in the ubuntu repositories, I use those. They may not be latest and greatest, but they are tested somewhat. 1
LeidenSpain 33 Posted November 14, 2018 Posted November 14, 2018 Yes, since you were having hardware transcoding disabled, and, Luke said if hardware transcoding fails, then, it disabled it, it makes sense that the Beta would do nothing other than leave your setting on. To me, it was better that it disabled it as then you knew that hardware transcoding was indeed broken. Though, confusing. I tend to keep everything as ubuntu versions, they have done the testing and sorting out of what works with what, etc. If I have a new package and that package isn't in the ubuntu repos, I don't mind adding a ppa for it, but, for everything already in the ubuntu repositories, I use those. They may not be latest and greatest, but they are tested somewhat. OK thanks When I return to home I will install Lubuntu 18.04.1 LTS, and I will start all the tests again from 0 (better with the emby release or the beta version?) Regards
sfatula 208 Posted November 14, 2018 Posted November 14, 2018 (edited) I would not use the Beta myself, up to you, I am just saying it works fine on xubuntu 18.04.1 for me, and it worked first try. Twice. I had an old machine I had put Emby on and ran for a while, recently got a new machine, installed the OS, everything, and Emby, and it worked also. Now, it could be that your older machine has a bug with VA-API (not emby, the driver), no idea. But I am very skeptical that the problem, whatever it is, resides in Emby is what I am trying to say. Edited November 14, 2018 by sfatula 1
Luke 42244 Posted November 14, 2018 Author Posted November 14, 2018 To me, it was better that it disabled it as then you knew that hardware transcoding was indeed broken. Though, confusing. That's not a true statement because sometimes the hardware encoders or decoders will have problems with a specific file, but may still be fine for others. 1
sfatula 208 Posted November 14, 2018 Posted November 14, 2018 Well, it is a true statement, as it is prefixed by "To me". That doesn't mean I am right of course. But given your example, I would tend to side with you now! 1
LeidenSpain 33 Posted November 15, 2018 Posted November 15, 2018 my idea is to use transcoding by gpu, and I think as my case, there will be more people with the same configuration (ubuntu with intel UHD). Therefore, it would be helpful for everyone to find out the source of the problem. Tomorrow I hope to be at home, from that point I hope to be able to do all the tests that are considered necessary. regards 1
