Luke 42244 Posted May 12, 2018 Author Posted May 12, 2018 Hi there, please attach the complete emby server log, thanks.
waki89 0 Posted May 12, 2018 Posted May 12, 2018 Hi there, please attach the complete emby server log, thanks. I have attached the log that kills the server when running the library scan Log.txt
dobs 1 Posted May 15, 2018 Posted May 15, 2018 The CoverArt Plugin crashes emby on ubuntu 18.04 for me on the same images over and over. If anyone else has the issue, try removing the plugin.
Luke 42244 Posted May 15, 2018 Author Posted May 15, 2018 The CoverArt Plugin crashes emby on ubuntu 18.04 for me on the same images over and over. If anyone else has the issue, try removing the plugin. Hi, how are you determining this?
dobs 1 Posted May 15, 2018 Posted May 15, 2018 (edited) I upgraded my Server to 18.04 and updated emby to 3.4.1 after that I started to have some crashes (very sporadically). At some point emby would always crash when looking into the collection folder so I decided to remove and add all libraries, which did not help, so i purged the emby install and installed 3.3.1.I added all the libraries and it seemed to work fine, so I installed all plugins again, after which the crashes happened again any time I opened a folder where images for media were still missing. I turned on debug logging and the last lines would be 2018-05-15 09:18:37.268 Debug CoverArt: CoverArt using profile default for *** 2018-05-15 09:18:37.271 Debug CoverArt: Codec for *** is h264 2018-05-15 09:18:37.271 Debug CoverArt: CoverArt will create multi-image for ***. Children: 7 It has been stable for now, with the plugin turned off. Edited May 15, 2018 by dobs
schmitty 66 Posted May 17, 2018 Posted May 17, 2018 (edited) Hello, I don't know if this is a bug or permissions/configuration error but, I can not commit any changes to library configuration. I try to change settings via Library => TV or Movies => Manage Folders - whether it is changing fetchers, real-time processing, etc. then click the back arrow, and go back into configuration the settings I changed are unset. I have checked permissions of /opt/emby-server /srv/.config/emby /etc/emby-server.conf and the systemd service, and they are all set correctly. I wonder if it could be because I have changed the default -programdata flag from /opt/emby-server to /srv/.config/emby in the emby-server.conf... the log has been attached. Log.txt Edited May 17, 2018 by schmitty
schmitty 66 Posted May 17, 2018 Posted May 17, 2018 I upgraded my Server to 18.04 and updated emby to 3.4.1 after that I started to have some crashes (very sporadically). At some point emby would always crash when looking into the collection folder so I decided to remove and add all libraries, which did not help, so i purged the emby install and installed 3.3.1. I added all the libraries and it seemed to work fine, so I installed all plugins again, after which the crashes happened again any time I opened a folder where images for media were still missing. I turned on debug logging and the last lines would be 2018-05-15 09:18:37.268 Debug CoverArt: CoverArt using profile default for *** 2018-05-15 09:18:37.271 Debug CoverArt: Codec for *** is h264 2018-05-15 09:18:37.271 Debug CoverArt: CoverArt will create multi-image for ***. Children: 7 It has been stable for now, with the plugin turned off. I ended up removing CoverArt probably a year ago due to it causing issues with library-related operations. I even tried using it again recently after a reformat and reinstall... still caused server issues, so I removed it again.
Luke 42244 Posted May 17, 2018 Author Posted May 17, 2018 Hello, I don't know if this is a bug or permissions/configuration error but, I can not commit any changes to library configuration. I try to change settings via Library => TV or Movies => Manage Folders - whether it is changing fetchers, real-time processing, etc. then click the back arrow, and go back into configuration the settings I changed are unset. I have checked permissions of /opt/emby-server /srv/.config/emby /etc/emby-server.conf and the systemd service, and they are all set correctly. I wonder if it could be because I have changed the default -programdata flag from /opt/emby-server to /srv/.config/emby in the emby-server.conf... the log has been attached. Try pausing a second or two before you go back into the library.
Luke 42244 Posted May 17, 2018 Author Posted May 17, 2018 I ended up removing CoverArt probably a year ago due to it causing issues with library-related operations. I even tried using it again recently after a reformat and reinstall... still caused server issues, so I removed it again. It doesn't cause problems, it's just that it requires significant cpu resources to generate the images.
schmitty 66 Posted May 18, 2018 Posted May 18, 2018 Try pausing a second or two before you go back into the library. The problem is the settings are not saving. I go back in to the Manage Folders configuration and the settings I altered are cleared again. I even tried disabling all users except the admin to make the changes. Still no luck.
Luke 42244 Posted May 23, 2018 Author Posted May 23, 2018 I have not been able to reproduce this but will continue to test for it. I would suggest trying again. Thanks.
ruinzaO 1 Posted May 23, 2018 Posted May 23, 2018 (edited) Hello. My emby-server does not start. Could you help me, please? Ubuntu 16.04.4 LTS Sorry, I'm using the google translate. 2018-05-23 13:21:48.879 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-05-23 13:21:48.903 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.127 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-05-23 13:21:50.434 Info App: Application version: 3.4.1.0 2018-05-23 13:21:50.439 Info App: Loading assemblies 2018-05-23 13:21:50.678 Info App: File /var/lib/emby/plugins/IMVDb.dll has version 1.0.0.0 2018-05-23 13:21:50.702 Info App: File /opt/emby-server/system/plugins/IMVDb.dll has version 1.0.0.0 2018-05-23 13:21:50.727 Info App: File /var/lib/emby/plugins/OpenSubtitles.dll has version 1.0.1.0 2018-05-23 13:21:50.729 Info App: File /opt/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.1.0 2018-05-23 13:21:50.766 Info App: File /var/lib/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.0.0 2018-05-23 13:21:50.805 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.0.0 2018-05-23 13:21:50.849 Info App: Loading IMVDb, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll 2018-05-23 13:21:50.850 Info App: Loading OpenSubtitles, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll 2018-05-23 13:21:50.851 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:50.851 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-05-23 13:21:51.436 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-05-23 13:21:51.439 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-05-23 13:21:51.650 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal 2018-05-23 13:21:51.658 Info SqliteUserRepository: PRAGMA synchronous=1 2018-05-23 13:21:51.745 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal 2018-05-23 13:21:51.745 Info AuthenticationRepository: PRAGMA synchronous=1 2018-05-23 13:21:52.196 Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is wal 2018-05-23 13:21:52.196 Info DeviceManager: PRAGMA synchronous=1 2018-05-23 13:21:52.343 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal 2018-05-23 13:21:52.343 Info ActivityRepository: PRAGMA synchronous=1 2018-05-23 13:21:52.438 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal 2018-05-23 13:21:52.438 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-05-23 13:21:52.533 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal 2018-05-23 13:21:52.534 Info SqliteItemRepository: PRAGMA synchronous=1 2018-05-23 13:21:52.658 Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is wal 2018-05-23 13:21:52.659 Info SqliteNotificationsRepository: PRAGMA synchronous=1 After using the command: ln -s /var/lib/emby-server /var/lib/emby The server came back .. Thank you! Edited May 23, 2018 by ruinzaO
ruinzaO 1 Posted May 23, 2018 Posted May 23, 2018 Hi, so you're all set now? If the question was for me, yes it's working. Thank you friend.
schmitty 66 Posted May 24, 2018 Posted May 24, 2018 I ended up retrying what you suggested with a fresh install, and it worked. Thanks.
Luke 42244 Posted May 24, 2018 Author Posted May 24, 2018 Were you doing this from the web app before?
tomdh76 1 Posted May 24, 2018 Posted May 24, 2018 I have some troubles getting emby server on ubuntu with media files on a NAS. I mounted the nas folders on the ubuntu on /media/films etc. Then I used chown and chgrp for emby on that mount. Emby seems to work that way. If I add a film however on the NAS that has another owner, so I use a crontab to keep on changing the files to emby ownership. The problem is however that on the NAS also the ownership is changed to user 996 (probably emby from ubuntu?) . This is my lack of linux knowledge. But is there a way to keep on the NAS the original ownership and on the ubuntu mounted folders emby ownership?
ruinzaO 1 Posted May 25, 2018 Posted May 25, 2018 (edited) Hello guys. can you help me? My emby-server is in trouble =/ Ubuntu Server 16.04.4 LTS 2018-05-25 11:41:22.605 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-05-25 11:41:22.631 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.127 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-05-25 11:41:22.690 Error Main: UnhandledException System.IO.IOException: The system cannot open the device or file specified. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.Threading.Mutex.MutexTryCodeHelper.MutexTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.Mutex.CreateMutexWithGuaranteedCleanup(Boolean initiallyOwned, String name, Boolean& createdNew, SECURITY_ATTRIBUTES secAttrs) at EmbyServer.Program.Main(String[] args) System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.Threading.Mutex.MutexTryCodeHelper.MutexTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.Mutex.CreateMutexWithGuaranteedCleanup(Boolean initiallyOwned, String name, Boolean& createdNew, SECURITY_ATTRIBUTES secAttrs) at EmbyServer.Program.Main(String[] args) Edited May 25, 2018 by ruinzaO
Luke 42244 Posted May 26, 2018 Author Posted May 26, 2018 Hello guys. can you help me? My emby-server is in trouble =/ Ubuntu Server 16.04.4 LTS 2018-05-25 11:41:22.605 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-05-25 11:41:22.631 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.127 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-05-25 11:41:22.690 Error Main: UnhandledException System.IO.IOException: The system cannot open the device or file specified. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.Threading.Mutex.MutexTryCodeHelper.MutexTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.Mutex.CreateMutexWithGuaranteedCleanup(Boolean initiallyOwned, String name, Boolean& createdNew, SECURITY_ATTRIBUTES secAttrs) at EmbyServer.Program.Main(String[] args) System.IO.IOException at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.Threading.Mutex.MutexTryCodeHelper.MutexTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.Mutex.CreateMutexWithGuaranteedCleanup(Boolean initiallyOwned, String name, Boolean& createdNew, SECURITY_ATTRIBUTES secAttrs) at EmbyServer.Program.Main(String[] args) That's resolved on the beta channel. Thanks.
ruinzaO 1 Posted May 26, 2018 Posted May 26, 2018 That's resolved on the beta channel. Thanks. Thanks for the reply, my friend. I upgraded to the beta but unfortunately it did not work. Now, besides not starting the logs are blank. Any other suggestions?
Luke 42244 Posted May 26, 2018 Author Posted May 26, 2018 Please attach whatever log file is produced along with the terminal output. Thanks.
ruinzaO 1 Posted May 27, 2018 Posted May 27, 2018 Please attach whatever log file is produced along with the terminal output. Thanks. After upgrading to beta, I reset the libraries and it seems to be no problem Thank you friend.
hooray4me 52 Posted May 27, 2018 Posted May 27, 2018 (edited) I've been unsuccessful in trying to upgrade from 3.3.1 to 3.4.1. I've tried uninstalling via apt-get remove. I reinstalled 3.3.1 deb package and tried upgrading to 3.4.1 by downloading the corresponding deb package. The app just crashes shortly after starting a stream. When I downgrade to 3.3.1 everything works as expected. Am I missing something? Logs attached. 5-26.log Edited May 27, 2018 by robrhedrick
