hooray4me 52 Posted March 27, 2018 Posted March 27, 2018 appears to be the same across apps... Firetv (both beta and release) and just tried in chrome.
Luke 42244 Posted March 29, 2018 Author Posted March 29, 2018 Ok, we'll do some testing on that, thanks.
hooray4me 52 Posted April 16, 2018 Posted April 16, 2018 Would it be possible to incorporate volume leveling across episodes. We frequently put kid shows on shuffle for the little ones... depending on the episode the volume is extreme... to too quiet... especially annoying on short shows like Peppa Pig. I know alot is determined by the source file, but wondering if anything can be done.
hooray4me 52 Posted April 16, 2018 Posted April 16, 2018 Would it be possible to incorporate volume leveling across episodes. We frequently put kid shows on shuffle for the little ones... depending on the episode the volume is extreme... to too quiet... especially annoying on short shows like Peppa Pig. I know alot is determined by the source file, but wondering if anything can be done. Dunno if this would be relevant https://stackoverflow.com/questions/34562921/how-to-get-and-set-audio-volume-level-for-a-universal-windows-application
Luke 42244 Posted April 17, 2018 Author Posted April 17, 2018 Would it be possible to incorporate volume leveling across episodes. We frequently put kid shows on shuffle for the little ones... depending on the episode the volume is extreme... to too quiet... especially annoying on short shows like Peppa Pig. I know alot is determined by the source file, but wondering if anything can be done. Please open a feature request topic so that we can measure community demand for this. Thanks !
mastrmind11 722 Posted April 17, 2018 Posted April 17, 2018 (edited) Please open a feature request topic so that we can measure community demand for this. Thanks ! https://emby.media/community/index.php?/topic/54749-volume-leveling/?p=530847 Edited April 17, 2018 by mastrmind11
woenk 62 Posted April 18, 2018 Posted April 18, 2018 Fonsiderin that about 2 months ago my library scan got down to slightly over 30 minutes from over an hour, I would really appreciate if the developers take some steps back. Before the last update I was up to 50 minutes again, since the last release it does not finish at all. Thought at first I changed some settings but it seems that even a full backup from over a week ago does not help. Also get quite a few DNS errors now in the error logs and I really can not remmeber setting anywhere, that Emby shoutl do a subtitile download while scanning. bottom line...was fine, fast and stble, now its more broken...take a step back
Luke 42244 Posted April 19, 2018 Author Posted April 19, 2018 Fonsiderin that about 2 months ago my library scan got down to slightly over 30 minutes from over an hour, I would really appreciate if the developers take some steps back. Before the last update I was up to 50 minutes again, since the last release it does not finish at all. Thought at first I changed some settings but it seems that even a full backup from over a week ago does not help. Also get quite a few DNS errors now in the error logs and I really can not remmeber setting anywhere, that Emby shoutl do a subtitile download while scanning. bottom line...was fine, fast and stble, now its more broken...take a step back Hi @@woenk, we're happy to help. Please see how to report a problem. Thanks.
Maverick0815 2 Posted April 20, 2018 Posted April 20, 2018 I installed emby server two days ago on a fresh install of ubuntu 16.04. Today I wanted to access the emby-webinterface and got a connection refused. a quick look in the syslog revealed this: kernel: [ 8010.330860] EmbyServer[29502]: segfault at 0 ip 00007f98c7dbdad0 sp 00007f97f7ff41c8 error 4 in libc-2.23.so[7f98c7d48000+1c0000] Apr 20 21:11:57 Mediahub systemd[1]: emby-server.service: Main process exited, code=killed, status=11/SEGV Apr 20 21:11:57 Mediahub systemd[1]: emby-server.service: Unit entered failed state. Apr 20 21:11:57 Mediahub systemd[1]: emby-server.service: Failed with result 'signal' it crashes almost immediately
Luke 42244 Posted April 20, 2018 Author Posted April 20, 2018 hi there @@Maverick0815, is there an emby server log? can you please attach that? thanks.
Maverick0815 2 Posted April 20, 2018 Posted April 20, 2018 once I find it, I can attach it- can you tell me where I can locate it?
Maverick0815 2 Posted April 20, 2018 Posted April 20, 2018 There are the last two logfiles...server-63659857230.txtserver-63659855451.txt
Maverick0815 2 Posted April 24, 2018 Posted April 24, 2018 Hi there @@Luke, I don't suppose you have any idea yet what I could try?
Luke 42244 Posted April 24, 2018 Author Posted April 24, 2018 Can you try grabbing our beta package from the website and see if that makes a difference? Thanks.
Maverick0815 2 Posted April 25, 2018 Posted April 25, 2018 I uninstalled the release Version and installed the beta package. So far I only added my movies...and the Server is still up and running. I will add more when I get home and Keep you updated.
grayfados 2 Posted May 9, 2018 Posted May 9, 2018 @@Luke, there is a possibility to you release the last version of emby over the ppa?
Luke 42244 Posted May 9, 2018 Author Posted May 9, 2018 @@Luke, there is a possibility to you release the last version of emby over the ppa? For now, if you are using the old OBS-based packages, you will need to update manually using the procedures listed in posts #3 and #4 here: https://emby.media/community/index.php?/topic/58613-question-about-my-32-bit-upgrade/?p=574032 Thanks.
grayfados 2 Posted May 9, 2018 Posted May 9, 2018 For now, if you are using the old OBS-based packages, you will need to update manually using the procedures listed in posts #3 and #4 here: https://emby.media/community/index.php?/topic/58613-question-about-my-32-bit-upgrade/?p=574032 Thanks. Thanks Luke! I think that works!
strikegun 2 Posted May 9, 2018 Posted May 9, 2018 Hi, I just updated to 3.4.1.0 and had problems with some thumbs. I saw in the log, this: 2018-05-10 01:03:54.886 Error ImageProcessor: Error encoding image *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.116 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.IO.FileNotFoundException: File not found File name: '/var/lib/emby-server/root/default/Kinder-Filme/poster.png' at Emby.Drawing.Skia.SkiaEncoder.Decode(String path, Boolean forceCleanBitmap, IFileSystem fileSystem, Nullable`1 orientation, SKCodecOrigin& origin) at Emby.Drawing.Skia.SkiaEncoder.GetBitmap(String path, Boolean cropWhitespace, Boolean forceAnalyzeBitmap, Nullable`1 orientation, SKCodecOrigin& origin) at Emby.Drawing.Skia.SkiaEncoder.GetBitmap(String path, Boolean cropWhitespace, Boolean autoOrient, Nullable`1 orientation) at Emby.Drawing.Skia.SkiaEncoder.EncodeImage(String inputPath, DateTime dateModified, String outputPath, Boolean autoOrient, Nullable`1 orientation, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() System.IO.FileNotFoundException at Emby.Drawing.Skia.SkiaEncoder.Decode(String path, Boolean forceCleanBitmap, IFileSystem fileSystem, Nullable`1 orientation, SKCodecOrigin& origin) at Emby.Drawing.Skia.SkiaEncoder.GetBitmap(String path, Boolean cropWhitespace, Boolean forceAnalyzeBitmap, Nullable`1 orientation, SKCodecOrigin& origin) at Emby.Drawing.Skia.SkiaEncoder.GetBitmap(String path, Boolean cropWhitespace, Boolean autoOrient, Nullable`1 orientation) at Emby.Drawing.Skia.SkiaEncoder.EncodeImage(String inputPath, DateTime dateModified, String outputPath, Boolean autoOrient, Nullable`1 orientation, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.<ProcessImage>d__29.MoveNext() So, I have my programm data path under /var/lib/emby but why does it try to finde the files under /var/lib/emby-server/...... ? After I created a symbol link from emby-server to emby folder I doen't get any errors more. AND emby doesn't crash any more. Can I setup the folders any where correctly or is that a bug? Thanks
Luke 42244 Posted May 10, 2018 Author Posted May 10, 2018 Hi, I just updated to 3.4.1.0 and had problems with some thumbs. I saw in the log, this: So, I have my programm data path under /var/lib/emby but why does it try to finde the files under /var/lib/emby-server/...... ? After I created a symbol link from emby-server to emby folder I doen't get any errors more. AND emby doesn't crash any more. Can I setup the folders any where correctly or is that a bug? Thanks You should be fine. That's just a quick of switching from our legacy install package to our newer one. Thanks.
hooray4me 52 Posted May 11, 2018 Posted May 11, 2018 Luke, I tested upgrading from 3.3.1.0 to 3.4.1.0 this evening via dpkg. The upgrade was quick and did not error. I could initially stream something and then the service would crash. Tried restarting the service a couple times and restarting the server. I saw the same results. I'll pm you the logs as I don't want to sanitize 'em for public post. I ended up downgrading back to 3.3.1.0, which has been stable for me since its' release.
sylvio2000 23 Posted May 11, 2018 Posted May 11, 2018 Hello. I am not new to emby, but in the near future I would like to change my system from Windows7 to Ubuntu 18.04.1 with emby server and tvheadend. What I would like to know: Is this ubuntu setup really stable? I have read through a lot of pages within in this thread and it seems to me there are a lot of problems regarding updates and library. Maybe I am totally wrong but this is my impression
Luke 42244 Posted May 11, 2018 Author Posted May 11, 2018 The problems are related from switching to our legacy install package to our new install package. You'd be starting fresh with the new install package so it wouldn't apply to you.
waki89 0 Posted May 12, 2018 Posted May 12, 2018 Hi, I seem to be having little joy getting a new emby server up and running on Ubuntu. I have tried many times over the last 2 weeks to get this installed on different Ubuntu versions with Beta and Stable emby releases. However every time I add one of my network shares it seems to crash emby (either on a library scan or when landing on the home screen) On the home screen I do see that it has picked up the contents of the share as they appear without images, additionally I can browse the share when adding the folder to the library. The last few lines of the logs on the various occasions the library scans have caused the crash all appear to stop at a similar point (ImageProcessor) before the server crashes and I have to restart the service: e.g 1 2018-05-12 08:14:40.450 Debug App: Running FanartMovieImageProvider for smb://10.2.1.210/**************************************.mp4 2018-05-12 08:14:40.463 Debug App: Running post-scan task RefreshIntrosScanTask 2018-05-12 08:14:40.470 Debug XmlSerializer: Deserializing file /var/lib/emby/config/cinemamode.xml 2018-05-12 08:14:40.472 Debug App: Running post-scan task TvdbPrescanTask 2018-05-12 08:14:40.479 Debug App: Running post-scan task LocalTrailerPostScanTask 2018-05-12 08:14:40.502 Debug App: Running post-scan task ArtistsPostScanTask 2018-05-12 08:14:40.512 Debug App: Running post-scan task GameGenresPostScanTask 2018-05-12 08:14:40.514 Debug App: Running post-scan task GenresPostScanTask 2018-05-12 08:14:40.524 Debug App: Running GenreImageProvider for /var/lib/emby/metadata/Genre/Action 2018-05-12 08:14:40.530 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/752972ab36eb4894b48e39bf2120bfe2.png e.g 2 2018-05-11 16:54:03.663 Info HttpServer: HTTP GET http://10.2.1.67:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-11 16:54:03.664 Info HttpServer: HTTP Response 200 to 10.2.1.102. Time: 1ms. http://10.2.1.67:8096/web/css/images/logoblack.png2018-05-11 16:54:03.695 Info HttpServer: HTTP Response 200 to 10.2.1.102. Time: 57ms. http://10.2.1.67:8096/emby/Packages/Updates?PackageType=System2018-05-11 16:54:03.781 Info HttpClient: GET https://api.themoviedb.org/3/movie/432579?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-05-11 16:54:04.056 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2948160&plot=short&tomatoes=true&r=json2018-05-11 16:54:04.466 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/432579?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-05-11 16:54:04.850 Info ImageProcessor: Creating image collage and saving to /var/lib/emby/cache/temp/48dd8ec03fde4ee2b6d2c8e59b9ae33d.png If I create a local folder on the OS and add media to that it also scans and works without error. Any pointers would be greatly appreciated.
