Turboschnecke 2 Posted January 18, 2018 Posted January 18, 2018 (edited) Out of the box no. But i can search the web for it. Docker contains everything or has it some other dependencies? Edited January 18, 2018 by Turboschnecke
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 Our docker install has everything self contained.
hooray4me 52 Posted January 19, 2018 Posted January 19, 2018 3.2.70 Crashes and is not usable... had to downgrade to 3.2.60. ```Jan 19 10:28:08 tv emby-server[2003]: 7ff32be78000-7ff32be82000 r--p 00000000 fd:00 1311733 /usr/lib/emby-server/bin/SQLitePCLRaw.provider.sqlite3.dll Jan 19 10:28:08 tv emby-server[2003]: 7ff32be82000-7ff32be86000 r--p 00000000 fd:00 1311492 /usr/lib/mono/4.5/Facades/System.Runtime.dllJan 19 10:28:08 tv emby-server[2003]: 7ff32be86000-7ff32be92000 r--p 00000000 fd:00 1311717 /usr/lib/emby-server/bin/MediaBrowser.Common.dllJan 19 10:28:08 tv emby-server[2003]: 7ff32be92000-7ff32bf03000 r--p 00000000 fd:00 1311720 /usr/lib/emby-server/bin/MediaBrowser.Model.dllJan 19 10:28:08 tv emby-server[2003]: 7ff32bf03000-7ff32bffb000 rw-p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ff32bffb000-7ff32c05a000 ---p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ff32c05a000-7ff32c064000 rw-p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ff32c064000-7ff32c068000 r--p 00000000 fd:00 1311723 /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exeJan 19 10:28:08 tv emby-server[2003]: 7ff32c068000-7ff32c074000 rw-p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ff32c074000-7ff32c075000 rw-s 00000000 00:19 3 /dev/shm/mono.2036Jan 19 10:28:08 tv emby-server[2003]: 7ff32c075000-7ff32c078000 rw-p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ff32c078000-7ff32c079000 r--p 00027000 fd:00 2630388 /lib/x86_64-linux-gnu/ld-2.26.soJan 19 10:28:08 tv emby-server[2003]: 7ff32c079000-7ff32c07a000 rw-p 00028000 fd:00 2630388 /lib/x86_64-linux-gnu/ld-2.26.soJan 19 10:28:08 tv emby-server[2003]: 7ff32c07a000-7ff32c07b000 rw-p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ffc2cfab000-7ffc2cfb3000 ---p 00000000 00:00 0Jan 19 10:28:08 tv emby-server[2003]: 7ffc2d789000-7ffc2d7aa000 rw-p 00000000 00:00 0 [stack]Jan 19 10:28:08 tv emby-server[2003]: 7ffc2d7b5000-7ffc2d7b8000 r--p 00000000 00:00 0 [vvar]Jan 19 10:28:08 tv emby-server[2003]: 7ffc2d7b8000-7ffc2d7ba000 r-xp 00000000 00:00 0 [vdso]Jan 19 10:28:08 tv emby-server[2003]: ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]Jan 19 10:28:08 tv emby-server[2003]: Native stacktrace:Jan 19 10:28:08 tv emby-server[2003]: #011/usr/bin/mono-sgen(+0xcd694) [0x5564e58af694]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/bin/mono-sgen(+0x129dde) [0x5564e590bdde]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/bin/mono-sgen(+0x3c3b3) [0x5564e581e3b3]Jan 19 10:28:08 tv emby-server[2003]: #011/lib/x86_64-linux-gnu/libpthread.so.0(+0x13150) [0x7ff32b4e3150]Jan 19 10:28:08 tv emby-server[2003]: #011/lib/x86_64-linux-gnu/libc.so.6(+0x17edff) [0x7ff32b057dff]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/lib/emby-server/x86_64-linux-gnu/libEmbyMagickCore-6.Q8.so.2(ReadBlob+0xed) [0x7ff320c75add]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/lib/emby-server/x86_64-linux-gnu/libEmbyMagickCore-6.Q8.so.2(SetImageInfo+0x2df) [0x7ff320d2220f]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/lib/emby-server/x86_64-linux-gnu/libEmbyMagickCore-6.Q8.so.2(ReadImage+0xa1) [0x7ff320ca9c71]Jan 19 10:28:08 tv emby-server[2003]: #011/usr/lib/emby-server/x86_64-linux-gnu/libEmbyMagickWand-6.Q8.so.2(MagickReadImage+0x6a) [0x7ff32109a88a]Jan 19 10:28:08 tv emby-server[2003]: #011[0x408a7cf8]Jan 19 10:28:08 tv emby-server[2003]: Debug info from gdb:Jan 19 10:28:08 tv emby-server[2003]: =================================================================Jan 19 10:28:08 tv emby-server[2003]: Got a SIGSEGV while executing native code. This usually indicatesJan 19 10:28:08 tv emby-server[2003]: a fatal error in the mono runtime or one of the native librariesJan 19 10:28:08 tv emby-server[2003]: used by your application.Jan 19 10:28:08 tv emby-server[2003]: =================================================================Jan 19 10:28:08 tv tvheadend[1503]: htsp: xx.xx.xx.50 [ tv | TVHclient4Emby-3.2.70.0 ]: DisconnectedJan 19 10:28:08 tv systemd[1]: emby-server.service: Main process exited, code=exited, status=134/n/aJan 19 10:28:08 tv systemd[1]: Stopping User Manager for UID 999...Jan 19 10:28:08 tv systemd[2031]: Stopped target Default.Jan 19 10:28:08 tv systemd[2031]: Stopped target Basic System.Jan 19 10:28:08 tv systemd[2031]: Stopped target Sockets.Jan 19 10:28:08 tv systemd[2031]: Stopped target Paths.Jan 19 10:28:08 tv systemd[2031]: Reached target Shutdown.Jan 19 10:28:08 tv systemd[2031]: Starting Exit the Session...Jan 19 10:28:08 tv systemd[2031]: Stopped target Timers.Jan 19 10:28:08 tv systemd[2031]: Received SIGRTMIN+24 from PID 2098 (kill).Jan 19 10:28:08 tv systemd[1]: emby-server.service: Unit entered failed state.Jan 19 10:28:08 tv systemd[1]: emby-server.service: Failed with result 'exit-code'.Jan 19 10:28:08 tv systemd[1]: Stopped User Manager for UID 999.Jan 19 10:28:08 tv systemd[1]: Removed slice User Slice of emby.Jan 19 10:29:03 tv systemd[1]: Starting Cleanup of Temporary Directories...Jan 19 10:29:03 tv systemd-tmpfiles[2124]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path "/var/log", ignoring.Jan 19 10:29:03 tv systemd[1]: Started Cleanup of Temporary Directories.``` will only stay started for a few seconds. ```● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled; vendor preset: enabled)Active: failed (Result: exit-code) since Fri 2018-01-19 10:33:33 CST; 9s agoProcess: 2291 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS)Process: 2214 ExecStart=/usr/bin/emby-server start (code=exited, status=134)Main PID: 2214 (code=exited, status=134)CPU: 58msJan 19 10:31:37 tv systemd[1]: Started Emby Media Server.Jan 19 10:31:37 tv su[2214]: Successful su for emby by rootJan 19 10:31:37 tv su[2214]: + ??? root:embyJan 19 10:31:37 tv su[2214]: pam_unix(su:session): session opened for user emby by (uid=0)Jan 19 10:33:33 tv systemd[1]: emby-server.service: Main process exited, code=exited, status=134/n/aJan 19 10:33:33 tv systemd[1]: emby-server.service: Unit entered failed state.Jan 19 10:33:33 tv systemd[1]: emby-server.service: Failed with result 'exit-code'.```
Luke 42243 Posted January 19, 2018 Author Posted January 19, 2018 Can you please attach the emby server log? thanks.
hooray4me 52 Posted January 20, 2018 Posted January 20, 2018 :/ The logs truncated when I downgraded to the .60 release... I recall it complaining about mono
Luke 42243 Posted January 22, 2018 Author Posted January 22, 2018 Just a heads up to anyone running an Emby Server beta package from OBS. In the next week or two we will be retiring the OBS beta channel. Our website download page has been updated with beta install instructions: https://emby.media/download At your convenience it is recommended that you switch over to the new installation process as we will no longer be publishing betas to OBS. If you're running a non-beta (stable) package from OBS, you can continue to do so for the time being. Thanks !
hooray4me 52 Posted January 25, 2018 Posted January 25, 2018 We have a new unique setup that we are having some problems with... we recently added a new storage server with high-speed storage and 10Gig nic connectivity to our infrastructure. We also added a 10gig nic to the emby-server. The emby shares for TV and Movies now connect over cifs shares to the new storage server. The emby server connectivity is: Not bound to any specific ip address… 1 nic with default gateway in the DMZ (primary PUBLIC access to emby) 1 nic to 10gig storage network, no gateway, static routes 1 nic to internal network, no gateway, static routes A. When we join an emby client to the server via an internal client to the internal ip address, the “auto-conifg” of the emby server address changes to the 10gig nic ip address after a reboot. B. When an android tablet is added via the internal ip address and content is locally synced, once it leaves the local subnet it cannot connect via the programmed public ssl url . Thoughts?
Luke 42243 Posted January 25, 2018 Author Posted January 25, 2018 @@robrhedrick, what kind of ssl cert do you have?
hooray4me 52 Posted January 25, 2018 Posted January 25, 2018 Also, there is a mix of kodi boxes and firesticks on the internal subnet that automatically see the emby server, after they connect, they show one of the other ip addresses as the "server" address... like the 10g nic ip, which they cannot access.
Turboschnecke 2 Posted February 1, 2018 Posted February 1, 2018 (edited) Yesterday i installed the latest stable version of emby on Ubuntu 17.10 and it worked. Today emby always crash, when i try to login in the dashboard... Status always returns failed (code=killed,signal=ILL). How can i solve this problem? The log file dont provide much infos. Just this HTTP GET http://IP:8096/emby/Users/7790daac6e374b90812d9eb1144dcbb/Views and a UserAgent. But then it ends Edited February 1, 2018 by Turboschnecke
Luke 42243 Posted February 1, 2018 Author Posted February 1, 2018 @@Turboschnecke, please attach the complete emby server log, thanks.
darrenkdean 31 Posted February 5, 2018 Posted February 5, 2018 Updated to Emby Server 3.2.70.0 yesterday AM. Remote firesticks had choppy/freezing playback so I decided to downgrade back to 3.2.60.0 Library did not want to update after downgrade, so a previous configuration prior to the upgrade was restored using the Backup Plugin Libraries are now updated & functioning again, but when I click on Live TV it just spins When I look at the logs I keep seeing this error: Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6'2018-02-04 19:49:43.828 I've tried uninstalling the TV Headend Plugin, Downgrading It, etc. etc., but can't seem to figure it out. The Plugin configuration settings are correct (username/password). The TV Headend Server is hosted on the same machine as the Emby Server. Any thoughts? Best- Darren Log.txt
Luke 42243 Posted February 5, 2018 Author Posted February 5, 2018 I'm not sure. I think you will need to post in the Tv Headend section. Thanks.
iwm 0 Posted February 5, 2018 Posted February 5, 2018 I have tried to update to the latest beta but get the following problems sudo service emby-server stop emby-server stop/waiting iwm@xxxxx1 ~/Desktop $ sudo dpkg -i emby-server-deb_3.2.70.10_amd64.deb (Reading database ... 241587 files and directories currently installed.) Preparing to unpack emby-server-deb_3.2.70.10_amd64.deb ... stop: Unknown instance: Unpacking emby-server (3.2.70.10) over (3.2.70.5) ... dpkg: error processing archive emby-server-deb_3.2.70.10_amd64.deb (--install): unable to open '/opt/emby-server/share/icu/59.1/icudt59l/ibm-942_P12A-1999.cnv.dpkg-new': Operation not permitted Processing triggers for libc-bin (2.19-0ubuntu6.14) ... Processing triggers for ureadahead (0.100.0-16) ... Errors were encountered while processing: emby-server-deb_3.2.70.10_amd64.deb I am running RELEASE=17.3 CODENAME=rosa EDITION="MATE 64-bit" DESCRIPTION="Linux Mint 17.3 Rosa" DESKTOP=MATE TOOLKIT=GTK GRUB_TITLE=Linux Mint 17.3 MATE 64-bit Cheers IanM
iwm 0 Posted February 5, 2018 Posted February 5, 2018 By the way Version 3.2.70.5 is working really well so maybe I should not fix it. Cheers IanM
Luke 42243 Posted February 5, 2018 Author Posted February 5, 2018 @@iwm, you could try deleting this file and then updating again: /opt/emby-server/share/icu/59.1/icudt59l/ibm-942_P12A-1999.cnv.dpkg-new
iwm 0 Posted February 7, 2018 Posted February 7, 2018 @@iwm, you could try deleting this file and then updating again: /opt/emby-server/share/icu/59.1/icudt59l/ibm-942_P12A-1999.cnv.dpkg-new Tried again that with following result iwm@xxxx1 ~/Downloads $ ls emby-server-deb_3.2.70.11_amd64.deb iwm@xxxx1 ~/Downloads $ sudo dpkg -i emby-server-deb_3.2.70.11_amd64.deb (Reading database ... 241587 files and directories currently installed.) Preparing to unpack emby-server-deb_3.2.70.11_amd64.deb ... emby-server stop/waiting Unpacking emby-server (3.2.70.11) over (3.2.70.5) ... dpkg: error processing archive emby-server-deb_3.2.70.11_amd64.deb (--install): unable to open '/opt/emby-server/share/icu/59.1/icudt59l/unit/sw.res.dpkg-new': Operation not permitted Processing triggers for libc-bin (2.19-0ubuntu6.14) ... Processing triggers for ureadahead (0.100.0-16) ... ureadahead will be reprofiled on next reboot Errors were encountered while processing: emby-server-deb_3.2.70.11_amd64.deb iwm@xxxx1 ~/Downloads $ sudo rm /opt/emby-server/share/icu/59.1/icudt59l/unit/sw.res.dpkg-new rm: cannot remove ‘/opt/emby-server/share/icu/59.1/icudt59l/unit/sw.res.dpkg-new’: No such file or directory Then I tried the install again Sorry that didn't work - Maybe I will backup settings for server and do a new install Cheers IanM
alucryd 318 Posted February 7, 2018 Posted February 7, 2018 I couldn't reproduce. Could you try uninstalling the previous package before installing the latest one?
AlpBen 0 Posted February 24, 2018 Posted February 24, 2018 Hello, my emby server runs on Ubuntu 16.04 and it says there was an update to 3.3.0.0, but when I try apt dist-upgrade it does not update. Repo not yet updated? I should be more patient? ;-)
Luke 42243 Posted February 24, 2018 Author Posted February 24, 2018 Hello, my emby server runs on Ubuntu 16.04 and it says there was an update to 3.3.0.0, but when I try apt dist-upgrade it does not update. Repo not yet updated? I should be more patient? ;-) @@AlpBen, how did you originally install?
AlpBen 0 Posted February 25, 2018 Posted February 25, 2018 @@Luke Oh my, you are right. I downloaded it manually.... Sorry for the inconvienience. Thank you very much for your help
neik 874 Posted February 27, 2018 Posted February 27, 2018 (edited) After upgrading from 3.2.70 to 3.3.0.0 Emby won't start anymore. I downloaded the .deb file and unpacked it via dpkg (as stated in the official download page for Ubuntu on emby.media) but since then I haven't been able to get Emby started. When I enter "service emby-server start" I can see the process "EmbyServer" in top but after a few moments it goes away and I am not able to access the WebInterface at all. Would like to a debug log but without WebInterface I do not really know how to do so. Would it be possible to do a downgrade back to 3.2.70? I am kinda lost over here, any hint would be appreciated. Thanks a lot! €dit: My bad! Had to access it via http instead of https because the folder in /var/lib was renamed from emby-server to just emby. This led to emby not finding my certificate anymore. €dit2: Nevertheless, there is a problem in the main page of the WebInterface. Emby does not load all the images anymore. See screenshot: Is it related to the renamed folder? Is a library rescan required to solve this? €dit3: There is yet an other problem. I use Kodi + Emby for Kodi on a FTVS which worked flawlessly before the update to 3.3.0.0. Now I have to disable Check host-ssl certificate (or similar) in the settings otherwise it does not log in to the server and I don't know why. No changes were made to the certificate. Edited February 27, 2018 by neik
Luke 42243 Posted February 27, 2018 Author Posted February 27, 2018 Have you tried running a library scan?
neik 874 Posted February 27, 2018 Posted February 27, 2018 (edited) No, actually I have not. Should I replace all metadata or just scan for new files? What about the certificate issue? Edited February 27, 2018 by neik
