clarkss12 304 Posted May 26, 2017 Posted May 26, 2017 (edited) On my FreeNas server Sorry, I missed the FreeNas. I am a total noob at Linux, but after a few months of pure agony, trying to do what you are asking. I created a cheat to help me mount my folders from two different NAS's, one, NFS and one smb. Here is my cheat sheet, maybe it will help. You will have to figure out your music folder location on your FreeNas, and then on your Linux box create the necessary folders and give them permissions. Then enter that data into fstab. I works for me, I am always adding different versions of Linux and with my cheat sheet, I can have a system up and running in a few minutes.. AGAIN, I AM A TOTAL NOOB. Real Linux gurus will be probably be shaking their heads..... mounting nas on pine64.txt Here is a video showing how I mount my external drives on Linux. Don't laugh, it works for me. https://www.youtube.com/watch?v=nwa1tH8ju7Q Edited May 26, 2017 by clarkss12
avalon65 2 Posted May 27, 2017 Posted May 27, 2017 (edited) From the FreeNAS forum : So you need to create a dataset on your FreeNAS server where you will store your media files; it seems you've already done this. Then share this dataset as an NFS share (Sharing->UNIX(NFS) in the GUI). On your emby server -- your laptop? -- you will then mount the share so that the emby package can access it to serve up your media. I have added a UNIX share in FreeNAS, and then added the path of the Media folder in emby, : /mnt/WinShare/Media?music, but I am getting an error: ' There was an error adding the media path. Please ensure the path is valid and the Emby Server process has access to it. I have also entered the same path as a (Optional) Shared Network Folder, but still get the same error What have I missed or not done. Edited May 27, 2017 by avalon65
mastrmind11 722 Posted May 28, 2017 Posted May 28, 2017 From the FreeNAS forum : So you need to create a dataset on your FreeNAS server where you will store your media files; it seems you've already done this. Then share this dataset as an NFS share (Sharing->UNIX(NFS) in the GUI). On your emby server -- your laptop? -- you will then mount the share so that the emby package can access it to serve up your media. I have added a UNIX share in FreeNAS, and then added the path of the Media folder in emby, : /mnt/WinShare/Media?music, but I am getting an error: ' There was an error adding the media path. Please ensure the path is valid and the Emby Server process has access to it. I have also entered the same path as a (Optional) Shared Network Folder, but still get the same error What have I missed or not done. Why is there a question mark in your path?
avalon65 2 Posted May 28, 2017 Posted May 28, 2017 Why is there a question mark in your path? oops, It was a typo error here in my message and not in emby server path for the media. I have just checked.
mastrmind11 722 Posted May 28, 2017 Posted May 28, 2017 (edited) oops, It was a typo error here in my message and not in emby server path for the media. I have just checked. I think you're getting confused. All you did above was set up a NFS share of your music folder. Now you need to add *that* share by mounting it wherever you have Emby server running. In this case, I believe that'd be your laptop. Once you mount the share on your laptop, you can then point Emby to the local mountpoint.... ie, once it's mounted it mimics a regular local folder that you can access just like any other folder on your laptop. You'll need to install nfs-common on your laptop: sudo apt-get install nfs-common Then you'll need to simply mount the share by creating a local directory: mkdir /mnt/whatever/you/want Then it's just a matter of mounting the share and pointing it to the folder you just created: sudo mount your_freenas_ip:/mnt/WinShare/Media/music /mnt/whatever/you/want Once that's executed, you should be able to list the contents of the mountpoint: ls -lh /mnt/whatever/you/want Assuming that worked, go into Emby and point the library to /mnt/whatever/you/want Assuming you don't want to mount the share every time you restart your laptop, you'll need to edit the /etc/fstab file sudo nano /etc/fstab and add a line to permanently mount the share each reboot: your_freenas_ip:/mnt/WinShare/Media/music /mnt/whatever/you/want nfs auto,nofail,noatime,nolock,intr,tcp,actimeo=1800 0 0 And that's it. You'll probably come back asking about permissioning, but we can figure that out if you do. Edited May 28, 2017 by mastrmind11
avalon65 2 Posted May 28, 2017 Posted May 28, 2017 (edited) I think you're getting confused. All you did above was set up a NFS share of your music folder. Now you need to add *that* share by mounting it wherever you have Emby server running. In this case, I believe that'd be your laptop. Once you mount the share on your laptop, you can then point Emby to the local mountpoint.... ie, once it's mounted it mimics a regular local folder that you can access just like any other folder on your laptop. You'll need to install nfs-common on your laptop: sudo apt-get install nfs-common Then you'll need to simply mount the share by creating a local directory: mkdir /mnt/whatever/you/want Then it's just a matter of mounting the share and pointing it to the folder you just created: sudo mount your_freenas_ip:/mnt/WinShare/Media/music /mnt/whatever/you/want Once that's executed, you should be able to list the contents of the mountpoint: ls -lh /mnt/whatever/you/want Assuming that worked, go into Emby and point the library to /mnt/whatever/you/want Assuming you don't want to mount the share every time you restart your laptop, you'll need to edit the /etc/fstab file sudo nano /etc/fstab and add a line to permanently mount the share each reboot: your_freenas_ip:/mnt/WinShare/Media/music /mnt/whatever/you/want nfs auto,nofail,noatime,nolock,intr,tcp,actimeo=1800 0 0 And that's it. You'll probably come back asking about permissioning, but we can figure that out if you do. Yes that is the next question as access is denied by server while mounting ip address of server. The Music folder is now showing in emby server as /mnt/WinShare/Media/Music, but there are no files there at the moment. It looks like I am getting somewhere now. Edited May 28, 2017 by avalon65
avalon65 2 Posted May 31, 2017 Posted May 31, 2017 Just to say thanks, as I finally managed to get things working correctly now. I tried this again: sudo mount your_freenas_ip:/mnt/WinShare/Media/music /mnt/whatever/you/want, and it completed without the error I received before. Then after completing the rest of your instructions, the music folder on Ubuntu is now showing tracks, and emby has loaded all the files. Again, many thanks for your help with this.
David69220 0 Posted June 14, 2017 Posted June 14, 2017 Hi, I installed emby-server in Ubuntu 16.04, and it don't start. emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2017-06-14 12:25:33 CEST; 1h 33min ago Process: 23107 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 23082 ExecStart=/usr/bin/emby-server start (code=exited, status=1/FAILURE) Main PID: 23082 (code=exited, status=1/FAILURE) Jun 14 12:25:29 Arcadia systemd[1]: Started Emby Media Server.Jun 14 12:25:31 Arcadia su[23082]: Successful su for emby by rootJun 14 12:25:31 Arcadia su[23082]: + ??? root:embyJun 14 12:25:31 Arcadia su[23082]: pam_unix(su:session): session opened for user emby by (uid=0)Jun 14 12:25:31 Arcadia systemd[1]: emby-server.service: Main process exited, code=exited, status=1/FAILUREJun 14 12:25:33 Arcadia systemd[1]: emby-server.service: Unit entered failed state.Jun 14 12:25:33 Arcadia systemd[1]: emby-server.service: Failed with result 'exit-code'. When I try to use : sudo /usr/bin/emby-server start Unhandled Exception: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods:sqlite3_libversion_number () at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <1dfac022a6f2490eb616d7759415c871>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00008] in <6725949973104bb8b8bdf05801db616a>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <b891ce5b60df4267bab17c7ac8783d69>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00012] in <b891ce5b60df4267bab17c7ac8783d69>:0 [ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: libembysqlite3.so.0 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_sqlite3+NativeMethods:sqlite3_libversion_number () at SQLitePCL.SQLite3Provider_sqlite3.SQLitePCL.ISQLite3Provider.sqlite3_libversion_number () [0x00000] in <1dfac022a6f2490eb616d7759415c871>:0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00008] in <6725949973104bb8b8bdf05801db616a>:0 at MediaBrowser.Server.Mono.MainClass.SetSqliteProvider () [0x00005] in <b891ce5b60df4267bab17c7ac8783d69>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00012] in <b891ce5b60df4267bab17c7ac8783d69>:0 What is this issue please ? Thanks. David.
hurricanehrndz 149 Posted June 14, 2017 Posted June 14, 2017 There seems to have been an issue with your installation, please verify the following: Files exist: /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so.0 /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so.0.8.6 /usr/lib/emby-server/bin/SQLitePCLRaw.provider.sqlite3.dll.config Verify the contents of the config file <configuration> <dllmap dll="sqlite3" target="libembysqlite3.so.0" os="linux"/> <dllmap dll="dl" target="libdl.so.2" os="linux"/> </configuration>
David69220 0 Posted June 14, 2017 Posted June 14, 2017 Hello, I don't have the files. I don't have the directory x86_64-linux-gnu David
Daniel Snow 0 Posted June 15, 2017 Posted June 15, 2017 Hi everyone! I'm going to use Emby for slideshows via Chromecast, however the default speed of slide changing is a bit fast. I couldn't find any even setting. Someone knows how speed of slide's changing may be configured? Any server parameter or something else, even hard way to build from sources with needed speed value? Thanks!
Luke 42243 Posted June 15, 2017 Author Posted June 15, 2017 We don't currently have a setting but how much slower do you think it should be?
Daniel Snow 0 Posted June 15, 2017 Posted June 15, 2017 (edited) Hi Luke, I think 10-15 seconds should be enough. As for me, 12 s will be cool. Other installations that can work with Chromecast also don't have such option, here a lot of desperate people asking for implement slideshow speed control: https://forums.plex.tv/discussion/213680/why-is-there-no-way-to-control-the-photo-slideshow-speed https://forums.plex.tv/discussion/251289/slideshow-settings-speed https://forums.plex.tv/discussion/174250/can-you-configure-the-photo-slideshow I think if you'll implement such feature or just slightly decrease the slideshow speed, all these people will go to Emby side : ) Edited June 15, 2017 by Daniel Snow
Luke 42243 Posted June 15, 2017 Author Posted June 15, 2017 For now I will just increase it by a few seconds because the current 8 seconds is probably a little too quick. 1
Daniel Snow 0 Posted June 15, 2017 Posted June 15, 2017 Great! May you tell please in which branch and version improvement will appear?
David69220 0 Posted June 20, 2017 Posted June 20, 2017 There seems to have been an issue with your installation, please verify the following: Files exist: /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so.0 /usr/lib/emby-server/x86_64-linux-gnu/libembysqlite3.so.0.8.6 /usr/lib/emby-server/bin/SQLitePCLRaw.provider.sqlite3.dll.config Verify the contents of the config file <configuration> <dllmap dll="sqlite3" target="libembysqlite3.so.0" os="linux"/> <dllmap dll="dl" target="libdl.so.2" os="linux"/> </configuration> Hello, Nobody to help me ? I don't have the directory x86_64-linux-gnu in /usr/lib/emby-server/ David
hurricanehrndz 149 Posted June 20, 2017 Posted June 20, 2017 How did you install Sent from my ONEPLUS A3000 using Tapatalk
David69220 0 Posted June 20, 2017 Posted June 20, 2017 (edited) Like this: For xUbuntu 16.04 run the following: sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/ /' > /etc/apt/sources.list.d/emby-server.list"sudo apt-get updatesudo apt-get install emby-server Do you need more detail ? Thanks in advance. Edited June 21, 2017 by David69220
thatoneguy99 33 Posted June 23, 2017 Posted June 23, 2017 (edited) What do you see when you type "sqlite3 --version" into terminal ? Sent from my phone! Edited June 23, 2017 by thatoneguy99
David69220 0 Posted June 23, 2017 Posted June 23, 2017 This is the version 3.11.0 2016-02-15 17:29:24 3d862f207e3adc00f78066799ac5a8c282430a5f
thatoneguy99 33 Posted June 23, 2017 Posted June 23, 2017 (edited) That is the same version I have. You didn't see any errors during the install? Maybe try "sudo apt-get remove --purge emby-server" then try to reinstall. I have the folder you're missing inside of /usr/lib/emby-server which makes me think something didn't happen right during install. Sent from my phone! Edited June 23, 2017 by thatoneguy99
David69220 0 Posted June 23, 2017 Posted June 23, 2017 (edited) I removed with purge and reinstalled... Always the same issue. Never mind, I stop now. Edited June 23, 2017 by David69220
thatoneguy99 33 Posted June 23, 2017 Posted June 23, 2017 Sorry about your luck. I did not have these problems. Maybe someone will come along with an answer.
