hurricanehrndz 149 Posted February 21, 2017 Posted February 21, 2017 I use: https://packagecloud.io/gyazo/gyazo-for-linux/ubuntu https://deb.opera.com/opera-stable and some from ppa.launchpad.net, for example http://ppa.launchpad.net/noobslab/themes/ubuntu So I tried with the 16.10 repo and get the same issue: Ign:12 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 InRelease Get:13 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release [1,009 B] Err:14 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] Get:15 http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Packages [35.9 kB] Fetched 36.9 kB in 6s (5,483 B/s) Reading package lists... Done W: The repository 'http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10 Release' is not signed. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. E: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.10/Release.gpg Bad header line Bad header data [IP: 195.135.221.134 80] E: Some index files failed to download. They have been ignored, or old ones used instead. Interesting. Well I would suggest you try a vpn and see if the results are the same.
Driesner 0 Posted February 22, 2017 Posted February 22, 2017 I am pretty much frustrated but at least I got emby-server now installed... So I installed VPN One Click and tried again... and it just worked while the vpn was active. I really wouldnt have thought that they mess so bad with our data here to make real standard stuff like downloading from a signed repo fails Thanks for your help and I got it now!
hurricanehrndz 149 Posted February 22, 2017 Posted February 22, 2017 Cool, glad to hear it worked. Sent from my ONEPLUS A3000 using Tapatalk
avalon65 2 Posted March 1, 2017 Posted March 1, 2017 (edited) I have emby server just installed in Ubuntu 16.04, and have it started, but I cannot add a media folder in the setup. Emby sees a network in or under Folder, but that is all, nothing else. I then tried this : \\freenas\WinShare\Media\music, but emby couldn't either see or find it. I've also tried by IP address, but still no luck I can see the media folder from files in Ubuntu when I connect to the smb server, and have tried: smb://freenas/winShare/Media/music, but that doesn't work either. What have I missed. Edited March 1, 2017 by avalon65
Luke 42243 Posted March 1, 2017 Author Posted March 1, 2017 I have emby server just installed in Ubuntu 16.04, and have it started, but I cannot add a media folder in the setup. Emby sees a network in or under Folder, but that is all, nothing else. I then tried this : \\freenas\WinShare\Media\music, but emby couldn't either see or find it. I've also tried by IP address, but still no luck I can see the media folder from files in Ubuntu when I connect to the smb server, and have tried: smb://freenas/winShare/Media/music, but that doesn't work either. What have I missed. @@avalon65, the mono runtime does not support unc shares, so you need to first mount the network path as a local path in Ubuntu, then use that local path in Emby.
Sphno1 1 Posted March 3, 2017 Posted March 3, 2017 Any advice on installing emby server on pi 3 I have nothing but problems and I'm getting fed up now first I tried debian no luck constantly failing on dependencies. So I installed ubuntu 16.04 instead now I'm a step closer and it seems to just be sqlite3 which is causing me the most trouble to get hold of. I've tried a few different approaches. I don't know Wether this is due to newer updates but I am having no luck and am about ready to give up with this project now. Regards
thatoneguy99 33 Posted March 3, 2017 Posted March 3, 2017 Give this a shot for your SQLite problems. Not sure how it will go but it fixed a previous error I had with something else somewhere else. sudo apt-get install sqlite3 libsqlite3-dev Sent from my phone!
Luke 42243 Posted March 3, 2017 Author Posted March 3, 2017 Any advice on installing emby server on pi 3 I have nothing but problems and I'm getting fed up now first I tried debian no luck constantly failing on dependencies. So I installed ubuntu 16.04 instead now I'm a step closer and it seems to just be sqlite3 which is causing me the most trouble to get hold of. I've tried a few different approaches. I don't know Wether this is due to newer updates but I am having no luck and am about ready to give up with this project now. Regards @@Sphno1 have you looked here? https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/
Sphno1 1 Posted March 3, 2017 Posted March 3, 2017 (edited) @@Sphno1 have you looked here? https://emby.media/community/index.php?/topic/43166-arm-devices-official-instructions/ Yeah I did a combination of this and a tutorial I found online nearly all set up just struggling to transfer my emby premier account it doesn't seem to register after I save my key. Is there a way to get the key reset or is it an issue with the new firmware. Regards Edited March 3, 2017 by Sphno1
Luke 42243 Posted March 3, 2017 Author Posted March 3, 2017 Yeah I did a combination of this and a tutorial I found online nearly all set up just struggling to transfer my emby premier account it doesn't seem to register after I save my key. Is there a way to get the key reset or is it an issue with the new firmware. Regards Can you please provide the Emby server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
epia125 0 Posted March 8, 2017 Posted March 8, 2017 (edited) I have emby server just installed in Ubuntu 16.04, and have it started, but I cannot add a media folder in the setup. Emby will list the parent folder with the media I want to share, but clicking on it does nothing, i.e. it doesn't show subfolders and blanks out the path. I tried manually inputting the location: /share/tv, but receive the error message; "There was an error adding the media path. Please ensure the path is valid and the Emby Server process has access to that location." Doing some research I see that Emby has its own user/group. I changed the permissions for "/share/tv" to chown -R emby:emby and chmod 775 giving emby:emby read/write/execute. I go back through the setup and emby still won't let me navigate to the subfolder /tv under /share. Manually inputting the path yields the same result as before. I should note that this location is pooled via mergerFS, does Emby support pooled storage? My next attempt is to change the user and group of Emby to my current user/group for those locations and see if that works. Edited March 8, 2017 by epia125
freezy 2 Posted March 15, 2017 Posted March 15, 2017 Hi, since 3.2.7.1 I'm not getting any beta updates for xUbuntu_16.10 through apt anymore. Seems the last version is indeed 3.2.7.1. Since there was a regression recently for poster updates, I'd like to test with the latest beta first before filing a bug report. Thanks.
Luke 42243 Posted March 15, 2017 Author Posted March 15, 2017 @@freezy what regression for poster updates? Both tvdb and Omdb have been having sporadic outages, but that is not an Emby regression and won't change with the Emby version.
freezy 2 Posted March 15, 2017 Posted March 15, 2017 @@Luke no, it's not an outage. For some movies, when selecting a new poster, Emby just hangs with the progress bar. Refreshing will result in the new poster, but restarting Emby reverts back to the old one. I've also tried manually uploading a new poster with the same result. I'll open a GitHub issue about it with the log and steps how to reproduce. However while I see 3.2.7.5 at the Opensuse repo, apt update doesn't seem to fetch the update.
Luke 42243 Posted March 15, 2017 Author Posted March 15, 2017 Right, and that's fine, it's important to provide detailed information by consulting how to report a problem. thanks !
freezy 2 Posted March 15, 2017 Posted March 15, 2017 So apt is going to be fine? Or it's fine now? Not sure how to interpret your answer.
Luke 42243 Posted March 15, 2017 Author Posted March 15, 2017 I've posted 3.2.8 stable. It is strictly a version increment to correct the tagging mistake. We are currently working on a new build system. Apologies for the disruption. Thanks. 1
leezy 1 Posted April 8, 2017 Posted April 8, 2017 I cannot get my emby server to update. My dashboard currently states I am on Version 3.2.12.0 beta and there is an update available for 3.2.12.1. I've tried sudo apt-get update and sudo apt-get install commands but terminal says I'm on the latest release even though the dashboard states differently. I also want my server to stay on and get updates only for stable releases. Any suggestions?
Luke 42243 Posted April 8, 2017 Author Posted April 8, 2017 I cannot get my emby server to update. My dashboard currently states I am on Version 3.2.12.0 beta and there is an update available for 3.2.12.1. I've tried sudo apt-get update and sudo apt-get install commands but terminal says I'm on the latest release even though the dashboard states differently. I also want my server to stay on and get updates only for stable releases. Any suggestions? We are looking into it, thanks.
SkyBehind 23 Posted April 8, 2017 Posted April 8, 2017 I cannot get my emby server to update. My dashboard currently states I am on Version 3.2.12.0 beta and there is an update available for 3.2.12.1. I've tried sudo apt-get update and sudo apt-get install commands but terminal says I'm on the latest release even though the dashboard states differently. I also want my server to stay on and get updates only for stable releases. Any suggestions? Same
schmitty 66 Posted April 19, 2017 Posted April 19, 2017 (edited) Hi, I've just set up an Ubuntu 17.04 VM using Hyper-V in Windows 10. I would like to know if there is a way to install Emby Server to the /srv path, rather than the default, as it is a separate partition. Edited April 19, 2017 by schmitty
Mokhless 0 Posted April 20, 2017 Posted April 20, 2017 Hi, How can open emby-server database (file .db) , i try with DB browser but it's display in binary. Please Help Me. Thanks
zigzagtshirt 55 Posted April 20, 2017 Posted April 20, 2017 (edited) @@leezy @@SkyBehind Does it still not update after running the following?: apt-get update apt-get dist-upgrade Edited April 20, 2017 by zigzagtshirt
Luke 42243 Posted April 20, 2017 Author Posted April 20, 2017 Hi, How can open emby-server database (file .db) , i try with DB browser but it's display in binary. Please Help Me. Thanks @@Mokhless what exactly are you trying to do?
SkyBehind 23 Posted April 21, 2017 Posted April 21, 2017 @@leezy @@SkyBehind Does it still not update after running the following?: apt-get update apt-get dist-upgrade It didn't before, but it's been fixed now.
