hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 Please post the script that is reference in the error Sent from my ONE E1005 using Tapatalk
Luticus 13 Posted September 10, 2016 Posted September 10, 2016 For anyone on Debian and/or ubuntu maybe with a broken install after the update, I went to /var/lib/dpkg/info and did a "sudo mv emby-server.prerm ~" then I did "sudo dpkg -i /var/cache/apt/archives/emby-server_3.0.7000-69.1_all.deb" which let me roll back and fix the now broken install. Haven't tried upgrading since moving the file. Will wait until the Dev's unbrick it.
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 For anyone on Debian and/or ubuntu maybe with a broken install after the update, I went to /var/lib/dpkg/info and did a "sudo mv emby-server.prerm ~" then I did "sudo dpkg -i /var/cache/apt/archives/emby-server_3.0.7000-69.1_all.deb" which let me roll back and fix the now broken install. Haven't tried upgrading since moving the file. Will wait until the Dev's unbrick it.Thank you. Sent from my ONE E1005 using Tapatalk
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 I will try and fix the script soon. Unfortunately I'm away at a wedding this weekend Sent from my ONE E1005 using Tapatalk
matty87a 8 Posted September 11, 2016 Posted September 11, 2016 for anyone else seeing this another post has the resolution: In /var/lib/dpkg/info/emby-server.prerm, line 26 reads: deb-systemd-invoke stop ${NAME}.service > 2>&1 /dev/null when it should be: deb-systemd-invoke stop ${NAME}.service 2>&1 /dev/null After making these changes I am able to upgrade.
hurricanehrndz 149 Posted September 12, 2016 Posted September 12, 2016 for anyone else seeing this another post has the resolution: Issue should be resolved in next build.
Delphi 83 Posted September 17, 2016 Posted September 17, 2016 (edited) Emby crashing constantly after .7100 update, journalctl has no logs for emby-server.service. How can I track down the cause of the crashes? EDIT: from systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset Active: failed (Result: exit-code) since Fri 2016-09-16 18:28:45 MDT; 9min ago Process: 17978 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SU Process: 17851 ExecStart=/usr/bin/emby-server start (code=exited, status=134) Main PID: 17851 (code=exited, status=134 Edited September 17, 2016 by Delphi
Luke 42243 Posted September 17, 2016 Author Posted September 17, 2016 Emby crashing constantly after .7100 update, journalctl has no logs for emby-server.service. How can I track down the cause of the crashes? EDIT: from systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset Active: failed (Result: exit-code) since Fri 2016-09-16 18:28:45 MDT; 9min ago Process: 17978 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SU Process: 17851 ExecStart=/usr/bin/emby-server start (code=exited, status=134) Main PID: 17851 (code=exited, status=134 How far are you getting? How long does it stay up?
Luke 42243 Posted September 17, 2016 Author Posted September 17, 2016 Can you offer any more detail besides that? Perhaps some sort of discussion of what you are seeing, not seeing, what you're able to do, not able to do, etc. Thanks.
jant90 15 Posted October 3, 2016 Posted October 3, 2016 Is there an issue with the Ubuntu repo or something? I can't update Emby via apt anymore. I'm running Emby Server 3.0.7200.0 on Ubuntu Server 16.04 and my server dashboard reports that a new version is available (7300) but apt won't upgrade Emby. After running apt update I tried to install the latest Emby server: ~$ sudo apt install emby-server Reading package lists... Done Building dependency tree Reading state information... Done emby-server is already the newest version (3.1.6106.19259~dev-76.1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Why is apt reporting such a strange version? And how do I fix this properly? I also tried simulating a reinstall but I don't know if that will reset all Emby's settings but that fails as well: ~$ sudo apt -s --reinstall install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Reinstallation of emby-server is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
hurricanehrndz 149 Posted October 3, 2016 Posted October 3, 2016 There was probably an issue with tagging. I will try an reissue a release thank you. Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted October 3, 2016 Posted October 3, 2016 Is there an issue with the Ubuntu repo or something? I can't update Emby via apt anymore. I'm running Emby Server 3.0.7200.0 on Ubuntu Server 16.04 and my server dashboard reports that a new version is available (7300) but apt won't upgrade Emby. After running apt update I tried to install the latest Emby server: ~$ sudo apt install emby-server Reading package lists... Done Building dependency tree Reading state information... Done emby-server is already the newest version (3.1.6106.19259~dev-76.1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Why is apt reporting such a strange version? And how do I fix this properly? I also tried simulating a reinstall but I don't know if that will reset all Emby's settings but that fails as well: ~$ sudo apt -s --reinstall install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Reinstallation of emby-server is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. It seems like you somehow installed a dev version, there was an issue with tagging earlier on in the month. Please look at the following in order to downgrade the version: http://askubuntu.com/questions/138284/how-to-downgrade-a-package-via-apt-get 1
jant90 15 Posted October 4, 2016 Posted October 4, 2016 So I am running version 7200 but it was incorrectly tagged as a dev version? This shows up in the logs for example: Version: 3.0.7200.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.0.38 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.4.2 (Stable 4.4.2.11/f72fe45 Tue Aug 30 16:43:57 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe And the dashboard shows me this: Can I fix this by running: $ sudo apt -s install emby-server=3.0.7300-79.1 Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be DOWNGRADED: emby-server 0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded. Inst emby-server [3.1.6106.19259~dev-76.1] (3.0.7300-79.1 home:emby:download.opensuse.org [all]) Conf emby-server (3.0.7300-79.1 home:emby:download.opensuse.org [all]) I've never used the package manager like this and I just want to make sure I won't lose any settings or anything.
hurricanehrndz 149 Posted October 4, 2016 Posted October 4, 2016 (edited) Version 3.1.6106 was accidentally tagged as stable on github. Technically yes, I'm not sure about the database. @@Luke will know the answer to that. Sent from my ONEPLUS A3000 using Tapatalk Edited October 4, 2016 by hurricanehrndz
Guest plexman Posted October 4, 2016 Posted October 4, 2016 So I am running version 7200 but it was incorrectly tagged as a dev version? This shows up in the logs for example: Version: 3.0.7200.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.4.0.38 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.4.2 (Stable 4.4.2.11/f72fe45 Tue Aug 30 16:43:57 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe And the dashboard shows me this: Can I fix this by running: $ sudo apt -s install emby-server=3.0.7300-79.1 Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be DOWNGRADED: emby-server 0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded. Inst emby-server [3.1.6106.19259~dev-76.1] (3.0.7300-79.1 home:emby:download.opensuse.org [all]) Conf emby-server (3.0.7300-79.1 home:emby:download.opensuse.org [all]) I've never used the package manager like this and I just want to make sure I won't lose any settings or anything. I did it and nothing happened, just upgraded my server without any problem.
hurricanehrndz 149 Posted October 4, 2016 Posted October 4, 2016 You were running a dev version of 7200. Not actually 7200 Sent from my ONEPLUS A3000 using Tapatalk
jant90 15 Posted October 4, 2016 Posted October 4, 2016 To be honest I'm confused now. Can @@Luke please confirm that I can install 7300 over my current version without database issues? Thanks!
jant90 15 Posted October 4, 2016 Posted October 4, 2016 (edited) Thanks. I ran the upgrade and it seems to running perfectly fine again. Edited October 4, 2016 by jant90
johnnyzee99 0 Posted October 13, 2016 Posted October 13, 2016 Hi All, Enby noob and just purchased yearly subscription. I'm running Ubuntu 16.04 and for the life of me I cannot upgrade the server from3.0.7200.0. I have tried all the steps and it seems not to upgrade? Is there an easy command I can try to fix this issue? Please keep me posted! John
hurricanehrndz 149 Posted October 13, 2016 Posted October 13, 2016 What steps? Sent from my ONEPLUS A3000 using Tapatalk
johnnyzee99 0 Posted October 13, 2016 Posted October 13, 2016 The steps listed on the site... sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/ /' > /etc/apt/sources.list.d/emby-server.list" sudo apt-get updatesudo apt-get install emby-server and I did this... wget http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.keysudo apt-key add - < Release.keysudo apt-get update
hurricanehrndz 149 Posted October 13, 2016 Posted October 13, 2016 Update, updates the apt caches, it doesn't update packages. Try upgrade Sent from my ONEPLUS A3000 using Tapatalk
