Luke 42243 Posted September 1, 2016 Author Posted September 1, 2016 Hi, we're looking into it, thanks. In the meantime, the mono complete workaround should work. Thanks.
forty37 0 Posted September 1, 2016 Posted September 1, 2016 It will work if you install mono-complete. Looks like a dependency was missed in the latest update. "sudo apt-get install mono-complete" I'm sure it installs more than you need, but it will work. Like a charm. Thank you so much.
forty37 0 Posted September 1, 2016 Posted September 1, 2016 Hi, we're looking into it, thanks. In the meantime, the mono complete workaround should work. Thanks. Which is why I continue to support emby - because when things break, people fix it. Thanks guys!
supermau 37 Posted September 2, 2016 Posted September 2, 2016 To upgrade or not to upgrade??? Hi, I have a server exclusively for Emby running on Ubuntu 14.04 and I am very happy with it. Should I do a Release upgrade to 16.04? On what release does Emby work better? Any opinions are greatly appreciated!!!
Luke 42243 Posted September 2, 2016 Author Posted September 2, 2016 Well for more hold off for another day or two while we work out the Ubuntu issues with the latest package 2
dlreiss 1 Posted September 9, 2016 Posted September 9, 2016 Hi, we're looking into it, thanks. In the meantime, the mono complete workaround should work. Thanks. Did not work for me. Do we have a status update on the latest package?
hurricanehrndz 149 Posted September 9, 2016 Posted September 9, 2016 (edited) Did not work for me. Do we have a status update on the latest package? There should be an update release later tonight. The mono-complete fix is only for ubuntu16.04 and it's a specific issue. Can you please provide a log. Edited September 9, 2016 by hurricanehrndz
Luke 42243 Posted September 9, 2016 Author Posted September 9, 2016 We've updated the packages. Apologies for the disruption.
SuperCurro 4 Posted September 9, 2016 Posted September 9, 2016 Tonight upgrade fail Reading package lists...Building dependency tree...Reading state information...The following packages were automatically installed and are no longer required:libmono-c5-1.1-cil libmonoboehm-2.0-1 libmonoboehm-2.0-devUse 'apt autoremove' to remove them.The following packages will be upgraded:emby-server1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.Need to get 0 B/10.6 MB of archives.After this operation, 1024 B disk space will be freed.(Reading database ...(Reading database ... 5%(Reading database ... 10%(Reading database ... 15%(Reading database ... 20%(Reading database ... 25%(Reading database ... 30%(Reading database ... 35%(Reading database ... 40%(Reading database ... 45%(Reading database ... 50%(Reading database ... 55%(Reading database ... 60%(Reading database ... 65%(Reading database ... 70%(Reading database ... 75%(Reading database ... 80%(Reading database ... 85%(Reading database ... 90%(Reading database ... 95%(Reading database ... 100%(Reading database ... 277623 files and directories currently installed.)Preparing to unpack .../emby-server_3.0.6400-67.1_all.deb ...find: '/var/run/user/1000/gvfs': Permission denieddpkg: error processing archive /var/cache/apt/archives/emby-server_3.0.6400-67.1_all.deb (--unpack):subprocess new pre-installation script returned error exit status 1Errors were encountered while processing:/var/cache/apt/archives/emby-server_3.0.6400-67.1_all.debE: Sub-process /usr/bin/dpkg returned an error code (1)
ESPINET 0 Posted September 9, 2016 Posted September 9, 2016 Any problem with ubuntu server 16.04 lts?, I copy all file into the server but this can´t played for http way. i have 230 movies and give me error for all videos. i try: apt-get update apt-get upgrade and update to mono complete, but nothing i can´t see any movie any idea
Andy777 21 Posted September 9, 2016 Posted September 9, 2016 Works fine for me (beta branch) on a new install of Ubuntu 16.04 and survived apt-get upgrade. Did: wget http://download.opensuse.org/repositories/home:emby/xUbuntu_16.04/Release.key sudo apt-key add - < Release.key sudo apt-get update sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04/ /' >> /etc/apt/sources.list.d/emby-server-beta.list" sudo apt-get update sudo apt-get install emby-server-beta sudo service emby-server start # opened web interface and configured emby sudo usermod -a -G cdrom,audio,video,plugdev,users,dialout,dip,input,netdev emby sudo service emby-server stop sudo reboot sudo apt-get update sudo apt-get upgrade sudo apt-get dist-upgrade Running without problems now for 10 minutes at least :-) 2
hurricanehrndz 149 Posted September 9, 2016 Posted September 9, 2016 Tonight upgrade failI will resolve this right away sorry. Sent from my ONE E1005 using Tapatalk
hurricanehrndz 149 Posted September 9, 2016 Posted September 9, 2016 (edited) Any problem with ubuntu server 16.04 lts?, I copy all file into the server but this can´t played for http way. i have 230 movies and give me error for all videos. i try: apt-get update apt-get upgrade and update to mono complete, but nothing i can´t see any movie any idea mono-complete issue has been resolved. I have tested an install on a clean file server and have seen no issue. Edited September 9, 2016 by hurricanehrndz
ESPINET 0 Posted September 9, 2016 Posted September 9, 2016 mono-complete issue has been resolved. I have tested an install on a clean file server and have seen no issue. ok i try within files in server. thanks
Luke 42243 Posted September 9, 2016 Author Posted September 9, 2016 Setup FFmpeg, this is new or what???? The instructions are easy, right? Looks like you're running beta. Thank you for being a part of beta testing.
dlreiss 1 Posted September 9, 2016 Posted September 9, 2016 There should be an update release later tonight. The mono-complete fix is only for ubuntu16.04 and it's a specific issue. Can you please provide a log. I'll try tonight. I'll post log if I have any issues. Thanks!
dlreiss 1 Posted September 10, 2016 Posted September 10, 2016 I'll try tonight. I'll post log if I have any issues. Thanks! Think my issues are beyond this fix. Trying to uninstall and getting this /home/darrin# sudo apt-get purge emby-server-beta Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: at libembymagickcore-6.q8-2 libembymagickwand-6.q8-2 Use 'sudo apt autoremove' to remove them. The following packages will be REMOVED: emby-server-beta* 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. After this operation, 39.7 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 371793 files and directories currently installed.) Removing emby-server-beta (3.1.143~beta-1634.1) ... /var/lib/dpkg/info/emby-server-beta.prerm: line 26: syntax error near unexpected token `2' dpkg: error processing package emby-server-beta (--remove): subprocess installed pre-removal script returned error exit status 2 Errors were encountered while processing: emby-server-beta E: Sub-process /usr/bin/dpkg returned an error code (1)
dlreiss 1 Posted September 10, 2016 Posted September 10, 2016 Ok, got past this issue. will give the fix another look Think my issues are beyond this fix. Trying to uninstall and getting this /home/darrin# sudo apt-get purge emby-server-betaReading package lists... DoneBuilding dependency tree Reading state information... DoneThe following packages were automatically installed and are no longer required: at libembymagickcore-6.q8-2 libembymagickwand-6.q8-2Use 'sudo apt autoremove' to remove them.The following packages will be REMOVED: emby-server-beta*0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.After this operation, 39.7 MB disk space will be freed.Do you want to continue? [Y/n] y(Reading database ... 371793 files and directories currently installed.)Removing emby-server-beta (3.1.143~beta-1634.1) .../var/lib/dpkg/info/emby-server-beta.prerm: line 26: syntax error near unexpected token `2'dpkg: error processing package emby-server-beta (--remove): subprocess installed pre-removal script returned error exit status 2Errors were encountered while processing: emby-server-betaE: Sub-process /usr/bin/dpkg returned an error code (1)
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 Ok, got past this issue. will give the fix another look Edit the script and remove the find line. It will proceed. Script has been fixed in new packages Sent from my ONE E1005 using Tapatalk
matty87a 8 Posted September 10, 2016 Posted September 10, 2016 Trying to upgrade from 3.0.7000.0 to 3.0.7100 and getting similar error as above: (Reading database ... 100374 files and directories currently installed.) Preparing to unpack .../emby-server_3.0.7100-71.1_all.deb ... /var/lib/dpkg/info/emby-server.prerm: line 26: syntax error near unexpected token `2' dpkg: warning: subprocess old pre-removal script returned error exit status 2 dpkg: trying script from the new package instead ... /var/lib/dpkg/tmp.ci/prerm: line 26: syntax error near unexpected token `2' dpkg: error processing archive /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb (--install): subprocess new pre-removal script returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb Have tried: sudo dpkg -i --force-overwrite /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb Still no joy, also ran apt-get clean and re-updated packages with no affect.
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 Sorry about the issue with the maintainer scripts they were edited to support systemd. I will chek it over again and ensure they are okay. During my testing these issues didn't come up. Can you pleasr post the file in the temp directory Sent from my ONE E1005 using Tapatalk
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 Everyone please hold off updating for now Sent from my ONE E1005 using Tapatalk
hurricanehrndz 149 Posted September 10, 2016 Posted September 10, 2016 Trying to upgrade from 3.0.7000.0 to 3.0.7100 and getting similar error as above: (Reading database ... 100374 files and directories currently installed.) Preparing to unpack .../emby-server_3.0.7100-71.1_all.deb ... /var/lib/dpkg/info/emby-server.prerm: line 26: syntax error near unexpected token `2' dpkg: warning: subprocess old pre-removal script returned error exit status 2 dpkg: trying script from the new package instead ... /var/lib/dpkg/tmp.ci/prerm: line 26: syntax error near unexpected token `2' dpkg: error processing archive /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb (--install): subprocess new pre-removal script returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb Have tried: sudo dpkg -i --force-overwrite /var/cache/apt/archives/emby-server_3.0.7100-71.1_all.deb Still no joy, also ran apt-get clean and re-updated packages with no affect.Can you please tell me the distro you are running? Sent from my ONE E1005 using Tapatalk
