Pixelpaule 4 Posted July 10, 2016 Posted July 10, 2016 Hey Luke, after the installation i can't Start emby. When i type "sudo service emby-server start" in the terminal nothing happens. Unfortunately i can't describe any more. During the installation there were no errors
Luke 42243 Posted July 10, 2016 Author Posted July 10, 2016 How do you know it's not starting? did you try the next step which is opening http://localhost:8096 ?
Pixelpaule 4 Posted July 10, 2016 Posted July 10, 2016 (edited) Yes i did and i got the message from mozilla that the server/website is not available. I use emby on my mac mini for a long time and i know a little bit about emby and it works fine. But on ubuntu emby doesen't start. Are there any log files at ubuntu that might helfen? It works. After a reinstall of ubuntu and emby the server starts. At the second installation i haven't used this tool to create a bootable usb stick: http://www.linuxliveusb.com. Possibly Linux Live has caused an error by creating the bootable stick. Edited July 10, 2016 by Pixelpaule
hurricanehrndz 149 Posted July 11, 2016 Posted July 11, 2016 Hey Luke, after the installation i can't Start emby. When i type "sudo service emby-server start" in the terminal nothing happens. Unfortunately i can't describe any more. During the installation there were no errors 16.04 uses systemd, I believe you need to do systemctl start emby-server
itsmynewname 0 Posted July 12, 2016 Posted July 12, 2016 Hi all very new to emby, have run the plex server. I have installed the emby mediaserver to my remote server but how do i create a tunnel so i can open the web interface on my pc please? Obviously i realise source port will be 8096 in putty but for plex its ipaddress:32400 Could someone kindly point me in the right direction Regards
mlpaul 0 Posted July 31, 2016 Posted July 31, 2016 Hello all, Iv'e been running Emby Server for about 9 months now, and recently ive ran into a little issue regarding playback of certain audio codecs (AC3). Whenever i try to stream anything through the web client (Chrome, Firefox, Edge, IE) that has the AC3 audio codec i get the "There was an error playing the video." Through the legacy Emby Theater application i can play the media just fine so that tells me that the files are fine, but it seems to be an issue whenever i play media through the web clients. Im running Ubuntu Server 16.04.1 and Emby Server 3.0.6020.0 Any help will be appreciated. Thanks!
Luke 42243 Posted July 31, 2016 Author Posted July 31, 2016 Hello all, Iv'e been running Emby Server for about 9 months now, and recently ive ran into a little issue regarding playback of certain audio codecs (AC3). Whenever i try to stream anything through the web client (Chrome, Firefox, Edge, IE) that has the AC3 audio codec i get the "There was an error playing the video." Through the legacy Emby Theater application i can play the media just fine so that tells me that the files are fine, but it seems to be an issue whenever i play media through the web clients. Im running Ubuntu Server 16.04.1 and Emby Server 3.0.6020.0 Any help will be appreciated. Thanks! Hi there, sorry to hear about this. Best thing to do is supply the info requested in how to report a problem and we'll do our best to get you squared away. Thanks!
mlpaul 0 Posted July 31, 2016 Posted July 31, 2016 (edited) Hi there, sorry to hear about this. Best thing to do is supply the info requested in how to report a problem and we'll do our best to get you squared away. Thanks! Here is the trans-coding log file - https://paste2.org/EOUWacPj Here is the General server log file - https://paste2.org/7MHvYFHX Here is an image of the media info - Edited July 31, 2016 by mlpaul
Luke 42243 Posted July 31, 2016 Author Posted July 31, 2016 Here is the trans-coding log file - https://paste2.org/EOUWacPj Here is the General server log file - https://paste2.org/7MHvYFHX Here is an image of the media info - It looks like your ffmpeg build does not support the look_ahead option we are using as part of QuickSync. I would disable QuickSync and/or look into updating ffmpeg on your system. If you can't update it on your system, you can always try downloading it from here: http://johnvansickle.com/ffmpeg/ and then setting it up under Playback -> Transcoding
mlpaul 0 Posted July 31, 2016 Posted July 31, 2016 Hmm. I remember i changed the Hardware Accleration in hopes that would fix it a while ago, and now when i try to change it back to "None" and click save, then go to restart the server, its back on the QuickSync. Any ideas?
Luke 42243 Posted July 31, 2016 Author Posted July 31, 2016 Hmm. I remember i changed the Hardware Accleration in hopes that would fix it a while ago, and now when i try to change it back to "None" and click save, then go to restart the server, its back on the QuickSync. Any ideas? try just shutting down the server and deleting the file /var/lib/emby-server/config/encoding.xml
Jdiesel 1435 Posted August 8, 2016 Posted August 8, 2016 Is the beta server being updated in the repository? I seem to be stuck on 3.1.88 and even after running apt-get update it is not recognizing the latest beta version.
Luke 42243 Posted August 8, 2016 Author Posted August 8, 2016 Is the beta server being updated in the repository? I seem to be stuck on 3.1.88 and even after running apt-get update it is not recognizing the latest beta version. It might just be running a little behind. Thank you for your patience.
Delphi 83 Posted August 11, 2016 Posted August 11, 2016 As of Version 3.0.6050.0 branding no longer persists between server restarts...
Luke 42243 Posted August 11, 2016 Author Posted August 11, 2016 Just tested this, no problem found. Worked perfectly.
Luke 42243 Posted August 11, 2016 Author Posted August 11, 2016 That doesn't really prove anything, it just says that perhaps there was some kind of style failure after restarting the server. Try removing the custom css and seeing if you still see the same failure.
Delphi 83 Posted August 11, 2016 Posted August 11, 2016 (edited) thats not the problem, the branding isn't there after the restart... my apologies, I meant the custom css isn't there after a restart... EDIT: Branding: persists Custom CSS: does not persist Edited August 11, 2016 by Delphi
Luke 42243 Posted August 11, 2016 Author Posted August 11, 2016 Ok, sorry to hear that. I can't reproduce it.
Delphi 83 Posted August 11, 2016 Posted August 11, 2016 (edited) Where is custom css information saved at by default? /var/lib/emby-server? Edited August 11, 2016 by Delphi
Delphi 83 Posted August 14, 2016 Posted August 14, 2016 (edited) @@Luke, Emby doesnt like the @import option in custom css... If i paste the css there it stays but if I use the @import statement to import from github emby does not persist that data between restarts Try the following as your custom css and restart to see the problem... @import url('https://rawgit.com/BenZuser/Emby-Web-Dark-Themes-CSS/master/PURPLE%20-%20Dark%20Theme.css'); @import url('https://rawgit.com/delphiactual/emby.css/master/adjust.css'); Edited August 14, 2016 by Delphi
richardbigg 1 Posted August 23, 2016 Posted August 23, 2016 Cinema Mode... Include trailers from older movies... Works great, but occasionaly, it tries to get a trailer that isn't good, and it breaks things. Such as this. My daughter tried to watch Milo and Otis... It played the streamed trailer for babe, ok, then it tried to get the Young Black Stalliion, then it crashed out of play back... See logs below.. But my realy question is... how does it determine which trailers to play, it seems to play the same ones every time... Where are these preferred trailers stored? Can they be deleted so a new set appear? ----- 2016-08-22 21:42:38.8849 Info HttpServer: HTTP GET http://10.0.0.5:8096/emby/Users/232943f0bd80482daa87f3303a363425/Items/7c48cc97b153a7026e187628d2d200ae/Intros. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:38.9617 Info HttpServer: HTTP Response 200 to 10.0.0.100. Time: 77ms. http://10.0.0.5:8096/emby/Users/232943f0bd80482daa87f3303a363425/Items/7c48cc97b153a7026e187628d2d200ae/Intros 2016-08-22 21:42:38.9876 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Items/1056b2d09466bffa3fc1dfbc28b9d61d/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:39.0163 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:39.0163 Info App: Profile: Unknown Profile, Path: http://videos.movie-list.com/classics/babe-trailer.mov, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:39.0163 Info App: Profile: Unknown Profile, Cannot direct stream with no known video stream. Path: http://videos.movie-list.com/classics/babe-trailer.mov 2016-08-22 21:42:39.0172 Info HttpServer: HTTP Response 200 to 10.0.0.100. Time: 30ms. http://10.0.0.5:8096/emby/Items/1056b2d09466bffa3fc1dfbc28b9d61d/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0 2016-08-22 21:42:39.0504 Info HttpServer: HTTP GET http://10.0.0.5:8096/emby/videos/1056b2d09466bffa3fc1dfbc28b9d61d/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=4a2c330ae402d4d991bcb6f80d955166&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=269153684&AudioBitrate=320000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=33eade517e8b42cdaff32a57f3955259&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:39.0644 Info App: /var/lib/emby-server/ffmpeg/20160215/ffmpeg -fflags +genpts -i "http://videos.movie-list.com/classics/babe-trailer.mov"-sn -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 269153684 -maxrate 269153684 -bufsize 538307368 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 2 -ab 320000 -af "aresample=async=1" -y "/fileserver/mediabrowser/lib/mediabrowser/transcoding-temp/transcoding-temp/e3c29cd7cea2772ab56cf44c1e1004fd.mkv" 2016-08-22 21:42:41.7221 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Sessions/Playing. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:42.1310 Info HttpServer: HTTP Response 204 to 10.0.0.100. Time: 409ms. http://10.0.0.5:8096/emby/Sessions/Playing 2016-08-22 21:42:42.3183 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:42.3223 Info App: Stopping ffmpeg process with q command for /fileserver/mediabrowser/lib/mediabrowser/transcoding-temp/transcoding-temp/e3c29cd7cea2772ab56cf44c1e1004fd.mkv 2016-08-22 21:42:42.3306 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Items/b2b88185da158d7bd71721af79dca1ce/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:42.3489 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_1500.mov, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Cannot direct stream with no known video stream. Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_1500.mov 2016-08-22 21:42:42.3489 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_0750.mov, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Cannot direct stream with no known video stream. Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_0750.mov 2016-08-22 21:42:42.3489 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_0300.mov, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:42.3489 Info App: Profile: Unknown Profile, Cannot direct stream with no known video stream. Path: http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_0300.mov 2016-08-22 21:42:42.3489 Info HttpServer: HTTP Response 200 to 10.0.0.100. Time: 19ms. http://10.0.0.5:8096/emby/Items/b2b88185da158d7bd71721af79dca1ce/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0 2016-08-22 21:42:42.3571 Info App: FFMpeg exited with code 0 2016-08-22 21:42:42.3571 Info App: Deleting partial stream file(s) /fileserver/mediabrowser/lib/mediabrowser/transcoding-temp/transcoding-temp/e3c29cd7cea2772ab56cf44c1e1004fd.mkv 2016-08-22 21:42:42.3778 Info HttpServer: HTTP GET http://10.0.0.5:8096/emby/videos/b2b88185da158d7bd71721af79dca1ce/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=a66b76438eb46b4d40c72c06c659d897&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=269153684&AudioBitrate=320000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=94d98613be1a4020b5fea189d503a8e8&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:42.4215 Info App: /var/lib/emby-server/ffmpeg/20160215/ffmpeg -fflags +genpts -i "http://bvim-qt.vitalstream.com/YoungBlackStallion/YoungBlackStallion_T1_1500.mov"-sn -codec:v:0 libx264 -force_key_frames "expr:gte(t,n_forced*5)" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 269153684 -maxrate 269153684 -bufsize 538307368 -vsync -1 -profile:v high -level 51 -map_metadata -1 -threads 0 -codec:a:0 libmp3lame -ac 2 -ab 320000 -af "aresample=async=1" -y "/fileserver/mediabrowser/lib/mediabrowser/transcoding-temp/transcoding-temp/45d8f3ef44031d7bd7cecd290c94326f.mkv" 2016-08-22 21:42:42.7237 Info HttpServer: HTTP Response 204 to 10.0.0.100. Time: 405ms. http://10.0.0.5:8096/emby/Sessions/Playing/Stopped 2016-08-22 21:42:42.8231 Info App: FFMpeg exited with code 1 2016-08-22 21:42:43.8423 Error ServiceStackHost: 10.0.0.5:8096 Request not found: /emby/videos/b2b88185da158d7bd71721af79dca1ce/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=a66b76438eb46b4d40c72c06c659d897&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=269153684&AudioBitrate=320000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=94d98613be1a4020b5fea189d503a8e8&api_key=0f0ccd6b880443189f645d03ed7b68d6&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false 2016-08-22 21:42:43.8423 Info HttpServer: HTTP Response 404 to 10.0.0.100. Time: 1466ms (slow). http://10.0.0.5:8096/emby/videos/b2b88185da158d7bd71721af79dca1ce/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=a66b76438eb46b4d40c72c06c659d897&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=269153684&AudioBitrate=320000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=94d98613be1a4020b5fea189d503a8e8&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false 2016-08-22 21:42:43.8504 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:43.8511 Info HttpServer: HTTP DELETE http://10.0.0.5:8096/emby/Videos/ActiveEncodings?deviceId=499e3e3ea028a39802afffebd8d26b08. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:43.8511 Info App: Deleting partial stream file(s) /fileserver/mediabrowser/lib/mediabrowser/transcoding-temp/transcoding-temp/45d8f3ef44031d7bd7cecd290c94326f.mkv 2016-08-22 21:42:43.8522 Info HttpServer: HTTP Response 204 to 10.0.0.100. Time: 1ms. http://10.0.0.5:8096/emby/Videos/ActiveEncodings?deviceId=499e3e3ea028a39802afffebd8d26b08 2016-08-22 21:42:43.8910 Info HttpServer: HTTP POST http://10.0.0.5:8096/emby/Items/7c48cc97b153a7026e187628d2d200ae/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36 2016-08-22 21:42:43.9073 Info HttpServer: HTTP Response 200 to 10.0.0.100. Time: 4857ms (slow). http://10.0.0.5:8096/emby/videos/1056b2d09466bffa3fc1dfbc28b9d61d/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=4a2c330ae402d4d991bcb6f80d955166&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=269153684&AudioBitrate=320000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=33eade517e8b42cdaff32a57f3955259&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi 2016-08-22 21:42:43.9312 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi 2016-08-22 21:42:43.9312 Info App: RemoteClientBitrateLimit: 4000000, RemoteIp: 10.0.0.100, IsInLocalNetwork: True 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-08-22 21:42:43.9312 Info App: Profile: Unknown Profile, No direct play profiles found for Path: \\10.0.0.5\movies\The Adventures of Milo and Otis (1986)\The Adventures of Milo and Otis (1986) [sD] [2.0].avi 2016-08-22 21:42:43.9326 Info HttpServer: HTTP Response 200 to 10.0.0.100. Time: 42ms. http://10.0.0.5:8096/emby/Items/7c48cc97b153a7026e187628d2d200ae/PlaybackInfo?UserId=232943f0bd80482daa87f3303a363425&StartTimeTicks=0 2016-08-22 21:42:43.9638 Info HttpServer: HTTP GET http://10.0.0.5:8096/emby/videos/7c48cc97b153a7026e187628d2d200ae/stream.mkv?DeviceId=499e3e3ea028a39802afffebd8d26b08&MediaSourceId=7c48cc97b153a7026e187628d2d200ae&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=269355780&AudioBitrate=117904&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=d2b7f943c44b47699e124655324fb7f8&CopyTimestamps=true&ForceLiveStream=false&EnableSubtitlesInManifest=false. UserAgent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36
forty37 0 Posted September 1, 2016 Posted September 1, 2016 Hello - been lurking, now seeking help. Just installed Ubuntu 16.04 Server on a fresh machine and followed the instructions to install emby. The install seemed to go fine but when I attempt to start it .. nothing. Looking in /var/log/emby-server.log I see the following: [ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) <0x411b20e0 + 0x00225> in :0 Could not load signature of Patterns.Logging.ILogger:FatalException due to: Could not load file or assembly or one of its dependencies. assembly:System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a type: member: exception inside UnhandledException handler: Object reference not set to an instance of an object exception inside UnhandledException handler: Object reference not set to an instance of an object Any suggestions would be grand. Thanks!
rlw6534 4 Posted September 1, 2016 Posted September 1, 2016 (edited) Hello - been lurking, now seeking help. Just installed Ubuntu 16.04 Server on a fresh machine and followed the instructions to install emby. The install seemed to go fine but when I attempt to start it .. nothing. Looking in /var/log/emby-server.log I see the following: [ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) <0x411b20e0 + 0x00225> in :0 Could not load signature of Patterns.Logging.ILogger:FatalException due to: Could not load file or assembly or one of its dependencies. assembly:System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a type: member: exception inside UnhandledException handler: Object reference not set to an instance of an object exception inside UnhandledException handler: Object reference not set to an instance of an object Any suggestions would be grand. Thanks! It will work if you install mono-complete. Looks like a dependency was missed in the latest update. "sudo apt-get install mono-complete" I'm sure it installs more than you need, but it will work. Edited September 1, 2016 by rlw6534 1
