hurricanehrndz 149 Posted January 7, 2016 Posted January 7, 2016 What distribution are you running? What is your init system?
bob808 2 Posted January 8, 2016 Posted January 8, 2016 running ubuntu server 15.10 - its a plain install with emby and a few other programs added (tv headend plus some others). so I think this is systemd and not upstart?
hurricanehrndz 149 Posted January 9, 2016 Posted January 9, 2016 If systemd is the managing emby start and stop then restart should work flawlessly. It was the distribution used for all testing and development of the restart script Sent from my D6603 using Tapatalk
hurricanehrndz 149 Posted January 9, 2016 Posted January 9, 2016 How far did you get through the troubleshooting guide on the wiki? Sent from my D6603 using Tapatalk
dkalejta 0 Posted January 10, 2016 Posted January 10, 2016 I feel a bit dense for asking this, but are there any clear instructions anywhere for updating Emby server on Ubuntu? Apt-get update - > apt-get upgrade emby-server appears to upgrade to the latest version, but then the emby service is not recognized. While it appears to be running on reboot, I can't stop/start with 'service emby-server start/stop/restart' and its unavailable via :8096 Same results from running apt-get remove -> install via https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server I don't want to waste anyone's time troubleshooting, but I also can't find a nice little bulletpoint list of 'How to update' to make sure I'm not doing something idiotic (I'm pretty new to Ubuntu Server/Linux in general). Thanks for any help you can provide.
hurricanehrndz 149 Posted January 10, 2016 Posted January 10, 2016 That is exactly how you upgrade, there seems that a bug has crept into our stable releases and we are trying to address it. Sent from my D6603 using Tapatalk
hurricanehrndz 149 Posted January 10, 2016 Posted January 10, 2016 Please post the logs, there should be a system log for emby startup /var/log as well. Also, could you please provide any info regarding which version you are coming from Sent from my D6603 using Tapatalk
j0nezy 0 Posted January 11, 2016 Posted January 11, 2016 (edited) Hi I'm having some serious problems with my Emby install. Was previously running an older version fine. There are two of us who access the installation. My friend tried to update Emby a couple of weeks ago and it failed so he left it. It was running fine though afterwards.Today it wasn't running, so I took a look.Basically I'm at a crossroads.Running Ubuntu 14.04, I've installed the relevant latest Emby version but I cannot for the life of me get it running.I go to http://ip:8096and just get "ERR_CONNECTION_REFUSED" or "This web page is not available".Occasionally I get a "No data received". If I continually try to refresh I occasionally see the URL forward to http://ip:8096/web/index.htmlor http://ip:8096/web/wizardstart.html but then it dies again. I've managed, with continual refreshes to get as far as a bit further in the wizard, even to the point of putting my Emby Connect username in, but then it dies again. I do occasionally get a grey screen too.I've searched and searched these forums, and I'm sure the answer is starting me in the face but I just can't find it. I can start/stop/restart the service using : service emby-server start|stop|restart (With and without sudo). I've changed the user in /etc/emby-server.conf by adding the following line EMBY_USER=root Also tried adding the user root to the emby group chowned the /var/lib/emby-server folder (not recursive) to root:root The file at /var/log/upstart/emby-server.log just has multiple recurrences of + echo Starting emby-serverStarting emby-server + set + logger -t /proc/self/fd/9 DEBUG: IFS=' ' OPTIND='1' PATH='/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/sbin:/sbin:/bin' PPID='1' PS1='# ' PS2='> ' PS4='+ ' PWD='/' TERM='linux' UPSTART_INSTANCE='' UPSTART_JOB='emby-server' + exec /usr/bin/emby-server start Edited January 11, 2016 by j0nezy
hurricanehrndz 149 Posted January 11, 2016 Posted January 11, 2016 Hi I'm having some serious problems with my Emby install. Was previously running an older version fine. There are two of us who access the installation. My friend tried to update Emby a couple of weeks ago and it failed so he left it. It was running fine though afterwards. Today it wasn't running, so I took a look. Basically I'm at a crossroads. Running Ubuntu 14.04, I've installed the relevant latest Emby version but I cannot for the life of me get it running. I go to http://ip:8096and just get "ERR_CONNECTION_REFUSED" or "This web page is not available". Occasionally I get a "No data received". If I continually try to refresh I occasionally see the URL forward to http://ip:8096/web/index.htmlor http://ip:8096/web/wizardstart.html but then it dies again. I've managed, with continual refreshes to get as far as a bit further in the wizard, even to the point of putting my Emby Connect username in, but then it dies again. I do occasionally get a grey screen too. I've searched and searched these forums, and I'm sure the answer is starting me in the face but I just can't find it. I can start/stop/restart the service using : service emby-server start|stop|restart (With and without sudo). I've changed the user in /etc/emby-server.conf by adding the following line EMBY_USER=root Also tried adding the user root to the emby group chowned the /var/lib/emby-server folder (not recursive) to root:root The file at /var/log/upstart/emby-server.log just has multiple recurrences of Please post the following files: /var/log/emby-server.log /etc/default/emby-server /etc/emby-server /etc/sudoers.d/emby
j0nezy 0 Posted January 11, 2016 Posted January 11, 2016 /var/log/emby-server.log : 01_var_log_emby-server.log.txt /etc/default/emby-server : 02_etc_default_emby-server.txt /etc/emby-server.conf : 03_etc_emby-server.conf.txt /etc/sudoers.d/emby : 04_etc_sudoers.d_emby.txt I assume the third was the .conf file? (/etc/emby-server does not exist without the .conf extension) I've also added .txt extensions to the files to allow me to upload them as attachments. Thanks
hurricanehrndz 149 Posted January 11, 2016 Posted January 11, 2016 Well I believe your issue is in the first log: Native stacktrace: ¦ /usr/bin/mono-sgen() [0x4b8028] ¦ /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f76b8744340] ¦ /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f76b83a5cc9] ¦ /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7f76b83a90d8] ¦ /usr/bin/mono-sgen() [0x62d029] ¦ /usr/bin/mono-sgen() [0x62d22f] ¦ /usr/bin/mono-sgen() [0x62d376] ¦ /usr/bin/mono-sgen() [0x58b5ad] ¦ /usr/bin/mono-sgen() [0x58b710] ¦ /usr/bin/mono-sgen() [0x62729e] ¦ /lib/x86_64-linux-gnu/libpthread.so.0(+0x8182) [0x7f76b873c182] ¦ /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f76b846947d] Corlib not in sync with this runtime: expected corlib version 117, found 138. Loaded from: /usr/lib/mono/4.5/mscorlib.dll Download a newer corlib or a newer runtime at http://www.mono-project.com/download. Debug info from gdb: http://stackoverflow.com/questions/29988698/teamcity-nunitlauncher-running-on-linux-mono-gives-corlib-not-in-sync-with-th This issue might be due to a plugin you have enabled. I would first try a purge of all mono packages and a re installation. If not perhaps try the solution at the bottom where the user talks about the raspberry pi.
hurricanehrndz 149 Posted January 11, 2016 Posted January 11, 2016 You might also want to try backing up your emby data. And doing a clean reinstall and see if it loads. If it does then my bet is that it is a plugin that you have enabled that is causing issues.
j0nezy 0 Posted January 11, 2016 Posted January 11, 2016 Thank you I've just tried the quickest solution (The raspberry pi post). No joy.Will look at the other two solutions. No idea where to start!Thanks again
j0nezy 0 Posted January 11, 2016 Posted January 11, 2016 (edited) Actually. I've just given the server a little reboot and now /var/log/emby-server.log is just showing this nfo, Main, Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib$ Operating system: Unix 3.13.0.46 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 04:04:55 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe appHost.Init Info, App, Application version: 3.0.5854.31461 Then I checked again 30 seconds later and it showed this Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib$ Operating system: Unix 3.13.0.46 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 04:04:55 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe appHost.Init Info, App, Application version: 3.0.5854.31461 Info, App, Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps$ Info, App, Loading MediaBrowser.Api, Version=3.0.5854.31450, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.WebDashboard, Version=3.0.5854.31445, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Model, Version=3.0.5854.31439, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Common, Version=3.0.5854.31440, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Controller, Version=3.0.5854.31441, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Providers, Version=3.0.5854.31442, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Common.Implementations, Version=3.0.5854.31441, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Server.Implementations, Version=3.0.5854.31443, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.MediaEncoding, Version=3.0.5854.31452, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Dlna, Version=3.0.5854.31451, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.LocalMetadata, Version=3.0.5854.31452, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.XbmcMetadata, Version=3.0.5854.31452, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Server.Mono, Version=3.0.5854.31461, Culture=neutral, PublicKeyToken=null Info, App, Loading MediaBrowser.Server.Startup.Common, Version=3.0.5854.31454, Culture=neutral, PublicKeyToken=null Info, SqliteUserRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/users.db Info, SqliteFileOrganizationRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/fileorganization.db Info, AuthenticationRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/authentication.db Info, SyncRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/sync14.db Info, ImageMagick, ImageMagick version: ImageMagick 6.9.2-8 Q8 x86_64 2015-12-21 [url=http://www.imagemagick.org]http://www.imagemagick.org[/url] Info, ImageProcessor, ImageProcessor started with 8 max concurrent image processes Info, App, FFMpeg: /var/lib/emby-server/ffmpeg/20150917/ffmpeg Info, App, FFProbe: /var/lib/emby-server/ffmpeg/20150917/ffprobe Info, SharingRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/shares.db Info, ActivityRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/activitylog.db Warn, App, ffmpeg is missing decoder h264_qsv Info, SqliteDisplayPreferencesRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/displaypreferences.db Warn, App, ffmpeg is missing decoder mpeg2_qsv Info, SqliteItemRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/library.db Warn, App, ffmpeg is missing decoder vc1_qsv Info, SqliteProviderInfoRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/refreshinfo.db Info, SqliteUserDataRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/userdata_v2.db Info, SqliteNotificationsRepository, Sqlite 3.8.2 opening /var/lib/emby-server/data/notifications.db Info, HttpServer, Calling ServiceStack AppHost.Init Edited January 11, 2016 by j0nezy
j0nezy 0 Posted January 12, 2016 Posted January 12, 2016 I did manage to get in last night (Which I have done before). Connected through port 8096, started the wizard and chose the language. Then when choosing a username and opting to add my Emby Connect username, I put it in and it just wouldn't 'take it', kept throwing up errors asking me if I'd actually signed up for Emby Connect. Removed the username and it still refused to proceed, instead giving a general error (I forget the actual text). I *did* then manage to log into app.emby.media though and the server was listed on there and I could browse it's properties etc, although it was an empty server with no libraries and just one user. Now this morning, none of it is working again.
hurricanehrndz 149 Posted January 12, 2016 Posted January 12, 2016 Post the log please. Sent from my D6603 using Tapatalk
j0nezy 0 Posted January 12, 2016 Posted January 12, 2016 This is the latest one. 01_var_log_emby-server.log (2).txt
hurricanehrndz 149 Posted January 12, 2016 Posted January 12, 2016 Please see if restarting the server works. I can not help you emby connect you will need to post to the appropriate forum for that. Sent from my D6603 using Tapatalk
j0nezy 0 Posted January 12, 2016 Posted January 12, 2016 No joy I'm afraid, I still cannot connect via port 8096, it just won't work.
hurricanehrndz 149 Posted January 12, 2016 Posted January 12, 2016 Well please remove your config and make a backup Sent from my D6603 using Tapatalk
j0nezy 0 Posted January 13, 2016 Posted January 13, 2016 Hi hh Right, after messing about with the config files I decided to remove all traces of emby/emby-server from the server. Deleted all files, everything. Updated what libraries I could and then rebooted. Reinstalled emby-server via apt-get. Still failed. I did notice when having a look at var/log/emby-server.log (I usually use nano to browse logs), it was different every time I loaded it, so I realised it was wiping the log on each startup, thus showing that emby was loading, logging then quitting and restarting. So running tail -f on /var/log/emby-server.log I watched it and found this interesting snippet recurring Info, HttpServer, Adding HttpListener prefix https://+:8920/ Running startup tasks (gnome-open:6038): GConf-WARNING **: Client failed to connect to the D-BUS daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11 GConf Error: No D-BUS daemon running Error showing url: Operation not supported Info, App, Core startup complete Info, SsdpHandler, MultiCast socket created Cannot handle address family 58112 Stacktrace: at <unknown> <0xffffffff> at (wrapper managed-to-native) System.Net.Dns.GetHostByName_internal (string,string&,string[]&,string[]&) <0xffffffff> at System.Net.Dns.GetHostByName (string) <0x00047> at System.Net.ServicePoint.get_HostEntry () <0x00203> at System.Net.WebConnection.Connect (System.Net.HttpWebRequest) <0x001ab> at System.Net.WebConnection.InitConnection (object) <0x00293> at System.Net.WebConnection.<WebConnection>m__0 (object) <0x0001f> at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context (object) <0x00048> at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext,System.Threading.ContextCallback,object,bool) <0x0016e> at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext,System.Threading.ContextCallback,object,bool) <0x00020> at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () <0x00053> at System.Threading.ThreadPoolWorkQueue.Dispatch () <0x001d6> at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () <0x00008> at (wrapper runtime-invoke) <Module>.runtime_invoke_bool (object,intptr,intptr,intptr) <0xffffffff> Native stacktrace: /usr/bin/mono-sgen() [0x4a1df8] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fec172b0340] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7fec16f11cc9] /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7fec16f150d8] /usr/bin/mono-sgen() [0x62bdc9] /usr/bin/mono-sgen() [0x62bfcf] /usr/bin/mono-sgen() [0x62c072] /usr/bin/mono-sgen() [0x626f15] /usr/bin/mono-sgen() [0x57a916] [0x40df98f7] Debug info from gdb: ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= tail: /var/log/emby-server.log: file truncated Info, Main, Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.13.0.46 Processor count: 8 64-Bit OS: TrueIt does repeat itself but the above is the section I believe is pertinent. Seems like it could be something to do with Mono as you mentioned above.Running mono -V gives me a version of 4.21
j0nezy 0 Posted January 13, 2016 Posted January 13, 2016 Right, I've purged all packaged prefixed with mono via apt-get. Reinstalled mono-complete as per the official mono site, and reinstalled emby-server. Still starting up then quitting, giving the following error in the log Running startup tasks Info, App, Core startup complete Info, SsdpHandler, MultiCast socket created (gnome-open:2581): GConf-WARNING **: Client failed to connect to the D-BUS daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11 GConf Error: No D-BUS daemon running Error showing url: Operation not supported Cannot handle address family 49920 Stacktrace: at <unknown> <0xffffffff> at (wrapper managed-to-native) System.Net.Dns.GetHostByName_internal (string,string&,string[]&,string[]&) <0xffffffff> at System.Net.Dns.GetHostByName (string) <0x00047> at System.Net.ServicePoint.get_HostEntry () <0x00203> at System.Net.WebConnection.Connect (System.Net.HttpWebRequest) <0x001ab> at System.Net.WebConnection.InitConnection (object) <0x00293> at System.Net.WebConnection.<WebConnection>m__0 (object) <0x0001f> at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context (object) <0x00048> at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext,System.Threading.ContextCallback,object,bool) <0x0016e> at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext,System.Threading.ContextCallback,object,bool) <0x00020> at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () <0x00053> at System.Threading.ThreadPoolWorkQueue.Dispatch () <0x001d6> at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () <0x00008> at (wrapper runtime-invoke) <Module>.runtime_invoke_bool (object,intptr,intptr,intptr) <0xffffffff> Native stacktrace: /usr/bin/mono-sgen() [0x4a1df8] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fe4dbe49340] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7fe4dbaaacc9] /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7fe4dbaae0d8] /usr/bin/mono-sgen() [0x62bdc9] /usr/bin/mono-sgen() [0x62bfcf] /usr/bin/mono-sgen() [0x62c072] /usr/bin/mono-sgen() [0x626f15] /usr/bin/mono-sgen() [0x57a916] [0x4136b097] Debug info from gdb: ================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= tail: /var/log/emby-server.log: file truncated Info, Main, EmbyI'm at the end of the road now, no idea what else to try.
hurricanehrndz 149 Posted January 13, 2016 Posted January 13, 2016 What is the kernel version of your system? You might also want to create a separate thread to get others attention other than just posting here. Sent from my D6603 using Tapatalk
