Ubuntu
hurricanehrndz
Yes. And ensure that /usr/bin/emby-server exist and is executable and replace it with the one I linked earlier as well. It might be different, I have been working on it all night long for other distros and projects.
nicheplayer
OK. Uploaded the new emby-server and then ran
/etc/init.d/emby-server start
Got
[....] Starting emby-server daemon:/usr/bin/emby-server: 30: [: 1: unexpected operator
. ok
But the server is running!
hurricanehrndz
Okay, did you run it as nicheplayer007
Got
. ok
hurricanehrndz
Script has been updated.
  • Like 1
nicheplayer
I ran it as root.
I'm having a similar issue too - can no longer start after the update ...
This is the output of systemctl status emby-server
● emby-server.service - Emby Media Server
   Loaded: loaded (/lib/systemd/system/emby-server.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2015-12-12 22:15:43 AEDT; 7min ago
  Process: 14187 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS)
  Process: 14178 ExecStart=/usr/bin/emby-server start (code=exited, status=1/FAILURE)
 Main PID: 14178 (code=exited, status=1/FAILURE)
Dec 12 22:15:43 machine emby-server[14178]: /usr/bin/emby-server: 82: /usr/bin/emby-server: cannot create : Directory nonexistent
Dec 12 22:15:43 machine su[14178]: No passwd entry for user 'env'
Dec 12 22:15:43 machine su[14178]: FAILED su for env by root
Dec 12 22:15:43 machine systemd[1]: emby-server.service: main process exited, code=exited, status=1/FAILURE
Dec 12 22:15:43 machine emby-server[14187]: dirname: missing operand
Dec 12 22:15:43 machine emby-server[14187]: Try 'dirname --help' for more information.
Dec 12 22:15:43 machine emby-server[14187]: chown: missing operand after ‘.’
Dec 12 22:15:43 machine emby-server[14187]: Try 'chown --help' for more information.
Dec 12 22:15:43 machine systemd[1]: Unit emby-server.service entered failed state.
Dec 12 22:15:43 machine systemd[1]: emby-server.service failed.
... and sudoers.d/emby
#Allow emby to start, stop and restart itself
emby ALL=(ALL) NOPASSWD: /bin/systemctl restart emby-server.service
emby ALL=(ALL) NOPASSWD: /etc/init.d/emby-server *
emby ALL=(ALL) NOPASSWD: /usr/sbin/service emby-server *
emby ALL=(ALL) NOPASSWD: /usr/sbin/invoke-rc.d emby-server *
#Allow the server to mount iso images
emby ALL=(ALL) NOPASSWD: /bin/mount
emby ALL=(ALL) NOPASSWD: /bin/umount
Defaults:emby !requiretty
hurricanehrndz
Totally different issue. Remove /etc/default/emby-sever and reinstall
Sent from my D6603 using Tapatalk
nicheplayer
I downloaded it again from the link you posted earlier this morning. Shut down emby server and then SCPed the script to the server and checked permissions.
root@machine:/usr/bin# ls -la /usr/lib/emby-server/
total 32
drwxr-xr-x  3 root root  4096 Dec  6 12:24 .
drwxr-xr-x 66 root root 12288 Dec  6 13:04 ..
drwxr-xr-x  5 root root 12288 Dec  6 12:24 bin
-rwxr-xr-x  1 root root   778 Dec 12 10:37 restart.sh
Started emby with /etc/init.d/emby-server start
. ok
Went to the web dashboard and hit restart. Shutdown button went gray. Refreshed the page, and no connection. Here's the server log from the event, FWIW.
hurricanehrndz
Why do you keep trying the button, there is no sense if you can't not get your user nicheplayer007 to sudo without a password. Line 30 of the start script should have been fixed. I will double check it.
hurricanehrndz
what happens when you run:
su nicheplayer007
sudo /etc/init.d/emby-server restart <--- this needs to work without a password before you can even hit the button
nicheplayer
su nicheplayer007
$ sudo /etc/init.d/emby-server restart
[sudo] password for nicheplayer007:
hurricanehrndz
well, i don't know what to tell you. I have done this hundreds of time and it works. Here are some things to check:
1. permission of /etc/sudoers.d/emby should 0640
2. ensure nicheplayer007 is part of group emby
3. ensure /etc/sudoers permissions is 0640
4. ensure your file /etc/sudoers.d/emby looks as follows: https://github.com/hurricanehrndz/Emby.Build/blob/ft_docker/builders/emby-server/debfiles/emby
Once you can get sudo /etc/init.demby-server restart working as nicheplayer007 we can move on.
Edited by hurricanehrndz
  • Like 1
nicheplayer
You know, I was just looking at /etc/sudoers.d/ . There are two emby files in there:
root@machine:/etc/sudoers.d# ls -la
total 16
drwxr-xr-x   2 root root 4096 Dec 12 03:22 .
drwxr-xr-x 105 root root 4096 Dec 12 02:26 ..
-r--r-----   1 root root    0 Dec 12 02:11 emby
-rw-r-----   1 root root 1541 Dec 12 03:22 emby.txt
-r--r-----   1 root root  958 Mar  1  2013 README
emby is empty. emby.txt looks like the github file you linked above. So not sure how that happened. So anyway, I removed emby, moved emby.txt to emby, did su nicheplayer007 and then sudo /etc/init.d/emby-server restart and got:
[ ok ] Stopping emby-server daemon:[....] apparently already stopped.
. ok
. ok
!!  :D
  • Like 1
hurricanehrndz
Good, now try.
ps aux | grep emby
su nicheplayer007
/usr/lib/emby-server/restart.sh
ps aux | grep emby
report back
nicheplayer
Still as nicheplayer007, or as root?
hurricanehrndz
Sorry,
ps aux | grep emby
su nicheplayer007
sudo /usr/lib/emby-server/restart.sh
ps aux | grep emby
nicheplayer
ps aux | grep emby:
root@machine:/# ps aux | grep emby
root     25641  0.0  0.0  37072  1088 pts/0    S    12:37   0:00 su -s /bin/sh -c exec "$0" "$@" nicheplayer007 -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m LD_LIBRARY_PATH= /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
1000     25657  3.5 13.1 781552 275312 ?       Ssl  12:37   0:36 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     25978  0.0  0.0   7724   944 pts/0    S+   12:54   0:00 grep emby
sudo /usr/lib/emby-server/restart.sh :
root@machine:/# su nicheplayer007
$ sudo /usr/lib/emby-server/restart.sh
Sorry, user nicheplayer007 is not allowed to execute '/usr/lib/emby-server/restart.sh' as root on machine.
ps aux | grep emby :
1000     25657  3.3 11.9 781552 250884 ?       Ssl  12:37   0:41 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     26040  0.0  0.0   7724   944 pts/0    S+   12:58   0:00 grep emby
Edited by nicheplayer
hurricanehrndz
try this
ps aux | grep emby
su nicheplayer007
ps aux | grep emby
nicheplayer
ps aux | grep emby
1000     25657  2.9 14.8 807708 310996 ?       Ssl  12:37   1:04 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     26300  0.0  0.0   7724   940 pts/0    S+   13:13   0:00 grep emby
then, after running the su and /usr/lib/emby-server/restart.sh , I'm prompted for nicheplayer007's password. I enter it, and there's no feedback, just a return to the $ prompt. Exiting out of that and running ps aux | grep emby gets
1000     25657  2.9 14.1 808732 297584 ?       Ssl  12:37   1:10 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     26370  0.0  0.0   7724   944 pts/0    S+   13:18   0:00 grep emby
hurricanehrndz
okay
Dude, you might really have to start troubleshooting this yourself. I have a ton to do, and this thread is getting super long. Go to chat.
ps aux | grep emby
su nicheplayer007
ps aux | grep emby
  • Like 1
nicheplayer
okay
Totally understand. I really do appreciate the assistance. I'll look into wiping my current install and just starting from scratch.
hurricanehrndz
I'm in the chat. And I wouldn't do a reinstall just yet, there is a ton of fixes going into the next update. Thanks for the bugs you found.
maiky jonathan gomes
My friends , since I moved to my access and even put to Emby access so that it still does not recognize the second hd , you guys have any help for me
This worked : dpkg --force-confmiss -i /var/cache/apt/archives/emby-server_3.0.5781.5_all.deb
	Edited  by lordvader
I installed Ubuntu 15.10 on the day it was released. Upon realizing that Emby-server was not ready for 15.10 I felt like a fool. My system is primarily games and Emby-server. I followed the instructions and installed the mono tools from the 15.04 repo alongside the deb posted to the forums. This worked but as soon as I finished the install I started getting this error when starting Emby-server.
"Error: No space left on device"
I have plenty of space on all my hard drive partitions, so I have no idea where this is coming from. I believe it is linked to what was installed by the 15.04 repo but I do not know for certain. I don't really know what was installed so I don't know how to revert and fix this. I have switched to th 15.10 repository and installed emby-server. It works fine, but I get that error message on launch.
Any idea what would cause this or where this is coming from?
