Ubuntu
hurricanehrndz
Okay, I will write some new files for you soon.
  • Like 1
nicheplayer
Thank you. I really appreciate your help. I'm not sure why the admins at my VPS are running Debian 7, but, then, I don't have any control over it.
I'm not sure what this will do to your system, I have not tested it thoroughly.
Replace /etc/sudoers.d/emby with https://raw.githubusercontent.com/hurricanehrndz/Emby.Build/ft_docker/builders/emby-server/debfiles/emby
Replace /usr/bin/emby-server with https://raw.githubusercontent.com/hurricanehrndz/Emby.Build/ft_docker/builders/emby-server/debfiles/bin/emby-server
What's the best way to do that? Just scp them into their respective directories to overwrite?
hurricanehrndz
Yeah, make sure they are both executable or wget them from the server itself.
Stop emby-server, before overwriting the existing files. Start emby-server. And then try the restart.sh script.
Edited by hurricanehrndz
nicheplayer
What should I run for wget, and do I have to do it from the destination directory (i.e., /etc/sudoers.d/ and /usr/bin/emby-server, respectively)?
hurricanehrndz
As root run the following
rm /etc/sudoers.d/emby
wget https://raw.githubusercontent.com/hurricanehrndz/Emby.Build/ft_docker/builders/emby-server/debfiles/emby > /etc/sudoers.d/emby
chmod +x /etc/sudoers.d/emby
rm /usr/bin/emby-server
wget https://raw.githubusercontent.com/hurricanehrndz/Emby.Build/ft_docker/builders/emby-server/debfiles/bin/emby-server > /usr/bin/emby-server
chmod +x /usr/bin/emby-server
su nicheplayer007
sudo /etc/init.d/emby-server start
You shouldn't be prompted for a password
  • Like 1
nicheplayer
Got all the way to
su nicheplayer007
and got this after running
[sudo] password for nicheplayer007:
nicheplayer007 is not in the sudoers file.  This incident will be reported.
hurricanehrndz
Got all the way to
cat /etc/group | grep emby check if nicheplayer is in group emby.
hurricanehrndz
lol, This is the funniest thing I have ever seen in my life.
  • Like 1
nicheplayer
I hear ya. It's not like I have a huge install here, so I'm totally good with wiping everything and starting from scratch. But in any case, running
gets me
root@darktruth:~# cat /etc/group | grep emby
emby:x:117:
root@darktruth:~#
hurricanehrndz
weird..,
okay do the following, start as root
usermod -G emby nicheplayer007
cat /etc/group | emby <--- ensure nicheplayer007 shows up
su nicheplayer007
sudo /etc/init.d/emby-server start <--- should not ask for a password.
nicheplayer
First command ran without comment. Then I ran
and got
root@machine:/etc# cat /etc/group | emby
-bash: emby: command not found
so then I nanoed into /etc/group and found nicheplayer007 in the following places:
nicheplayer007:x:1000:
openvpn:x:1001:
openvpn_as:x:1002:
plex:x:113:
messagebus:x:114:
colord:x:115:
fuse:x:116:
emby:x:117:nicheplayer007
nicheplayer
I proceeded with your directions anyway, for the hell of it, and got
root@machine:/etc# su nicheplayer007
$ sudo /etc/init.d/emby-server start
hurricanehrndz
Well I'm beat for today. I heading to bed, I will see if I can try and track it down. It makes no sense to me. The group emby is in the sudoers and I made you part of that group.
  • Like 1
nicheplayer
I hear ya! Thanks a lot for your help!! I'll get it nailed down eventually!
hurricanehrndz
What's the permission of the emby file in sudoers.d folder
nicheplayer
:/etc/sudoers.d# ls -la
total 12
drwxr-xr-x   2 root root 4096 Dec 12 02:11 .
drwxr-xr-x 105 root root 4096 Dec 12 02:26 ..
-rwxr-xr-x   1 root root    0 Dec 12 02:11 emby
-r--r-----   1 root root  958 Mar  1  2013 README
hurricanehrndz
chmod 440 /etc/sudoers.d/emby
then try
su nicheplayer007
nicheplayer
FWIW, as soon as I do the
su nicheplayer007
line my command prompt turns into a $. When I run
from that $ prompt, I get
Oh well. A job for another day!
hurricanehrndz
I just tested it all on debian 7 without issue.
Please run
cat /etc/sudoers.d/emby
ls -lah /etc/sudoers.d/
nicheplayer
Hrm. Also, now when I do
as root I get
[FAIL] Starting emby-server daemon: failed!
hurricanehrndz
Ha ha, I did mention that I had not put the scripts through its usual paces.
  • Like 1
nicheplayer
Just returned me to the system prompt. Then:
root@machine:/# ls -lah /etc/sudoers.d/
total 12K
drwxr-xr-x   2 root root 4.0K Dec 12 02:11 .
drwxr-xr-x 105 root root 4.0K Dec 12 02:26 ..
-r--r-----   1 root root    0 Dec 12 02:11 emby
hurricanehrndz
Well there is nothing in the file... of course it's not going to work.
Try and edit the file and just copy and paste the lines.
Or download it to your home directory and then move them where there suppose to go.
nicheplayer
From this file?
