Ubuntu
hurricanehrndz
Okay found the issue and it will be fixed in next release for now, you can run the following and it should fix it for you.
sudo chmod +x /usr/lib/emby-server/restart.sh
  • Like 2
That seemed to fix it. Thank you very much!
  • Like 1
nicheplayer
I seem to be having this issue too with Debian 7. Tried the code above and got the following when I tried to restart via the web interface (I'm on server version Version 3.0.5781.4). I restarted via the command line, reloaded the page, and tried restart again. Only thing that happened the second time is that the SHUTDOWN button grayed it. Had to restart manually again....
Error Code NullReferenceException Message Object reference not set to an instance of an object Stack Trace at ServiceStack.ServiceStackHost.TryResolve[T] () <0x415cc720 + 0x0002c> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].AfterEachRequest (IRequest requestContext, ServiceStack.Host.TRequest request, System.Object response) <0x415ce000 + 0x00045> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].HandleException (IRequest request, ServiceStack.Host.TRequest requestDto, System.Exception ex) <0x4172e4e0 + 0x00090> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Execute (IRequest request, System.Object instance, ServiceStack.Host.TRequest requestDto) <0x415cbc90 + 0x00895> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Process (IRequest requestContext, System.Object instance, System.Object request) <0x415cb590 + 0x000c0> in <filename unknown>:0 at ServiceStack.Host.ServiceExec`1[TService].Execute (IRequest request, System.Object instance, System.Object requestDto, System.String requestName) <0x415cb300 + 0x00106> in <filename unknown>:0 at ServiceStack.Host.ServiceRequestExec`2[TService,TRequest].Execute (IRequest requestContext, System.Object instance, System.Object request) <0x415cb290 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf+<>c__DisplayClass11.<RegisterServiceExecutor>b__e (IRequest reqCtx, System.Object req) <0x415cb240 + 0x00040> in <filename unknown>:0 at ServiceStack.Host.ServiceController.ManagedServiceExec (ServiceStack.Host.ServiceExecFn serviceExec, IService service, IRequest request, System.Object requestDto) <0x415cac30 + 0x001a3> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf.<RegisterServiceExecutor>b__d (IRequest requestContext, System.Object dto) <0x415c8ba0 + 0x0022b> in <filename unknown>:0 at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest req) <0x415c8600 + 0x00098> in <filename unknown>:0 at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) <0x415c8550 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) <0x415c8520 + 0x00013> in <filename unknown>:0 at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) <0x415c8440 + 0x00077> in <filename unknown>:0 at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) <0x415ab270 + 0x00627> in <filename unknown>:0
hurricanehrndz
Please see if the restart script works manually from the command line. You can find it in /var/lib/emby-server
Sent from my D6603 using Tapatalk
maiky jonathan gomes
my friend , I'm using ubutu 15:04 , Emby only accepts films from the main hd how I put the secondary hd to be accepted into Emby ?
hurricanehrndz
Check user permissions, the user emby needs read and write.
Edited by hurricanehrndz
nicheplayer
I don't see it?
root@machine:/var/lib/emby-server# ls -la
total 44
drwxr-xr-x 11 nicheplayer007 emby 4096 Dec  6 16:39 .
drwxr-xr-x 38 root           root 4096 Dec  5 16:28 ..
drwxr-xr-x 12 nicheplayer007 emby 4096 Dec  9 23:24 cache
drwxr-xr-x  4 nicheplayer007 emby 4096 Dec  7 09:04 config
drwxr-xr-x  8 nicheplayer007 emby 4096 Dec 10 21:00 data
drwxr-xr-x  2 nicheplayer007 emby 4096 Dec  5 16:35 localization
drwxr-xr-x  2 nicheplayer007 emby 4096 Dec 11 21:55 logs
drwxr-xr-x  5 nicheplayer007 emby 4096 Dec  6 03:00 metadata
drwxr-xr-x  3 nicheplayer007 emby 4096 Dec  5 16:35 root
drwxr-xr-x  2 nicheplayer007 emby 4096 Dec  5 16:35 ssl
drwxr-xr-x  2 nicheplayer007 emby 4096 Dec  9 22:15 transcoding-temp
nicheplayer
But it IS in /usr/lib/emby-server#. Is that my problem?
nicheplayer
And when I run ./restart.sh from that directory, I get
restart: Unknown instance:
hurricanehrndz
It's in the right location. How did you start emby-sever
nicheplayer
Last time I started manually I used
/etc/init.d/emby-server start
Which worked. Will updating to the latest (.5) release help at all? I'm willing to give that a shot.
hurricanehrndz
Okay, well does /etc/init.d/emby-server restart work?
  • Like 1
nicheplayer
Yup! So I can restart from the command line but not from the server web interface. Go figure.
nicheplayer
Okay, well you can try the new restart script. It's not tested but I guess eh what the heck.
Replace the old one, with this one and report back:
https://raw.githubusercontent.com/hurricanehrndz/Emby.Build/ft_docker/builders/emby-server/debfiles/restart.sh
I notice the restart.sh file has -rwxr-xr-x permissions. Is that a problem? Here's the output (which I get in my browser when I hit restart server in the web interface):
Response Status Error Code NullReferenceException Message Object reference not set to an instance of an object Stack Trace at ServiceStack.ServiceStackHost.TryResolve[T] () <0x41f2eed0 + 0x0002c> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].AfterEachRequest (IRequest requestContext, ServiceStack.Host.TRequest request, System.Object response) <0x41f50f20 + 0x00041> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].HandleException (IRequest request, ServiceStack.Host.TRequest requestDto, System.Exception ex) <0x4202b310 + 0x00090> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Execute (IRequest request, System.Object instance, ServiceStack.Host.TRequest requestDto) <0x41f2e480 + 0x00885> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Process (IRequest requestContext, System.Object instance, System.Object request) <0x41f2ddb0 + 0x000bc> in <filename unknown>:0 at ServiceStack.Host.ServiceExec`1[TService].Execute (IRequest request, System.Object instance, System.Object requestDto, System.String requestName) <0x41f2db30 + 0x00106> in <filename unknown>:0 at ServiceStack.Host.ServiceRequestExec`2[TService,TRequest].Execute (IRequest requestContext, System.Object instance, System.Object request) <0x41f2dac0 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf+<>c__DisplayClass11.<RegisterServiceExecutor>b__e (IRequest reqCtx, System.Object req) <0x41f2da70 + 0x00040> in <filename unknown>:0 at ServiceStack.Host.ServiceController.ManagedServiceExec (ServiceStack.Host.ServiceExecFn serviceExec, IService service, IRequest request, System.Object requestDto) <0x41f2d4a0 + 0x0019f> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf.<RegisterServiceExecutor>b__d (IRequest requestContext, System.Object dto) <0x41f2b120 + 0x00217> in <filename unknown>:0 at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest req) <0x41f2abb0 + 0x00098> in <filename unknown>:0 at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) <0x41f2ab00 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) <0x41f2aad0 + 0x00013> in <filename unknown>:0 at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) <0x41f2a580 + 0x00077> in <filename unknown>:0 at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) <0x41f23ca0 + 0x0061f> in <filename unknown>:0
hurricanehrndz
Did you try the restart script on its own? Are you verifying that the process number is the same? The permissions are perfectly fine.
Please print /etc/sudoers.d/emby
followed by ps -aux |grep emby
then /usr/lib/emby-server/restart.sh  <---- ensure this is the new script that i just posted
then run ps -aux|grep emby
Please print everything that I have asked for.
nicheplayer
I ran /etc/init.d/emby-server restart successfully. Is that what you mean?
No. How should I?
#Allow emby to start, stop and restart itself
emby ALL=(ALL) NOPASSWD: /bin/systemctl restart emby-server.service
emby ALL=(ALL) NOPASSWD: /etc/init.d/emby-server *
emby ALL=(ALL) NOPASSWD: /usr/sbin/service emby-server *
emby ALL=(ALL) NOPASSWD: /usr/sbin/invoke-rc.d emby-server *
#Allow the server to mount iso images
emby ALL=(ALL) NOPASSWD: /bin/mount
emby ALL=(ALL) NOPASSWD: /bin/umount
Defaults:emby !requiretty
warning: bad ps syntax, perhaps a bogus '-'?
See http://gitorious.org/procps/procps/blobs/master/Documentation/FAQ
root     12326  0.0  0.0  37072  1440 pts/0    S    23:25   0:00 su -s /bin/sh -c exec "$0" "$@" nicheplayer007 -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
1000     12334  3.5 13.8 598840 290076 ?       Ssl  23:25   0:31 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     12599  0.0  0.0   7724   940 pts/0    S+   23:39   0:00 grep emby
Done. No feedback.
1000     12334  3.3 13.8 598840 290084 ?       Ssl  23:25   0:34 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     12657  0.0  0.0   7724   944 pts/0    S+   23:42   0:00 grep emby
hurricanehrndz
niceplayer007 ALL=(ALL) NOPASSWD: /bin/systemctl restart emby-server.service
niceplayer007 ALL=(ALL) NOPASSWD: /etc/init.d/emby-server *
niceplayer007 ALL=(ALL) NOPASSWD: /usr/sbin/service emby-server *
niceplayer007 ALL=(ALL) NOPASSWD: /usr/sbin/invoke-rc.d emby-server *
niceplayer007 ALL=(ALL) NOPASSWD: /bin/mount
niceplayer007 ALL=(ALL) NOPASSWD: /bin/umount
Defaults:niceplayer007 !requiretty
Edit /etc/sudoers.d/emby
replace emby with niceplayer007
Thanks for the feedback, update will fix this in the future.
  • Like 1
nicheplayer
Here's what /etc/sudoers.d/emby looks like now:
nicheplayer007 ALL=(ALL) NOPASSWD: /bin/systemctl restart emby-server.service
nicheplayer007 ALL=(ALL) NOPASSWD: /etc/init.d/emby-server *
nicheplayer007 ALL=(ALL) NOPASSWD: /usr/sbin/service emby-server *
nicheplayer007 ALL=(ALL) NOPASSWD: /usr/sbin/invoke-rc.d emby-server *
nicheplayer007 ALL=(ALL) NOPASSWD: /bin/mount
nicheplayer007 ALL=(ALL) NOPASSWD: /bin/umount
Defaults:nicheplayer007 !requiretty
And here's what I get after trying a restart (via http://MYIPADDRESS:8096/web/dashboard.html):
Response Status
Error CodeNullReferenceExceptionMessageObject reference not set to an instance of an objectStack Trace at ServiceStack.ServiceStackHost.TryResolve[T] () <0x41b31870 + 0x0002c> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].AfterEachRequest (IRequest requestContext, ServiceStack.Host.TRequest request, System.Object response) <0x41b36800 + 0x00045> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].HandleException (IRequest request, ServiceStack.Host.TRequest requestDto, System.Exception ex) <0x41bf07c0 + 0x00090> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Execute (IRequest request, System.Object instance, ServiceStack.Host.TRequest requestDto) <0x41b30de0 + 0x00899> in <filename unknown>:0 at ServiceStack.Host.ServiceRunner`1[TRequest].Process (IRequest requestContext, System.Object instance, System.Object request) <0x41b306e0 + 0x000c4> in <filename unknown>:0 at ServiceStack.Host.ServiceExec`1[TService].Execute (IRequest request, System.Object instance, System.Object requestDto, System.String requestName) <0x41b30450 + 0x0010a> in <filename unknown>:0 at ServiceStack.Host.ServiceRequestExec`2[TService,TRequest].Execute (IRequest requestContext, System.Object instance, System.Object request) <0x41b303e0 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf+<>c__DisplayClass11.<RegisterServiceExecutor>b__e (IRequest reqCtx, System.Object req) <0x41b30390 + 0x0003c> in <filename unknown>:0 at ServiceStack.Host.ServiceController.ManagedServiceExec (ServiceStack.Host.ServiceExecFn serviceExec, IService service, IRequest request, System.Object requestDto) <0x41b2fda0 + 0x001ab> in <filename unknown>:0 at ServiceStack.Host.ServiceController+<>c__DisplayClassf.<RegisterServiceExecutor>b__d (IRequest requestContext, System.Object dto) <0x41b2d8e0 + 0x00223> in <filename unknown>:0 at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest req) <0x41b2d340 + 0x000a0> in <filename unknown>:0 at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) <0x41b2d290 + 0x0005b> in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) <0x41b2d260 + 0x00013> in <filename unknown>:0 at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) <0x41b2ccf0 + 0x00083> in <filename unknown>:0 at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) <0x41b26000 + 0x00643> in <filename unknown>:0
hurricanehrndz
The log from emby does nothing for me, please run the restart script again from the command line. And run the ps aux | grep commands again. Please print the contents of restart.sh and the permissions as well.
nicheplayer
# /etc/init.d/emby-server restart
[ ok ] Stopping emby-server daemon:[....] apparently already stopped.
. ok
[ ok ] Starting emby-server daemon:.
Does it matter from which directory I do that?
ps -aux |grep emby
root     13566  0.0  0.0  37072  1436 pts/0    S    00:25   0:00 su -s /bin/sh -c exec "$0" "$@" nicheplayer007 -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
1000     13574 10.4 14.3 603992 301104 ?       Ssl  00:25   0:18 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     13658  0.0  0.0   7724   940 pts/0    R+   00:28   0:00 grep emby
hurricanehrndz
lol!
I need you to run
ps aux | grep emby
sudo -u nicheplayer007 /usr/lib/emby-server/restart.sh
ps aux | grep emby
ls -la /usr/lib/emby-server/restart.sh
cat /usr/lib/emby-server/restart.sh
Thanks. Please correct any typos, I might have typed the user name wrong. You did well previously.
We need to get /usr/lib/emby-server/restart.sh to work, otherwise the web interface never will. So do not worry about the interface.
nicheplayer
ps aux | grep emby
at the command line returns
1000     13574  3.8 14.3 604012 301248 ?       Ssl  00:25   0:33 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     13862  0.0  0.0   7724   940 pts/0    S+   00:40   0:00 grep emby
When I run
I get a prompt to enter the password for nicheplayer007. I do, hit return, and get no feedback, just a return to the command prompt.
ps aux | grep emby
1000     13574  3.3 17.0 660492 356560 ?       Ssl  00:25   0:45 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh
root     14025  0.0  0.0   7724   944 pts/0    S+   00:48   0:00 grep emby
-rwxr-xr-x 1 root root 778 Dec 11 23:20 /usr/lib/emby-server/restart.sh
#!/bin/bash
NAME=emby-server
restart_cmds=("/bin/s6-svc -t /var/run/s6/services/${NAME}" \
  "systemctl restart ${NAME}.service" \
  "service ${NAME} restart" \
  "/etc/init.d/${NAME} restart" \
  "invoke-rc.d ${NAME} restart")
PIDFILE=`find /var/run -name "emby*.pid" -print -quit`
[ -n "$PIDFILE" ] && EMBY_PID=`cat ${PIDFILE} 2> /dev/null || true`
for restart_cmd in "${restart_cmds[@]}"; do
  exec /usr/bin/sudo $restart_cmd > /dev/null 2>&1 || true
  sleep 1
  if ! kill -0 $EMBY_PID > /dev/null; then
    break
  fi
done
# is emby still running? Might have been manually started
if kill -0 $EMBY_PID > /dev/null 2>&1; then
  CPIDS=$(pgrep -P $EMBY_PID)
  sleep 2 && kill -KILL $CPIDS
  kill -TERM $CPIDS > /dev/null 2>&1
  # restart it
  exec emby-server start &
fi
hurricanehrndz
Are you logged in as nicheplayer007?
and do you get a prompt when you just run
nicheplayer
I was logged in as root. I'm logged in as nicheplayer007 now.
When I do
as nicheplayer007, I get
$ /usr/lib/emby-server/restart.sh
[sudo] password for nicheplayer007:
I get the same thing when doing it as root. No feedback other than a return to the system prompt.
