hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 (edited) Can you guys who are having issues adding media to your library install the beta and report back. sudo apt-get install emby-server-beta. Edited December 5, 2015 by hurricanehrndz
rlw6534 4 Posted December 5, 2015 Posted December 5, 2015 Can you guys who are having issues adding media to your library install the beta and report back. sudo apt-get install emby-server-beta. Can't get the service to start: rick@rick-ubuntu:~$ sudo systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: inactive (dead) since Sat 2015-12-05 18:43:54 EST; 2s ago Process: 2761 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Process: 2737 ExecStart=/usr/bin/emby-server start (code=exited, status=0/SUCCESS) Main PID: 2737 (code=exited, status=0/SUCCESS) Dec 05 18:43:53 rick-ubuntu systemd[1]: Started Emby Media Server. Dec 05 18:43:53 rick-ubuntu su[2737]: Successful su for emby by root Dec 05 18:43:53 rick-ubuntu su[2737]: + ??? root:emby Dec 05 18:43:53 rick-ubuntu su[2737]: pam_unix(su:session): session opened for user emby by (uid=0)
hurricanehrndz 149 Posted December 5, 2015 Posted December 5, 2015 Beta needs libsqlite Dev installed, I haven't address that issue yet on the beta build Sent from my D6603 using Tapatalk
rlw6534 4 Posted December 6, 2015 Posted December 6, 2015 No joy. It doesn't throw the error, but it doesn't add the path either. You can go back and add the folder to the library, but it doesn't scan - just a brief flash for the progress bar...
rlw6534 4 Posted December 6, 2015 Posted December 6, 2015 So I reverted back to the non-beta and the folders I manually added in the beta (that wouldn't scan) where still showing. I pressed the scan library button, and they scanned into the db... I tried playing a few movies and they do work... Still can't add any new folders, though... Guess I can go back to the beta and add the rest to get a working setup...
Luke 42243 Posted December 6, 2015 Author Posted December 6, 2015 For those running from source, I've checked in a fix for the above issue with adding folders. The issue is not actually part of the tagged 3.0.5781.4 release, it's just something that was checked in after the fact, and now it's fixed. Thanks.
maiky jonathan gomes 0 Posted December 6, 2015 Posted December 6, 2015 in my still not putting this folder I need to do to return to work
hurricanehrndz 149 Posted December 6, 2015 Posted December 6, 2015 I have triggered a new stable build. Please run a reinstall in half an hour. apt-get install -reinstall emby-server
darkblade 1 Posted December 6, 2015 Posted December 6, 2015 I just did a re-install and now I can add media!! Thanks for the fix! 1
Web_Spider 1 Posted December 8, 2015 Posted December 8, 2015 I'm seeing some strangeness upgrading emby-server on Ubuntu 14 LTS just now. It would appear that a new package (libembymagick) is conflicting with another dependency, imagemagick. Can I safely remove the system imagemagick library, which also removes about 38 dependant packages? (Reading database ... 82693 files and directories currently installed.) Preparing to unpack .../libembymagickcore-6.q8-2_8%3a6.9.2-8_amd64.deb ... Unpacking libembymagickcore-6.q8-2:amd64 (8:6.9.2-8) ... dpkg: error processing archive /var/cache/apt/archives/libembymagickcore-6.q8-2_8%3a6.9.2-8_amd64.deb (--unpack): trying to overwrite '/usr/lib/x86_64-linux-gnu/libMagickCore-6.Q8.so.2.0.0', which is also in package libmagickcore-6.q8-2:amd64 8:6.9.1-2 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Preparing to unpack .../libembymagickwand-6.q8-2_8%3a6.9.2-8_amd64.deb ... Unpacking libembymagickwand-6.q8-2:amd64 (8:6.9.2-8) ... dpkg: error processing archive /var/cache/apt/archives/libembymagickwand-6.q8-2_8%3a6.9.2-8_amd64.deb (--unpack): trying to overwrite '/usr/lib/x86_64-linux-gnu/libMagickWand-6.Q8.so.2.0.0', which is also in package libmagickwand-6.q8-2:amd64 8:6.9.1-2 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/libembymagickcore-6.q8-2_8%3a6.9.2-8_amd64.deb /var/cache/apt/archives/libembymagickwand-6.q8-2_8%3a6.9.2-8_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1) A package failed to install. Trying to recover: Press Return to continue.
Web_Spider 1 Posted December 8, 2015 Posted December 8, 2015 Just found that this is documented here, for some reason, the forum search didnt pick it up: http://emby.media/community/index.php?/topic/28188-massive-update-for-debian-and-ubuntu/
leezy 1 Posted December 9, 2015 Posted December 9, 2015 I cannot restart the server using the web gui on xubuntu 15.10. Is this issue being worked on?
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 (edited) Nope should work. This was tested very thoroughly, you might need to hit refresh after you have hit restart. Did you actually ensure that it didn't restart, but checking out the process ids? Please do a systemctl status emby-server before hitting restart and one afterwards. If you are running as a different user other than emby that might be a problem. Edited December 9, 2015 by hurricanehrndz
leezy 1 Posted December 9, 2015 Posted December 9, 2015 When I refresh the page it says web page is not available and I have to manually start the server again through terminal commands.
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 (edited) Open a terminal and type sudo systemctl status emby-server, please paste the contents of the output here. Edited December 9, 2015 by hurricanehrndz
leezy 1 Posted December 9, 2015 Posted December 9, 2015 leezy@LeezyServer:~$ systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled; vendor preset: enabled) Active: active (running) since Wed 2015-12-09 13:49:39 EST; 1min 8s ago Main PID: 25461 (su) CGroup: /system.slice/emby-server.service ‣ 25461 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_P... Dec 09 13:49:39 LeezyServer systemd[1]: Started Emby Media Server. Dec 09 13:49:39 LeezyServer su[25461]: Successful su for emby by root Dec 09 13:49:39 LeezyServer su[25461]: + ??? root:emby Dec 09 13:49:39 LeezyServer su[25461]: pam_unix(su:session): session opened...0) Hint: Some lines were ellipsized, use -l to show in full. leezy@LeezyServer:~$ systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled; vendor preset: enabled) Active: inactive (dead) Dec 09 13:13:10 LeezyServer su[24922]: + ??? root:emby Dec 09 13:13:10 LeezyServer su[24922]: pam_unix(su:session): session opened...0) Dec 09 13:15:23 LeezyServer systemd[1]: Started Emby Media Server. Dec 09 13:15:23 LeezyServer su[25059]: Successful su for emby by root Dec 09 13:15:23 LeezyServer su[25059]: + ??? root:emby Dec 09 13:15:23 LeezyServer su[25059]: pam_unix(su:session): session opened...0) Dec 09 13:49:39 LeezyServer systemd[1]: Started Emby Media Server. Dec 09 13:49:39 LeezyServer su[25461]: Successful su for emby by root Dec 09 13:49:39 LeezyServer su[25461]: + ??? root:emby Dec 09 13:49:39 LeezyServer su[25461]: pam_unix(su:session): session opened...0) Hint: Some lines were ellipsized, use -l to show in full. leezy@LeezyServer:~$
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 How did you start emby to being with Sent from my D6603 using Tapatalk
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 Maybe that's the issue, 15.10 uses systemd, please start with systemctl start emby-sever and then try the restart button Sent from my D6603 using Tapatalk
leezy 1 Posted December 9, 2015 Posted December 9, 2015 I tried it but it did not make a difference. Emby server shuts down and does not restart.
hurricanehrndz 149 Posted December 9, 2015 Posted December 9, 2015 Okay, well. I will do further testing. 1
