Kygeek 0 Posted October 5, 2015 Posted October 5, 2015 i also noticed the same thing on my machine. it does consume cpu at least 1% of the time. I know there are lots of scheduled tasks. i also have the file watch feature turned on. I would guess that has something to do with it. Other than that I'm not sure. Im sure someone can answer that though. Im not very familiar with mono apps.
Cypress 0 Posted October 5, 2015 Posted October 5, 2015 You just need to install ffmpeg. The service script will find the system binaries for ffmpeg and use those instead. franky384, Has been kind enough to have already compiled ffmpeg for arm. You can download it here: https://www.dropbox.com/s/vitj7bk9ho6acgb/ffmpeg_build.tar.gz?dl=0 All you should need to do, is install that and start emby with the service script. I have the same 'ffmpeg unvailable' problem. I'm new to ubuntu and i can't seem to figure out how to install the compiled ffmpeg.tar. Do i extract the files to a specific location? What steps do i need to do to get the ffmpeg library and get Emby working? thanx!
haeffnkr 3 Posted October 6, 2015 Posted October 6, 2015 I get this error when I try to install on my linux Mint 17 build haeffnkr@wy1450 ~ $ sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: mediainfo : Depends: libmediainfo0 (>= 0.7.52) but it is not going to be installed Depends: libzen0 (>= 0.4.23) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Can someone please help? thanks Kevin
stephen_d_hill 1 Posted October 9, 2015 Posted October 9, 2015 i also noticed the same thing on my machine. it does consume cpu at least 1% of the time. I know there are lots of scheduled tasks. i also have the file watch feature turned on. I would guess that has something to do with it. Other than that I'm not sure. Im sure someone can answer that though. Im not very familiar with mono apps. Disabling the file watch setting does not change this.
hurricanehrndz 149 Posted October 9, 2015 Posted October 9, 2015 I get this error when I try to install on my linux Mint 17 build haeffnkr@wy1450 ~ $ sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: mediainfo : Depends: libmediainfo0 (>= 0.7.52) but it is not going to be installed Depends: libzen0 (>= 0.4.23) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Can someone please help? thanks Kevin I would use docker in your situation Sent from my D6603 using Tapatalk
hurricanehrndz 149 Posted October 9, 2015 Posted October 9, 2015 Disabling the file watch setting does not change this. This is question best answered by Luke I think. Hopefully this will draw his attention.
Luke 42242 Posted October 9, 2015 Author Posted October 9, 2015 1% is going to be really hard to chase down. when it climbs higher, then we can look at it.
hurricanehrndz 149 Posted October 9, 2015 Posted October 9, 2015 I get this error when I try to install on my linux Mint 17 build haeffnkr@wy1450 ~ $ sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: mediainfo : Depends: libmediainfo0 (>= 0.7.52) but it is not going to be installed Depends: libzen0 (>= 0.4.23) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Can someone please help? thanks Kevin Have you tried apt-get -f install?
key98 0 Posted October 13, 2015 Posted October 13, 2015 Can anyone please help me. i have emby on my Linux server (ubuntu 15.04) i have noticed that when i apply update throught the emby server site address it installs the update and then when it restarts it crashes and wont restart. this happens even if i just do a restart and the only way to start emby back up is through comand line. Can someone please help me to fix this problem as i would like to be able to just restart server directly from emby.
hurricanehrndz 149 Posted October 13, 2015 Posted October 13, 2015 Are you talking about plugins and having the server restart after a plugin is installed? If that is the case, I wasn't aware that the restart function was not working in 15.04.
thefirstofthe300 292 Posted October 19, 2015 Posted October 19, 2015 Probably due to the systemd implementation. You will need to check the version number and run systemctl restart emby-server if it is 15.04.
Proteus 0 Posted October 22, 2015 Posted October 22, 2015 I get this error when I try to install on my linux Mint 17 build haeffnkr@wy1450 ~ $ sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: mediainfo : Depends: libmediainfo0 (>= 0.7.52) but it is not going to be installed Depends: libzen0 (>= 0.4.23) but it is not going to be installed E: Unable to correct problems, you have held broken packages. Can someone please help? thanks Kevin Kevin, I got the same error the first time I tired to install. Linux Mint 17 is based on Ubuntu 14.04. I made the mistake of trying to install on Ubuntu 14.10. Make sure your /etc/apt/sources.list.d/emby-server.list indicates xUbuntu_14.04. That should resolve the dependency problems.
Dagur 3 Posted October 24, 2015 Posted October 24, 2015 I made a pretty dumb mistake and upgrade to 15.10 without checking if Emby was ready for it. Does anyone have an ETA? Would it be a good idea for me to switch to Docker?
hurricanehrndz 149 Posted October 24, 2015 Posted October 24, 2015 I hope to have it done by Sunday. Can you please share the error you got during install Sent from my D6603 using Tapatalk
hurricanehrndz 149 Posted October 24, 2015 Posted October 24, 2015 Docker is the way to go in my opinion. Sent from my D6603 using Tapatalk
Dagur 3 Posted October 24, 2015 Posted October 24, 2015 I hope to have it done by Sunday. Can you please share the error you got during install Sent from my D6603 using Tapatalk No error per se, Ubuntu just warned me that the third party source would be disabled. I tried enabling it again but I got an error that libmediainfo0 is needed but wouldn't be installed. If I tried installing it manually I got dagur@nuc:~$ sudo apt install libmediainfo0 [sudo] password for dagur: Reading package lists... Done Building dependency tree Reading state information... Done Package libmediainfo0 is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source However the following packages replace it: libmediainfo0v5:i386 libmediainfo0v5 E: Package 'libmediainfo0' has no installation candidate
Dagur 3 Posted October 24, 2015 Posted October 24, 2015 Docker is the way to go in my opinion. Sent from my D6603 using Tapatalk Thanks! I'll check it out
hurricanehrndz 149 Posted October 24, 2015 Posted October 24, 2015 Perfect, yes that will be fixed. Sent from my D6603 using Tapatalk
Tha-Vini 0 Posted October 25, 2015 Posted October 25, 2015 Perfect, yes that will be fixed. Sent from my D6603 using Tapatalk Hello Hurricane.... I am new here, I also found out that after upgrading to ubuntu 15.10 this very nice piece of software was broken. Is the fix still planned for today or in the very near future? This was my error: sudo apt-get -f install emby-server Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: emby-server : Depends: libmediainfo0 but it is not going to be installed E: Unable to correct problems, you have held broken packages. thanks already. And keep up the good work. Best regards, Vincent
hurricanehrndz 149 Posted October 25, 2015 Posted October 25, 2015 I'm hoping to get the fixed out tonight. Sent from my D6603 using Tapatalk
alius_no 0 Posted October 25, 2015 Posted October 25, 2015 Any guides for installing it on 15.10? Does 15.04 still apply? Thanks!
hurricanehrndz 149 Posted October 25, 2015 Posted October 25, 2015 Yes, but please don't try and install until tomorrow Sent from my D6603 using Tapatalk 1
alius_no 0 Posted October 25, 2015 Posted October 25, 2015 Yes, but please don't try and install until tomorrow Sent from my D6603 using Tapatalk Alright, many thanks
jbc 0 Posted October 26, 2015 Posted October 26, 2015 (edited) Hi: Thanks... am in same boat. Upgraded from perfectly functioning 15.04 to 15.10. I should know better. Keep up the great work by the way, am really enjoying Emby. Edited October 26, 2015 by jbc
alius_no 0 Posted October 26, 2015 Posted October 26, 2015 Yeah please give us a heads-up in here when it's functioning correctly!!
