starbuckz 0 Posted September 22, 2015 Posted September 22, 2015 Google chrome does not even give an error, it just stops on a black background. Log is similar: ffmpeg version 0.8.17-4:0.8.17-0ubuntu0.12.04.1, Copyright (c) 2000-2014 the Libav developers built on Mar 16 2015 13:26:50 with gcc 4.6.3 configuration: --extra-version='4:0.8.17-0ubuntu0.12.04.1' --arch=amd64 --prefix=/usr --libdir=/usr/lib/x86_64-linux-gnu --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-libfreetype --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/x86_64-linux-gnu --enable-shared --disable-static libavutil 51. 22. 3 / 51. 22. 3 libavcodec 53. 35. 0 / 53. 35. 0 libavformat 53. 21. 1 / 53. 21. 1 libavdevice 53. 2. 0 / 53. 2. 0 libavfilter 2. 15. 0 / 2. 15. 0 libswscale 2. 1. 0 / 2. 1. 0 libpostproc 52. 0. 0 / 52. 0. 0 The ffmpeg program is only provided for script compatibility and will be removed in a future release. It has been deprecated in the Libav project to allow for incompatible command line syntax improvements in its replacement called avconv (see Changelog for details). Please use avconv instead. [matroska,webm @ 0x2397880] Probed with size=2048 and score=100 st:0 removing common factor 1000000 from timebase st:1 removing common factor 1000000 from timebase [h264 @ 0x239a400] err{or,}_recognition separate: 1; 1 [h264 @ 0x239a400] err{or,}_recognition combined: 1; 1 [h264 @ 0x239a400] Unsupported bit depth: 0 [ac3 @ 0x239c280] err{or,}_recognition separate: 1; 1 [ac3 @ 0x239c280] err{or,}_recognition combined: 1; 1 [ac3 @ 0x239c280] Unsupported bit depth: 0 [h264 @ 0x239a400] no picture [matroska,webm @ 0x2397880] All info found [matroska,webm @ 0x2397880] Estimating duration from bitrate, this may be inaccurate Input #0, matroska,webm, from 'file:/home/owner/Videos/Movies/Inside.Polizei.-.Einsatz.auf.der.Autobahn.GERMAN.DOKU.720p.HDTV.x264-love/Inside.Polizei.-.Einsatz.auf.der.Autobahn.GERMAN.DOKU.720p.HDTV.x264-love.mkv': Metadata: title : Inside.Polizei.-.Einsatz.auf.der.Autobahn.GERMAN.DOKU.720p.HDTV.x264-love Duration: 00:43:04.84, start: 0.000000, bitrate: 384 kb/s Stream #0.0, 42, 1/1000: Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 1/50, 25 fps, 25 tbr, 1k tbn, 50 tbc (default) Metadata: title : love Stream #0.1(ger), 49, 1/1000: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s (default) Unrecognized option 'codec:v:0' Failed to set value 'libx264' for option 'codec:v:0' I'll try updating ffmpeg an will report back.
Luke 42242 Posted September 22, 2015 Author Posted September 22, 2015 Ok, in Chrome, looks like you're also missing libx264,
hurricanehrndz 149 Posted September 22, 2015 Posted September 22, 2015 I personally think it would be best to adjust the cont and point to the ffmpeg downloaded by emby Sent from my D6603 using Tapatalk
Ho2x 5 Posted September 22, 2015 Posted September 22, 2015 (edited) Hi, I have a problem since the last update, When I watch movies to AC3 / MP4 / H264 since my Chromecast and only through this one, I have a bug sounds every X seconds like a TAC in the sounds, I said I did test via plex and I think it is since the last update 3.0.5724.5 server. I also did a test by enabling / disabling the AC3 passthrough, without result. I have two Chromecast, I did a test on the two and the problem is the same. Do you have an idea of the problem? (sorry for my english I am french! ) My server is Ubuntu 14.04 Thank's ! Example : ( 14-21 SEC ) https://www.youtube.com/watch?v=cIAVzvYNk88 Edited September 22, 2015 by Ho2x
Ho2x 5 Posted September 24, 2015 Posted September 24, 2015 The problem is the same 5.1 with AAC file and I also lag 5-10 sec from time to time , that I did not have with the previous version , still under Chromecast .
Luke 42242 Posted September 24, 2015 Author Posted September 24, 2015 Thank you for the video. Please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ to provide additional information about media playback issues. thanks.
crimsonred 0 Posted September 24, 2015 Posted September 24, 2015 Hi everyone, Today I found out that I'm not able to add a media location for any of my libraries, although I can create a new library. I tried adding a media location to my previously created libraries (which still have a location added on them), but I click the + button and nothing happens. I've tried to access this in Chrome, Chrome Canary, Firefox, Safari, and the Android app. Couldn't get it to work. I tried to delete a previously added location, and that works because a dialog pops up asking me to confirm. Is there something I'm doing wrong here?
Luke 42242 Posted September 24, 2015 Author Posted September 24, 2015 Hi everyone, Today I found out that I'm not able to add a media location for any of my libraries, although I can create a new library. I tried adding a media location to my previously created libraries (which still have a location added on them), but I click the + button and nothing happens. I've tried to access this in Chrome, Chrome Canary, Firefox, Safari, and the Android app. Couldn't get it to work. I tried to delete a previously added location, and that works because a dialog pops up asking me to confirm. Is there something I'm doing wrong here? what version of the server?
crimsonred 0 Posted September 24, 2015 Posted September 24, 2015 what version of the server? Sorry, should have mentioned that. Version 3.0.5724.3
Luke 42242 Posted September 24, 2015 Author Posted September 24, 2015 Try updating to the new version. 1
thunderthumbs 0 Posted September 24, 2015 Posted September 24, 2015 I'm trying to update my emby server to the latest beta. Currently I'm on 3.0.5713.6. In my server information it says that version 3.0.5724.3 is available for download. However whenever I try to update through apt-get it says there are no updates. I'll uninstall emby-server-beta and reinstall it and it installs 3.0.5713.6. Any help would be appreciated.
crimsonred 0 Posted September 24, 2015 Posted September 24, 2015 Try updating to the new version. Thank you, that worked!
thefirstofthe300 292 Posted September 24, 2015 Posted September 24, 2015 I'm trying to update my emby server to the latest beta. Currently I'm on 3.0.5713.6. In my server information it says that version 3.0.5724.3 is available for download. However whenever I try to update through apt-get it says there are no updates. I'll uninstall emby-server-beta and reinstall it and it installs 3.0.5713.6. Any help would be appreciated. It sounds like you might be on an old ppa. Try purging the ppa that you have currently from your config and then reinstalling using the instructions on the emby.media/downloads page.
Ho2x 5 Posted September 25, 2015 Posted September 25, 2015 (edited) Thank you for the video. Please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ to provide additional information about media playback issues. thanks. Emby 3.0.5724.5 Ubuntu 14.04.3 LTS 64Bits I reinstalled everything ( ffmpeg , Emby ...) No result still the same problem . I put the log in Attach Files And the video that goes with log https://www.youtube.com/watch?v=t-YoSKJwARs server-63578778401.txt transcode-4baac1d0-f85e-4fff-96df-2a0a5561bcbe.txt Edited September 25, 2015 by Ho2x
hurricanehrndz 149 Posted September 25, 2015 Posted September 25, 2015 Try uninstalling ffmpeg Sent from my D6603 using Tapatalk
Ho2x 5 Posted September 25, 2015 Posted September 25, 2015 (edited) sudo apt-get --purge remove ffmpeg sudo apt-get --purge autoremove sudo apt-get update sudo apt-get dist-upgrade sudo apt-get install ffmpeg reboot The problem is still present ... I really inpression that it is up to since the last official update , after I'm wrong can be ! I recall that the bug is only through Chromecast from the web no problem! Edited September 25, 2015 by Ho2x
Kygeek 0 Posted October 1, 2015 Posted October 1, 2015 This may be way OT, but i had a lot of issues trying to install MB from the repos. I spent a lot of time fixing dep issues etc etc. I just decided to #1 compile imagemagick the right way (i used all the deps from ubuntu repos) #2 use the mono version in repos #3 use the MB source. I probably spent 1/4 of the time installing from source than I did with all those dep issues. I am using Ubuntu 15.04 server. Installed it on an old Dell 1950. Quad Core Xeon with only 2GB of ram. (pxe boot) It works flawlessly. All video plays. Transcoding works perfect to at least two devices at once and its very stable. Most of my devices are DLNA. We have Dish Network in the house so we have a Hopper and Joey's. I modified the Joey DLNA profile to recognize my hopper with that profile instead of the generic. It works so well i am a supporter now. I used PLEX media server on a much better machine before and had a lot less luck with it. PLEX didn't serve my dishnet boxes well at all. It was totally hit or miss and quite annoying. Great work guys. If you think it would be beneficial i could write a HOWTO on the source compile stuff. Getting ImageMagick right is probably the toughest part. Many --with-blah=yes and --with-blah=no switches. The rest of it is no biggie. Much Much easier than apt-get this and apt-get install -f etc etc. Great Work Ill be sticking around!
Luke 42242 Posted October 1, 2015 Author Posted October 1, 2015 Well, done, thanks! Maybe you could also share some tips on how the packages can be improved to help them work on first try, thanks.
Kygeek 0 Posted October 1, 2015 Posted October 1, 2015 I can do that sure. I haven't honestly looked into it far enough to know the exact issue. It seems to me i was having some conflicts with different repos i had installed on my system. It was a fairly new install as well. I usually go generate a custom sources.list first thing though so i had several non-standard repos in there. I will re-install on a vmware machine with just standard repos so that i can try and help out there. If there are issues with other distros as well i can look at those too. Im pretty familiar with ubuntu, and Centos and their variants in production environments. Might be able to help out some if needed.
bearfamily 0 Posted October 3, 2015 Posted October 3, 2015 Installed emby on Ubuntu 14.04. Setup went fine, but now choosing library locations isn't working. It seems when I try to specify the path it will only go so far as locating my user (e.g. media/user). If I try to go further (/media/lane/MediaLibrary) it just blanks out the path selection space. Has anyone else ever seen this behavior?
stephen_d_hill 1 Posted October 4, 2015 Posted October 4, 2015 Really great media software guys, I currently have this installed along with Plex and Serviio, and in my mind is the best of the bunch. I have one gripe though.....CPU usage of the server. On my Ubuntu 14.04 server, I notice that emby is consuming 1% CPU all the time. This is somewhat odd, as I would have expected it to be idle unless I have a client connected to it, or it's downloading metadata. Plex and Serviio are completely idle. Here's a snippet from my 'top' output on my server, ordered by TIME, with emby always at the top by a massive distance: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2815 emby 20 0 1262316 339372 20056 S 1.0 4.2 66:53.22 mono-sgen 4786 stephen 20 0 3051520 732216 14008 S 0.0 9.1 3:51.87 java (Serviio) 4541 squeeze+ 20 0 687520 565504 10756 S 0.3 7.0 3:39.36 squeezebox+ 2933 plex 19 -1 534108 72736 21540 S 0.0 0.9 3:20.74 Plex Media+ 3084 plex 35 15 1270972 78336 10360 S 0.0 1.0 1:52.82 python What's it doing all that time?
hurricanehrndz 149 Posted October 4, 2015 Posted October 4, 2015 Installed emby on Ubuntu 14.04. Setup went fine, but now choosing library locations isn't working. It seems when I try to specify the path it will only go so far as locating my user (e.g. media/user). If I try to go further (/media/lane/MediaLibrary) it just blanks out the path selection space. Has anyone else ever seen this behavior? This is usually a permission issue.
Ho2x 5 Posted October 5, 2015 Posted October 5, 2015 (edited) To return to my problem sounds via Chromecast , I noticed that everything in log x Appear minute this message : Enter command: <target>|all <time>|-1 <command>[ <argument>]Parse error, at least 3 arguments were expected, only -1 given in string '' I do not know if this will help you !I give you the logs with . server.txt transcodage.txt Edited October 5, 2015 by Ho2x
Kygeek 0 Posted October 5, 2015 Posted October 5, 2015 that is most definitely a permission issue. the server is running as a different user than the media library directory you are pointing at. you will either need to change the user the server runs as or you can use groups to fix the issue. The server runs as user media browser and group mediabrowser. set your library location to be owned by your user and group mediabrowser so if your user is lane and your media library is /media/lane/medialibrary do this sudo chown lane:medialibrary -R /media/lane/medialibrary sudo chmod g+rx -R /media/lanel/medialibrary do you have an external disk connected and thats why you chose /media ? usually on ubuntu /media is where media is mounted. i.e. external drives, usb media, carom/dvdrom etc. i wouldn't just chmod 777 -R everything either... thats not safe and very insecure. i run my server as my user and keep everything contained in my home dir. i still had to group things because i use couchpotato, sabnzb, and transmission. if that doesn't help please let us know if your using an external drive as well as what file system is on the drive etc etc. that makes the difference as well.
