Ubuntu
what browser did you test with? i just tried with chrome and it seemed to be fine
If you're referring to me, I tested mine w/ chrome
I decided to install on my Ubuntu server, but I have run into a couple of problems....
Dashboard tells me there is an update, so I ran the usual sudo apt-get update and I got a 404 not found from launchpad.
Also I cannot path substitution to work as the movie folders/files are located on a Nas but as an smb share, I have read through here and tried smb://<servername>/<sharename>/ restarted the service but nothing. The other option was to perhaps edit fstab and see if it worked that way.
Many thanks.
hurricanehrndz
Please wait for the new installation instructions to be posted on the site. The ppa has been killed.
Thanks, should I do a remove and wait.... :)
I have a NAS and it works fine, but similar to what you said, I have my share automounted on boot via fstab so emby thinks it's just part of the filesystem
hurricanehrndz
Yes, don't purge though if you do not wish to rebuild your library.
I've 'nearly' got that sorted.... ;)  think I have made an error somewhere because doing sudo mount -a I needed a password....but it's moving in the right direction....at least they started to populate the folder  :)
Ok, just followed your new install options, but it errors on pgp value, don't know if this is relevant.....
hurricanehrndz
Please post error
Full error. And full commands
Edited by hurricanehernandez
ToBeFrank
deleted
Edited by ToBeFrank
hurricanehrndz
@@ToBeFrank
Just tried, the instructions worked for me on a clean install.
Please post error
Retried the instructions again this morning, and no errors,  :P thank you.
However, I am getting emby-server: unrecognised service when executing sudo service emby-server start.
EDIT: Scratch that found this sudo apt-get install --reinstall emby-server searching the forums and it now works.  :)
Edited by geaves
franky384
Unable to install on Ubuntu14.04 armhf and also on Debian 7 and 8 armhf.
The repos seem to be messed up. A lot of unfixable errors
The following packages have unmet dependencies:
mono-devel : Depends: libmono-2.0-dev (>= 4.0.1.43-0) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-tasklets4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-i18n4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-custommarshalers4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
emby-server : Depends: libmagickwand-6.q8-2 which is a virtual package.
libmono-debugger-soft4.0a-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-corlib4.5-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-i18n-cjk4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
mono-runtime-common : Depends: mono-gac (= 3.2.8+dfsg-4ubuntu1.1) but 4.0.1.43-0 is to be installed.
libmono-system4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-system-configuration4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
libmono-system-web4.0-cil : Depends: mono-runtime (>= 4.0.1.43) but 3.2.8+dfsg-4ubuntu1.1 is to be installed.
open: 308; closed: 187; defer: 284; conflict: 745 The following packages have unmet dependencies:
the same when trying to install in debian 7 or 8 armhf
any suggestions ?
Edited by franky384
hurricanehrndz
We don't build for any arm device. I haven't taken a look at what it takes to do so.
hurricanehrndz
any suggestions ?
@@franky384 I have enabled arm builds for repository 14.04 please try and again report back. I have not tested and have no means of testing.
By the way it's building right now so please check here:https://build.opensuse.org/project/monitor/home:emby
  • Like 1
Hello,
I updated to the latest build this morning.
Running Ubuntu 14.04 64-bit
I received a few 404 errors when I typed in:
sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/emby-server.list"sudo apt-get update
Then i did this per the Ubuntu instructions:
ian@ubuntu-basement:~$ sudo apt-get install emby-server
Output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
emby-server : Depends: mono-devel (>= 1.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
So I think the 1st two sudo lines above didn't grab the mono-devel packages properly.
So I installed the mono-devel package directly via:
sudo apt-get install mono-devel
then I proceeded to:
This worked properly and I received a prompt to enter in the user name, etc. No failure notes in the terminal text after running it.
and then:
A note: starting up the server took a few minutes. Longer than last time IIRC.
Edited by osborni
franky384
You're the man, :lol:
installs without problems and is WORKING !!
But i had to compile ffmpeg for armhf from sources cause it's not in the 14.04 ubuntu repos. It's back in 15.04, perhaps you can enable 15.04 in your repo??
I copied ffmpeg and ffprobe to /usr/bin,
after that the install worked without any error , i followed the instructions on the download page.
Great work !!!
maybe someone is interested in ffmpeg for armhf, here's the link to my dropbox:
https://www.dropbox....ild.tar.gz?dl=0
I run the emby-server on an Android TV-Box CS918 in a Ubuntu 14.04 chroot environment.
Now i will try it on my Raspberry Pi 2 B) , or my Odroid U3. They are all armhf, should be no problem to install emby-server on them.
hurricanehrndz
Hello,
Output:
and then:
It was probably adjusting permissions. The 404 errors could be because you have the old ppas. You missed a line.
sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2
perhaps that's why mono was not updated.
Oh there is also a delay in the start up, because the script ensures that the process stays up for 15 seconds. If it doesn't it refers you to the emby logs.
hurricanehrndz
Great work !!!
I wish that enabling 15.04 would be a possibility, but the open build service haven't imported any packages for 15.04 for arm, so I would need to build each and every package imaginable. It might be easier if I build ffmpeg. Ps you could always use 15.04 and point to xUbuntu_14.04 repo there should be no issues.
Good to know about the delay.
I tried that (95% sure I did that line - I'll check the terminal history. At work now and the box is at home) and it still choked. I followed the instructions verbatim the first two times through.
Though I'd suggest making the "{Repository}" note big fat and bold in the instruction set. I missed the 2nd one the first time I tried to update it. The 2nd time I walked through the install, I ran into the problem with the ppas. The 3rd time I installed mono-devel.
Doing the full mono install worked though, so I'm happy.
Though I have to say that Emby needs to figure out a way to have it install with just: sudo apt-get emby-server and be done with the multi-line repository stuff. I realize there is the assumption that most linux users have some sort of a clue, but some of us use linux because it is free and aren't much better than script kiddies. (like me. Ha!)
Edited by osborni
hurricanehrndz
Adding a repository to your os is part of every distros unless you get included in the default repos. I don't think that will happen. We have made the instructions and the installation procedure as simple as it could be and a lot less complex than when I first started when you had to compile mono and emby yourself. Thanks for your suggestions. mono-devel is not a full install, it includes some library files. The name is not really representative of what the package actually installs. I'm pretty sure that if you added the repo and did an apt-get update that apt-get install emby-server would work too. I like having the dependency line in the install instructions though so that the install is as flawless as possible. In terms of linux, I use to be script kiddy about 3 years ago, so don't worry the more and more you use linux the more addicting it becomes.
franky384
Ok, no problem , it works for me with my self compiled ffmpeg.
I'll try out the 15.04 repo together with your xUbuntu_14.04 on my raspberry.
Update:
I just installed Ubuntu 15.04 on my Raspberry Pi 2, installed ffmpeg, then followed the install instructions on the download page and everything installed fine without any error.
Very nice that the emby-server now also runs on armv7 devices.
Edited by franky384
Yes, the linux instructions are getting better!
During try #1, this is what the terminal log states when I tried to do the mono-runtime line item:
sudo apt-get install mono-runtime mediainfo libsqlite3-dev imagemagick-6.q8 libmagickwand-6.q8-2 libmagickcore-6.q8-2 Reading package lists... Done
libsqlite3-dev is already the newest version.
mediainfo is already the newest version.
imagemagick-6.q8 is already the newest version.
libmagickcore-6.q8-2 is already the newest version.
libmagickwand-6.q8-2 is already the newest version.
mono-runtime is already the newest version.
The following packages were automatically installed and are no longer required:
  libmono-cscompmgd8.0-cil libmono-data-tds2.0-cil
  libmono-entityframework-sqlserver6.0-cil libmono-entityframework6.0-cil
  libmono-i18n-west2.0-cil libmono-ldap2.0-cil libmono-management2.0-cil
  libmono-messaging-rabbitmq2.0-cil libmono-messaging2.0-cil
  libmono-microsoft-build2.0-cil libmono-microsoft8.0-cil
  libmono-npgsql2.0-cil libmono-npgsql4.0-cil libmono-opensystem-c4.0-cil
  libmono-oracle2.0-cil libmono-peapi2.0a-cil libmono-posix2.0-cil
  libmono-rabbitmq2.0-cil libmono-relaxng2.0-cil libmono-security2.0-cil
  libmono-sharpzip2.6-cil libmono-sharpzip2.84-cil libmono-simd2.0-cil
  libmono-sqlite2.0-cil libmono-system-data-services2.0-cil
  libmono-system-data2.0-cil libmono-system-json2.0-cil
  libmono-system-ldap2.0-cil libmono-system-messaging2.0-cil
  libmono-system-net2.0-cil libmono-web4.0-cil libmono-windowsbase3.0-cil
  libmono-xbuild-tasks2.0-cil mono-mcs mono-xbuild Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 212 not upgraded.
W: Duplicate sources.list entry http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/ trusty/main amd64 Packages (/var/lib/apt/lists/ppa.launchpad.net_apps-z_mediabrowser_ubuntu_dists_trusty_main_binary-amd64_Packages)
W: Duplicate sources.list entry http://ppa.launchpad.net/apps-z/mediabrowser/ubuntu/ trusty/main i386 Packages (/var/lib/apt/lists/ppa.launchpad.net_apps-z_mediabrowser_ubuntu_dists_trusty_main_binary-i386_Packages)
W: Duplicate sources.list entry http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/  Packages (/var/lib/apt/lists/download.opensuse.org_repositories_home:_emby_xUbuntu%5f14.04_Packages)
W: You may want to run apt-get update to correct these problems ian@ubuntu-basement:~$ sudo apt-get install emby-server Reading package lists... Done
Edited by osborni
hurricanehrndz
Okay, thanks. I think I know the issue.
