embylad892746 32 Posted June 30, 2024 Posted June 30, 2024 (edited) Server: 4.9.0.26 beta (official emby docker) Android TV App: 2.1.14g What is the problem? I keep my clients (ios, web, AndroidTV) set to sort by 'Date Added ↓'. The sort order shown is identical on my ios + web app, but the AndroidTV sorting appears slightly borked. The sort order is mostly correct, but several recently added titles are not at the top of the list like they should be. What i've tried rolling back to 4.9.0.25 beta --> fixes issue Reference to last time something similar happened: Edited June 30, 2024 by embylad892746
Luke 42244 Posted June 30, 2024 Posted June 30, 2024 Hi, try setting the sort order again and see how things are after that. Thanks.
embylad892746 32 Posted July 1, 2024 Author Posted July 1, 2024 (edited) I tried that before rolling back. Doesn’t work. Problem persists. Edited July 1, 2024 by embylad892746
embylad892746 32 Posted July 2, 2024 Author Posted July 2, 2024 10 hours ago, Luke said: What exactly did you do? What exactly happened? Logged into android tv after 4.9.0.26 beta update. The sort order was no longer sorted by 'Date Added' but my alphabetical order, which i knew was a bad sign since that is what also happened with the 4.9.0.23 beta update several weeks prior... i switched the order back to Data Added again, and quit the app and opened again to confirm the sort order was sticking, which it was, so i thought problem was solved. But then i noticed the sort order with 'Date Added' was not working correctly because several newly added items were not showing. Toggling Date Added filter option did not fix the issue. Gave up and rolled back to 4.9.0.25 which resolved the issue.
ebr 16337 Posted July 2, 2024 Posted July 2, 2024 7 hours ago, embylad892746 said: was not working correctly because several newly added items were not showing. Hi. That sounds like something very different. Are you sure you didn't have any filters engaged in the view? Exactly what items weren't showing?
embylad892746 32 Posted July 3, 2024 Author Posted July 3, 2024 On 7/2/2024 at 5:27 PM, ebr said: Hi. That sounds like something very different. Are you sure you didn't have any filters engaged in the view? Exactly what items weren't showing? Hi, yes I’m sure. I was able to compare same Android tv filter settings against the iOS and web app to confirm. Sorry I don’t have the exact items written down and I’m not willing to take time updating again just to check this. It doesn’t bother me too much especially since I reverted the update. Just wanted to give you guys a heads up.
ebr 16337 Posted July 4, 2024 Posted July 4, 2024 8 hours ago, embylad892746 said: It doesn’t bother me too much especially since I reverted the update. Just wanted to give you guys a heads up. Without your, or someone else's help, we may never discover the real issue and you may end up dealing with it again in stable so we would appreciate some more investigation. What you've described so far doesn't sound like a sort issue.
