Onkeldickmann 1 Posted June 27, 2024 Posted June 27, 2024 hello I have a Dune-HD pro one 8k Android Meida Player and installed Kodi 21. I have defined the Dune internal player to play the videos using the playercorefactory.xml file (better picture for DV and HDR UHD) all videos are played cleanly . If I now install Emby for Kodi and then click on a film, the Dune Player starts but nothing happens. Does anyone have an idea why this doesn't work. I have to define something here again that Emby recognizes for Kodie, to use the internal Dune player and not the Kodi player
quickmic 1709 Posted June 27, 2024 Posted June 27, 2024 3 hours ago, Onkeldickmann said: hello I have a Dune-HD pro one 8k Android Meida Player and installed Kodi 21. I have defined the Dune internal player to play the videos using the playercorefactory.xml file (better picture for DV and HDR UHD) all videos are played cleanly . If I now install Emby for Kodi and then click on a film, the Dune Player starts but nothing happens. Does anyone have an idea why this doesn't work. I have to define something here again that Emby recognizes for Kodie, to use the internal Dune player and not the Kodi player Probably disable path substitution in plugin's config menu. If still doesn't work, you need to send a kodi.log for review. 1
Onkeldickmann 1 Posted June 27, 2024 Author Posted June 27, 2024 that was exactly the cause - thank you very much 1
