Danielhartman 0 Posted June 26, 2024 Posted June 26, 2024 I'm having two separate issues which have only just begun occurring. First, when I try to update any metadata nothing is editable. even after unlocking, it's as though the screen freezes up but everything else works fine. The second is when I add a new move and try to access it via an AppleTV, the formatting is extra large and I can't hit the play button. I can only see the cast list. Has anyone else encountered this? Is there a solution? I could not locate a topic on similar issues.
Happy2Play 9811 Posted June 26, 2024 Posted June 26, 2024 Can you go over a specific example and possibly screen shots of the metadata issue along with what client and the server log. As for the Display issue will probably need screen shots of specific examples.
Danielhartman 0 Posted June 26, 2024 Author Posted June 26, 2024 (edited) Thank for the quick reply. Here are screenshots along with additional details 1. MetaData editing issue. I've been an Emby Premiere member for years and have never had an issue with updating MetaData before. This occurs with every movie and is not specific to the one movie I am trying to update. With that said I am attempting to update the source title of a Harry Potter film to get them to appear in order. In the screenshots below you can see the MetaData tab open. I cannot click on anything in the box except the green save bar at the bottom. Any time I click anywhere in the box it only changes the little lock in the middle of the screen. You can see it solid in one screenshot and unfilled in the other. Ive tried tabbing to the fields but it only cycles through my movie library in the background. 2. Apple TV formatting Issue: This has occurred with the two most recent additions to my library. Like before I have never had this is before. When I select the film from my library it initially pulls up as the first screenshot where the formatting is large and has no accessible play button, although that wouldn't matter because within seconds it slides down to the second screenshot and does not allow me to attempt to scroll up. Any assistance would be greatly appreciated. Thank You. Edited June 26, 2024 by Danielhartman
Happy2Play 9811 Posted June 26, 2024 Posted June 26, 2024 Are you trying to Edit Metadata on AppleTV also? But can say I have never seen a lock in the middle of the screen either but don't have this client.
Danielhartman 0 Posted June 26, 2024 Author Posted June 26, 2024 Ive also never seen a lock there before either. I'm only trying to edit the MetaData is from an iMac. I didn't do any updates to Emby either that would have caused a change. It just appeared one day and from that point on I've been unable to update.
Happy2Play 9811 Posted June 26, 2024 Posted June 26, 2024 Okay will have to wait for dev or fellow Mac/AppleTV users to comment.
Luke 42237 Posted June 26, 2024 Posted June 26, 2024 HI, is this the Emby web app that you're trying to edit metadata from?
