SamES 1069 Posted April 28, 2024 Posted April 28, 2024 (edited) Looks like there might be a template issue when being notified of moved posts: *I add this line for testing* Edited June 24, 2024 by Abobader add line
Abobader 3478 Posted June 24, 2024 Posted June 24, 2024 Hi @SamES Do the notification look better for split?
Abobader 3478 Posted June 24, 2024 Posted June 24, 2024 First post here, it was split from: You did not get any notify about that?
SamES 1069 Posted June 24, 2024 Author Posted June 24, 2024 (edited) 7 hours ago, Abobader said: First post here, it was split from: You did not get any notify about that? Wow, that took some time. Look at when I got your first email yesterday where you @ mentioned me. Then, your response after my response. Then the next two! To answer your question - yes, they look good now, thanks! Edited June 24, 2024 by SamES 1
Happy2Play 9797 Posted June 27, 2024 Posted June 27, 2024 @Abobadershould I get double emails? Not sure why I got emails instead of Notification per the setting. As I got email not notification. 1
Abobader 3478 Posted June 28, 2024 Posted June 28, 2024 Hi @Happy2Play I disable email for now, thanks for reporting. Also notice the split still had reporting issue. 1
Abobader 3478 Posted June 28, 2024 Posted June 28, 2024 hmm, @Happy2Play that not double same issue, 2 emails for 2 notify action. But as I said, I disable email temp for now, and will let members chose what option they want.
Happy2Play 9797 Posted June 28, 2024 Posted June 28, 2024 3 minutes ago, Abobader said: hmm, @Happy2Play that not double same issue, 2 emails for 2 notify action. But as I said, I disable email temp for now, and will let members chose what option they want. I guessed they were for the same action but you know what was merged but have no idea what was split.
Abobader 3478 Posted June 28, 2024 Posted June 28, 2024 3 minutes ago, Happy2Play said: I guessed they were for the same action but you know what was merged but have no idea what was split. Yes they are 2 actions, split and merged even from the same, but the notify see it as 2 actions. I notice the split error info (% things) and why it happens, but did not have time to look more in this, but tomorrow I will. 1
Abobader 3478 Posted June 28, 2024 Posted June 28, 2024 ah, heh, it only happends with one person whom do the action (I will not till who tho) But still need to be resolved.
Happy2Play 9797 Posted June 28, 2024 Posted June 28, 2024 1 minute ago, Abobader said: ah, heh, it only happends with one person whom do the action (I will not till who tho) But still need to be resolved. LOL dang ADMIN_Group. 1
