TechnoMonster 2 Posted June 22, 2024 Posted June 22, 2024 I am new to Bulky and have never "dropped" DLL files into my Synology NAS hidden folders. The Bulky installation info says: copy and paste dll to the plugins folder. I have no idea how to drop the DLL file into the /programdata/Plugins folder! Thanks for your help. --------------------------------- INSTALLATION - NOTE: Default Target for installation is Emby-Server/programdata/Plugins - Please download the "dll" file below copy and paste dll to the plugins folder. restart your emby server as this is in Development you will need to clear your browser Cache after each install, or the new changes will not appear Enjoy
Happy2Play 9814 Posted June 22, 2024 Posted June 22, 2024 You will need to SSH into your NAS And place the dll in to your programdata location shown in log or dashboard server info. You will also have to verify permissions once you place the dll in the folder.
TechnoMonster 2 Posted June 24, 2024 Author Posted June 24, 2024 That a great start. I've enabled SSH on my NAS, and installed WinSCP. I can navigate to the folder: but when I try to paste the Emby.Bulky.dll file there I get:
TechnoMonster 2 Posted June 25, 2024 Author Posted June 25, 2024 Any suggestions on how to fix "Permission denied" when trying to copy the DLL file to my NAS? Thank you.
pünktchen 1411 Posted June 25, 2024 Posted June 25, 2024 The plugin is also in Emby's plugin catalog under the Metadata section, so there's no need to manually copy the dll.
TechnoMonster 2 Posted June 25, 2024 Author Posted June 25, 2024 Awesome! Much simpler. Thank you all!
Happy2Play 9814 Posted June 25, 2024 Posted June 25, 2024 (edited) @VicMoore@Cheesegeezer Can you update the first post in Bulky topic and remove dll/zip/install instructions and mention plugin is in catalog. Edited June 25, 2024 by Happy2Play corrected tag
VicMoore 755 Posted June 25, 2024 Posted June 25, 2024 Yes, I will do that. I sort of drop everything to work on PseudoTV. By the way, I have a new GUI that you might like to look at. I will fix this issue tomorrow. It's nice to hear from you Vic 1
