DitchDoc84 0 Posted June 20, 2024 Posted June 20, 2024 I have input my .m3u and channels work flawlessly. I do not have a guide file provided with that .m3u. I have attempted to input a local guide from the emby native guides. I input a local cable provider and zipcode with the plan to manually set the channels I have to match the guide channels. unfortunately the running task refresh guide continues to stall and I never get the guide channels to display. is there a fix?
Abobader 3484 Posted June 20, 2024 Posted June 20, 2024 Hello DitchDoc84, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42184 Posted June 20, 2024 Posted June 20, 2024 HI there, it's most likely just taking a long time. I would just be patient and allow it to finish. If you can attach an emby server log, we might be able to offer some advice on how to speed it up: How to Report a Problem Thanks.
