icegood 12 Posted August 11, 2024 Author Posted August 11, 2024 Hello. Just checked 4.9.0.29. No errors anymore! Great job! Thank you! readelf -A lib/libavcodec.so Attribute Section: aeabi File Attributes Tag_CPU_name: "7-A" Tag_CPU_arch: v7 Tag_CPU_arch_profile: Application Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-2 Tag_FP_arch: VFPv3-D16 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_rounding: Needed Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_enum_size: int Tag_CPU_unaligned_access: v6 everything is fine as expected! Meanwhile, FYI, the community's one ffmpeg is suffering with even more issues. Do you happen to configure -mthumb in your toolchain? I would really want it to have but something from syno toolchain prevents me to do so....
Luke 42241 Posted August 12, 2024 Posted August 12, 2024 Hi, why would you want to use the community ffmpeg instead?
icegood 12 Posted August 12, 2024 Author Posted August 12, 2024 (edited) No, i don't want. I know, that API is inconsistent. It was just FYI. I consider case of reformating videos manually to be maximally compatible with Emby Edited August 12, 2024 by icegood
Luke 42241 Posted August 12, 2024 Posted August 12, 2024 10 hours ago, icegood said: No, i don't want. I know, that API is inconsistent. It was just FYI. I consider case of reformating videos manually to be maximally compatible with Emby Have you tried Emby Server's "Convert Media" feature? Convert Media
Luke 42241 Posted November 8, 2024 Posted November 8, 2024 @icegoodcan you please try this again with 4.9.0.31? Thanks !
icegood 12 Posted November 8, 2024 Author Posted November 8, 2024 Checked on 31st. Everything is fine. 1
