Happy2Play 9811 Posted June 21, 2024 Posted June 21, 2024 So looks like your options currently areĀ 1. remove subs 2. reorder current subs 3. extract the subs you will always use as external subs Since this is a limitation of Samsung player. 1
fiolet 5 Posted June 28, 2024 Author Posted June 28, 2024 On 6/21/2024 at 9:50 AM, Happy2Play said: So looks like your options currently areĀ 1. remove subs 2. reorder current subs 3. extract the subs you will always use as external subs Since this is a limitation of Samsung player. I checked best options and I can say: 1. Removing subs using SUBKILLER is very convenient, after easy setup it works fast and automaticly, so you can forget about it. Recommend. 2. Too time consuming. 3. Usually when mkv contain subs, they are also available on dedicated websites, so using special software or plugin you can do it also automaticly. I will stay with solution 1. Thanks all for help and lets wait until Samsung will fix it. 1
Spaceboy 2573 Posted June 28, 2024 Posted June 28, 2024 you can always use tdarr to automatically monitor and remove excess subs (not sure if subkiller has the same folder watch and automation). its a little complicated to configure but i havent touched it in the 2+ years since i did and it just churns away in the background 1
fiolet 5 Posted June 28, 2024 Author Posted June 28, 2024 11 minutes ago, Spaceboy said: you can always use tdarr to automatically monitor and remove excess subs (not sure if subkiller has the same folder watch and automation). its a little complicated to configure but i havent touched it in the 2+ years since i did and it just churns away in the background Subkiller works autimaticly, so you choose media folder, in settings choose what to do. Changes in that folder are discovered automaticly and task manager start up processing. So similar like you said, probably i won't touch it for next two years:) 1
