speechles 2062 Posted June 29, 2024 Posted June 29, 2024 (edited) The "line" setting means the dynamic range is left alone. There will be very quiet scenes and very loud scenes. You might have to adjust volume to hear the quiet scene then be blown out of the room by the loud scenes. The "RF" setting compresses the dynamic range. So the very quiet scenes and very loud scenes are normalized. You won't have to adjust the volume knob or be blow out of the room. But it might not sound the same as the theater. Slightly duller. Edited June 29, 2024 by speechles 1
Rolivaras 2 Posted July 3, 2024 Author Posted July 3, 2024 On 6/29/2024 at 12:30 PM, Luke said: Can they try resetting to default? My client has reset to factory defaults. But it didn't solve it.
Luke 42242 Posted August 7, 2024 Posted August 7, 2024 @Rolivarascan you try again with Emby for Android 3.4.16+? Thanks !
