Rolivaras 2 Posted June 16, 2024 Posted June 16, 2024 Hi, I'm having trouble playing audio in some movies, no audio actually comes out. In films like Shazam and Godzilla vs. Kong on June 11, for example, the audio didn't work. Spoiler The model is a TVBox T95Max. OS: Android 9.0 CPU: S905X3 Quad Core 64Bit Cortex-A55 GPU: ARM G31 MP2 RAM: 4GB DDR3 ROM: 32GB EMMC Card reader: support TF card Wi-Fi: 2.4G + 5G dual-band Wi-Fi Ethernet: Standard 10/100M RJ-45 UHD video output: Support 8K Mouse/Keyboard: Supports mouse and keyboard via USB; Supports 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle OSD Language Type: English, French, German, Spanish, Italian, etc. Multilateral languages 1080P/AV/3G: Support HDD File System: FAT16/FAT32/NTFS Audio formats: MP3, WMA, AAC, OGG, DDP, HD, FLAC, APE Specifications: Model: T95 max Plus BT version: 4.0 Input port: USB 3.0, USB 2.0, TF card slot, RJ45, power input Output port: HD, AV Power supply: DC 5V/2A On the other devices, everything has worked satisfactorily. embyserver.txt embyserver-63853925473.txt hardware_detection-63853925547.txt hardware_detection-63853980298.txt hardware_detection-63853985258.txt
Luke 42242 Posted June 16, 2024 Posted June 16, 2024 What device are you playing on? What is your audio setup?
Rolivaras 2 Posted June 17, 2024 Author Posted June 17, 2024 It's an old LG LCD TV, I don't use any audio devices on it.
Rolivaras 2 Posted June 17, 2024 Author Posted June 17, 2024 I'm using a TVBox with Android, I use Emby for Android version 3.3.95. The TVBox is connected to the TV via HDMI.
Rolivaras 2 Posted June 17, 2024 Author Posted June 17, 2024 On 6/16/2024 at 2:47 PM, Rolivaras said: The model is a TVBox T95Max. OS: Android 9.0 CPU: S905X3 Quad Core 64Bit Cortex-A55 GPU: ARM G31 MP2 RAM: 4GB DDR3 ROM: 32GB EMMC Card reader: support TF card Wi-Fi: 2.4G + 5G dual-band Wi-Fi Ethernet: Standard 10/100M RJ-45 UHD video output: Support 8K Mouse/Keyboard: Supports mouse and keyboard via USB; Supports 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle OSD Language Type: English, French, German, Spanish, Italian, etc. Multilateral languages 1080P/AV/3G: Support HDD File System: FAT16/FAT32/NTFS Audio formats: MP3, WMA, AAC, OGG, DDP, HD, FLAC, APE Specifications: Model: T95 max Plus BT version: 4.0 Input port: USB 3.0, USB 2.0, TF card slot, RJ45, power input Output port: HD, AV Power supply: DC 5V/2A This
Rolivaras 2 Posted June 18, 2024 Author Posted June 18, 2024 I'm sorry. I don't understand what you are referring to.
Rolivaras 2 Posted June 18, 2024 Author Posted June 18, 2024 I don't think it has a manufacturer. They are generic products from China. But they use hardware similar to the Xiaomi TV Box.
ebr 16335 Posted June 19, 2024 Posted June 19, 2024 Hi. One of the problems with these generic boxes is that they don't always have complete or correct implementations of the internals (codecs for one). Can you get a log from the app after reproducing the issue?
Rolivaras 2 Posted June 19, 2024 Author Posted June 19, 2024 I imagine it's some implementation problem. How do I get the app log? Could it be the TVBox app?
Lessaj 484 Posted June 19, 2024 Posted June 19, 2024 Within emby for android profile icon in the top right -> App Settings -> Logs -> Settings -> "Enable app logging" and restart the app. You should see a log appear in the Logs tab after an app restart.
Rolivaras 2 Posted June 20, 2024 Author Posted June 20, 2024 Here On 6/19/2024 at 11:47 AM, Lessaj said: Within emby for android profile icon in the top right -> App Settings -> Logs -> Settings -> "Enable app logging" and restart the app. You should see a log appear in the Logs tab after an app restart. bluetooth_content_share.html
Luke 42242 Posted June 20, 2024 Posted June 20, 2024 10 minutes ago, Rolivaras said: Here bluetooth_content_share.html 106.61 kB · 0 downloads Hi, can you please provide the original plain text version? Thanks.
Rolivaras 2 Posted June 21, 2024 Author Posted June 21, 2024 Unfortunately, I don't have the device, so my client was only able to send the file this way.
Luke 42242 Posted June 24, 2024 Posted June 24, 2024 How have they configured audio settings for the device?
Rolivaras 2 Posted June 25, 2024 Author Posted June 25, 2024 In the app and on the TVbox, use the default settings.
Rolivaras 2 Posted June 26, 2024 Author Posted June 26, 2024 This is the configuration of TVBox. The app Emby for Android is by default.
ebr 16335 Posted June 26, 2024 Posted June 26, 2024 I'm not sure I can interpret exactly what those even mean but I would try changing them to different values to see what difference it may make.
Rolivaras 2 Posted June 27, 2024 Author Posted June 27, 2024 I purchased a TVBox exactly the same as the one with sound problems. And with the same default settings. The one I purchased is working normally. My client made the changes to the TVBox settings to different values, but the audio still didn't work.
