Painkiller88 250 Posted September 29, 2024 Posted September 29, 2024 12 hours ago, codechurn said: Just pulled down the latest posted version of this and I am getting the following error: 2024-09-28 13:35:59.058 Error App: Error downloading trailer for Ghost in the Shell *** Error Report *** Version: 4.8.9.0 Command line: C:\Users\wmc\AppData\Roaming\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows 10.0.20348 Framework: .NET 6.0.33 OS/Process: x64/x64 Runtime: C:/Users/wmc/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 48 Data path: C:\Users\wmc\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\wmc\AppData\Roaming\Emby-Server\system VideoLibrary.Exceptions.UnavailableStreamException: VideoLibrary.Exceptions.UnavailableStreamException: Error caused by Youtube.(This video is not available)) at VideoLibrary.YouTube.ParseVideos(String source, String jsPlayer, JToken playerResponseJson)+MoveNext() at System.Linq.Enumerable.SelectEnumerableIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.GetEnumerator()+MoveNext() at System.Linq.Enumerable.TryGetFirst[TSource](IEnumerable`1 source, Func`2 predicate, Boolean& found) at System.Linq.Enumerable.First[TSource](IEnumerable`1 source, Func`2 predicate) at YTrailers.Search.YouTubeSearch.Search(BaseItem item, CancellationToken cancellationToken) Source: test TargetSite: Boolean MoveNext() Yes the Plugin is again no longer working. YT changed something "again" so we need to wait for a new fix.
radeon 757 Posted October 18, 2024 Posted October 18, 2024 New version uploaded to https://ballingtons.com/products 1
Painkiller88 250 Posted October 20, 2024 Posted October 20, 2024 I confirm that the new version fixes the problem. thanks
FlowCode 1 Posted October 20, 2024 Posted October 20, 2024 Unfortunately, it's still not working with me. Thats a shame, I was really excited. Could you please support to see where have i got wrong? I reinstalled the plugin with the new updated one but still not working embyserver (1).txt
radeon 757 Posted October 20, 2024 Posted October 20, 2024 It's working fine by the looks of your logs. I've just looked at a chunk of your failing downloads and the failing ones are those that have been removed from YouTube so the stream is unavailable. The plugin uses themoviedb for its source of available trailers.
Painkiller88 250 Posted October 21, 2024 Posted October 21, 2024 (edited) 11 hours ago, FlowCode said: Unfortunately, it's still not working with me. Thats a shame, I was really excited. Could you please support to see where have i got wrong? I reinstalled the plugin with the new updated one but still not working embyserver (1).txt 476.82 kB · 2 downloads There is one thing you can do. like @radeon said the plugin uses themoviedb to identify the movie and use those trailers. BUT: if you save you movie informations in NFO files, and you search for a trailer of the movie, and replace the link of the youtoube video in your NFO file, scan the library again and start the trailer download task. It will respect the infos in the NFO, this is what i had to do for a lot movies to get the german trailer because TMDB has the infos in german but uses english trailers very often. So if the trailer recommended by TMDB is not available, replace it with one you find on youtube. So maybe this helps you. Edited October 21, 2024 by Painkiller8818
