EmYaj 25 Posted June 16, 2024 Posted June 16, 2024 I have livetv on the server set to keep 1 hour of history. Using latest (stable) server on Ubuntu (docker) and latest version of emby app on firestick 4k. I have multiple devices and I can't seem to rewind livetv even after watching for an hour. I can pause and resume but cannot rewind. How does this work?
Luke 42241 Posted June 16, 2024 Posted June 16, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
EmYaj 25 Posted June 16, 2024 Author Posted June 16, 2024 10 hours ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! OK well logging on Firestick app doesnt seem to work at all. I enabled it, restarted the app (and also the firestick) and when I go back in the app the option is turned on so I know it saved. But nothing I do seems to create a log file so I cant send one from the app. The emby server log is attached, not sure if this will help or not. Rewinding works fine in browser, but firesticks (multiple of them) don't seem to be able to rewind live tv. All of the testing was done within 10 minutes of downloading the log from the server. I recorded a video showing the issue with both the log and with the rewinding but I'm not comfortable posting it in public since as it shows some identifying info - if I can email it or DM it that would be fine. embyserver(27).txt
ebr 16334 Posted June 18, 2024 Posted June 18, 2024 Hi. Are you using "Emby for Fire TV" or just "Emby" on the Fire stick?
EmYaj 25 Posted June 18, 2024 Author Posted June 18, 2024 6 minutes ago, ebr said: Hi. Are you using "Emby for Fire TV" or just "Emby" on the Fire stick? Just Emby
Luke 42241 Posted June 18, 2024 Posted June 18, 2024 On 6/16/2024 at 10:35 AM, EmYaj said: OK well logging on Firestick app doesnt seem to work at all. I enabled it, restarted the app (and also the firestick) and when I go back in the app the option is turned on so I know it saved. But nothing I do seems to create a log file so I cant send one from the app. The emby server log is attached, not sure if this will help or not. Rewinding works fine in browser, but firesticks (multiple of them) don't seem to be able to rewind live tv. All of the testing was done within 10 minutes of downloading the log from the server. I recorded a video showing the issue with both the log and with the rewinding but I'm not comfortable posting it in public since as it shows some identifying info - if I can email it or DM it that would be fine. embyserver(27).txt 28.17 MB · 0 downloads Hi try force closing the app after turning on logging.
EmYaj 25 Posted July 25, 2024 Author Posted July 25, 2024 3 hours ago, Luke said: @EmYaj? Have not been able to get logging to work on my firestick so I gave up on this one
