Scott750 29 Posted November 10, 2014 Posted November 10, 2014 (edited) I updated from beta v3.0.5416.0 to official release v3.0.5424.1 and now the Web client won't open up on my HTPC in Chrome using the external Web address. No issues before the update. I can open the Web client on my server using the local host address and MBC in WMC opens and plays movies fine. Server Update log; https://www.dropbox.com/s/acdb3u4spgh3t22/server-update.log?dl=0 Server log: https://www.dropbox.com/s/m4jesnon1exibya/server-63551177434.txt?dl=0 Edited November 10, 2014 by Scott750
ebr 16357 Posted November 11, 2014 Posted November 11, 2014 As I said in the other thread it looks to me like there is a global network problem on the server machine. It is unable to resolve DNS which tells me maybe it can't talk on the outside network at all.
Scott750 29 Posted November 11, 2014 Author Posted November 11, 2014 Any suggestions for me to look at? Settings, etc? I haven't touched the router or computer network settings before or after the update.
ebr 16357 Posted November 11, 2014 Posted November 11, 2014 I'm not sure. Can you reach websites from a browser on that machine? Can you ping us (mediabrowser.tv)? Check your firewall and be sure it isn't blocking the server application. Maybe the update threw it for a loop and the rules need to be re-setup.
Solution Scott750 29 Posted November 12, 2014 Author Solution Posted November 12, 2014 (edited) I figured it out. I found in my Router Port forwarding settings that the IP address for my server was wrong. It had 192.168.1.4 but the servers address is 192.168.1.2. Not sure why the server address would changed after the update? Weird! As soon I corrected that, I can now log into the web client using the external IP address again. Thanks EBR for your suggestions! Edited November 12, 2014 by Scott750
Aeolius 6 Posted November 12, 2014 Posted November 12, 2014 Sometimes your router's dhcp server gets a new request from a computer or it decides to change the ip address of the machines connected to it, your router most likely has a section where you can statically set certain devices connected to it so that you don't have this issue o.O You might check it out.
Ironman273 2 Posted November 13, 2014 Posted November 13, 2014 Ok, I'm having a similar problem. After an update I am unable to connect to my server from outside my house when I didn't have that problem before. Both my external and internal IP have remained the same and I've never had to do port forwarding on my router. It just worked. What settings do I need to check?
Ironman273 2 Posted November 14, 2014 Posted November 14, 2014 Well, never mind. A reboot fixed it (still with all the same IPs).
Ironman273 2 Posted November 16, 2014 Posted November 16, 2014 Ugh. Still on the same session as before and now can't access the external IP anymore. I'm going to reboot again to see if it fixes it but could anyone tell me what could be causing it to drop off?
shaefurr 1340 Posted November 17, 2014 Posted November 17, 2014 Are you using MB connect or just the external IP address? Has the address changed? Usually with DSL and such a modem reset or interruption to the ISP will give you a new external IP, which is why people use dynamic IP services like no-ip, or MB connect. http://www.whatsmyip.org/ Also, Did you ever set up the server with a static IP or assign it a set IP in the DHCP list? Helps to avoid these issues in the future in case of an IP change.
Ironman273 2 Posted November 19, 2014 Posted November 19, 2014 Are you using MB connect or just the external IP address? Has the address changed? Usually with DSL and such a modem reset or interruption to the ISP will give you a new external IP, which is why people use dynamic IP services like no-ip, or MB connect. http://www.whatsmyip.org/ Also, Did you ever set up the server with a static IP or assign it a set IP in the DHCP list? Helps to avoid these issues in the future in case of an IP change. I have DHCP internally and I don't pay for a static IP externally. My PC doesn't get turned off so it always retains the same IP without having to reserve it. As for the external IP, I would expect interruptions if the IP had changed, but it hasn't. I've had the same external IP for ages now. So far the reboot has managed to keep it working. 1
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 After being up for a week the connection has gone back down again. I can access it from inside the network with the internal IP but any access from the outside doesn't work. I also tried setting up Media Browser Connect and it finds the server information with its internal and external IPs but it errors out when trying to connect.
anks 36 Posted November 25, 2014 Posted November 25, 2014 DHCP has lease times and it makes sense to set a fixed reservation for your PC. If you haven't already, you could also set an inbound port mapping on the router for the port your using to the IP. Although MB uses UPNP, defining these things will help troubleshoot the problem.
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 DHCP has lease times and it makes sense to set a fixed reservation for your PC. If you haven't already, you could also set an inbound port mapping on the router for the port your using to the IP. Although MB uses UPNP, defining these things will help troubleshoot the problem. If the PC never reboots it should keep the same IP, though, no? I don't want to pay for static IP from my provider but I figured whenever I rebooted the router I'd check the IP and make all the necessary changes. Actually, Media Browser Connect would make those changes much easier. I haven't messed with the port mapping because I'm using my cable provider's router.
Beardyname 199 Posted November 25, 2014 Posted November 25, 2014 If the PC never reboots it should keep the same IP, though, no? I don't want to pay for static IP from my provider but I figured whenever I rebooted the router I'd check the IP and make all the necessary changes. Actually, Media Browser Connect would make those changes much easier. I haven't messed with the port mapping because I'm using my cable provider's router. I don't think so, while it "probably" will, setting the server on a static ip locally is really the best practice. If you don't want to you don't even have to fiddle around in the router, just change the ip adress on that specific machine. (port forwarding though needs to be done on the router, if upnp is not cutting it)
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 I don't think so, while it "probably" will, setting the server on a static ip locally is really the best practice. If you don't want to you don't even have to fiddle around in the router, just change the ip adress on that specific machine. (port forwarding though needs to be done on the router, if upnp is not cutting it) Oh, locally my IP is static. It's to the outside that it's not. That's why internally (from my Xbox One or if I have my tablet in the house) it works fine. If I'm out of the house is when I can't access it. Even then, I can access it for a while but then for some mysterious reason it will just stop working.
Beardyname 199 Posted November 25, 2014 Posted November 25, 2014 Oh, locally my IP is static. It's to the outside that it's not. That's why internally (from my Xbox One or if I have my tablet in the house) it works fine. If I'm out of the house is when I can't access it. Even then, I can access it for a while but then for some mysterious reason it will just stop working. Oh my bad, i thought we were talking locally ^^ Then my best guess would either be upnp not playing well with your router, or some other router specific thing. there are some great guides over at : http://portforward.com/english/routers/port_forwarding If you are unsure about this sort of thing and ant to fiddle around with the ports (for testing ofc)
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 Oh my bad, i thought we were talking locally ^^ Then my best guess would either be upnp not playing well with your router, or some other router specific thing. there are some great guides over at : http://portforward.com/english/routers/port_forwarding If you are unsure about this sort of thing and ant to fiddle around with the ports (for testing ofc) Thanks! I haven't messed with the modem/router since the cable company put their own but I'll see what I can do.
anks 36 Posted November 25, 2014 Posted November 25, 2014 I though it was local also since the OP mentioned IP changing on the 192.168.1.0 network. My bad, sorry. Are you not running dynamic DNS? Helps if your external IP does change. 1
Lee 212 Posted November 25, 2014 Posted November 25, 2014 Second dynamic dns no-ip offer a free service and an ip updater tool/program... 1
anks 36 Posted November 25, 2014 Posted November 25, 2014 Plus a lot of routers support no-ip and other services natively, so you may not need the updater tool. A name is of course much easier to remember than an IP address. http://www.noip.com/support/knowledgebase/what-devices-support-no-ips-dynamic-dns-update-service/
ebr 16357 Posted November 25, 2014 Posted November 25, 2014 With MB Connect - you don't need a dynamic DNS service .
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 With MB Connect - you don't need a dynamic DNS service . I was just thinking that! (I'm new to the dynamic DNS thing, was actually just reading up on it). The problem I have is that when I do MB Connect it comes up with the correct IPs (both internal and external show) but the connection never gets made. If I remote into my computer and check its external IP it's correct, but I can't access it from outside my network, until I reboot.
shaefurr 1340 Posted November 25, 2014 Posted November 25, 2014 (edited) reboot your PC or the modem/router? Edited November 25, 2014 by shaefurr
Ironman273 2 Posted November 25, 2014 Posted November 25, 2014 reboot your PC or the modem/router? Well, yeah. That's what fixes the problem. I'm just wondering why it fixes it for a week and then it stops working again. 1
