shocker 135 Posted June 13, 2024 Posted June 13, 2024 Hello, Can we import tags from HD Homerun? I'm using HD Homerun with Threadfin as a proxy, and I do have the group-title set, but it seems that HD Homerun tag is not imported/being set on Channels "Tags". For M3U is working fine. Thanks
Sammy 791 Posted June 13, 2024 Posted June 13, 2024 Is there an advantage to using Threadfin over just enabling the tuners directly in Emby?
shocker 135 Posted June 13, 2024 Author Posted June 13, 2024 1 minute ago, Sammy said: Is there an advantage to using Threadfin over just enabling the tuners directly in Emby? Yes, I have two HD Homerun tuners with two different DVBC TV providers. Most of the channels are the same and I would like to use the load-balancing feature for them, so I'm setting the same channel ID with Threadfin.
Sammy 791 Posted June 13, 2024 Posted June 13, 2024 Another feature that was being worked on in TVNext a few years ago yet to come to fruition..
shocker 135 Posted June 13, 2024 Author Posted June 13, 2024 Yes, but since it's taking ages to be released, I would like, in the meantime, to have the Tags to be able to group channels automatically, if that would be possible
