Eukshark 5 Posted June 12, 2024 Posted June 12, 2024 (edited) Just a heads up if you have any users connected to your Emby server and are using the connect - please check your user email addresses are still showing under each user as I have had few just randomly disappear. Edited June 12, 2024 by Eukshark
Luke 42184 Posted June 12, 2024 Posted June 12, 2024 Hi, one reason this could happen is if they deleted the server from their account on the server selection screen.
Eukshark 5 Posted June 12, 2024 Author Posted June 12, 2024 Hi Luke thanks for the information, I’m will check with them to see if they might have done this mistake. 1
