ggafewfa 0 Posted June 8, 2024 Author Posted June 8, 2024 "Emby is continuously using more memory, eventually consuming all 32GB of RAM." log error is 2024-06-08 19:14:51.607 Error Server: Error processing request *** Error Report *** Version: 4.8.7.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.15.0-107-generic (buildd@lcy02-amd64-012) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #117-Ubun Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'name') at Emby.Server.Implementations.Library.UserManager.GetUserByName(String name) at Emby.Server.Implementations.Session.SessionManager.AuthenticateNewSessionInternal(AuthenticationRequest request, Boolean enforcePassword, CancellationToken cancellationToken) at Emby.Api.UserService.Post(AuthenticateUserByName request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: MediaBrowser.Controller.Entities.User GetUserByName(System.String)
Q-Droid 1011 Posted June 8, 2024 Posted June 8, 2024 You're joking, right? In your 1 minute log there were 56 different IP addresses hitting your server. 3
Neminem 1623 Posted June 8, 2024 Posted June 8, 2024 I guess you need to upgrade your Memory, to accommodate you "There are quite a lot of users." 1
Luke 42243 Posted June 8, 2024 Posted June 8, 2024 Hi there, please attach the complete emby server log file. Thanks.
ggafewfa 0 Posted June 9, 2024 Author Posted June 9, 2024 10 hours ago, Luke said: Hi there, please attach the complete emby server log file. Thanks. embyserver-63853534977.txt
ggafewfa 0 Posted June 10, 2024 Author Posted June 10, 2024 "I have to keep restarting the Emby service to reduce memory usage, but soon the memory usage rises above 20GB again, so I continue to restart it."
Lessaj 484 Posted June 11, 2024 Posted June 11, 2024 200? And you wonder why it's using so much memory. You sound like a share seller. 1 1
Neminem 1623 Posted June 11, 2024 Posted June 11, 2024 200 ? thats a lot. Emby - The open media solution Your personal media on any device Bringing all of your home videos, music, and photos together into one place has never been easier. Your personal Emby Server automatically converts and streams your media on-the-fly to play on any device.
