Noctedam 0 Posted June 7, 2024 Posted June 7, 2024 Hello! First of all I love Emby. Was a Plex user before but changed sometime ago. My problem is that I am trying to connect to our home server (same router, but wifi) with our LG TV and the usualy screen shows up. MY SERVER | ADD NEW SERVER | EMBY CONNECT When I click on Emby Connect and add the pin on my phone the app on the TV starts thinking then just goes back to the home page. When I click on my previously manualy added server it says cannot connect. When I check my WAN settings and manualy add the server it works fine till my IP changes again. The wierd part is that Emby mobile app works like a charm even when I am out of the house and using mobile coverage. "Stream to" option DLNA shows my TV but doesnt work in other homes when I try to connect my phone to the TV this way. Thanks for your help in advance!
Luke 42234 Posted June 7, 2024 Posted June 7, 2024 Hi, why not connect with your lan address if you’re inside the network?
Noctedam 0 Posted June 7, 2024 Author Posted June 7, 2024 Right now I can't use LAN. Because my PC (aka server) is in the other side of the house. Also it doesnt seems to solve the problem when my father try to connect to it from the other side of the city.
