iiiJoe 62 Posted June 4, 2024 Posted June 4, 2024 Hello to all. I'm currently utilizing a windows server with two android clients, Nvidia Shield TV Pro (2019 version) and Vbox, as well as numerous IOS devices. Subtitles for live tv display fine on all devices. But for recorded programs subtitles display correctly on pc and IOS devices only; not on Shield or Vbox. The error message is: "unable to load subtitles". Android version 2.1.14. Would appreciate any advice. embyserver.txt
Luke 42184 Posted June 4, 2024 Posted June 4, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
ebr 16307 Posted June 4, 2024 Posted June 4, 2024 Hi. These are actually video embedded closed captions, correct?
iiiJoe 62 Posted June 5, 2024 Author Posted June 5, 2024 7 hours ago, ebr said: Hi. These are actually video embedded closed captions, correct? Correct
iiiJoe 62 Posted June 5, 2024 Author Posted June 5, 2024 8 hours ago, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. Def can. Does it need to be sideloaded?
ebr 16307 Posted June 5, 2024 Posted June 5, 2024 Please try the other app to see if it is different but I imagine it is the same as this:
