EmYaj 25 Posted June 5, 2024 Author Posted June 5, 2024 Very strange, we will see what devs say. Thanks again. Just as a reminder, this issue goes away if I delete the tuner source and re-add it from scratch (but all users lose their favourites so trying to avoid)
Luke 42241 Posted June 5, 2024 Posted June 5, 2024 48 minutes ago, EmYaj said: Apologies forgot to use debug. Here is the same thing with debugging on. I'm not sure exactly how to access the /config/ path - from this new log I tried mydomain.com:8096/config/metadata/livetv/2381624067599958fc69a88113a34ac8/metadata/poster.svg but got file not found error. embyserver-63853200109.txt 34.52 kB · 1 download Svg is not supported. Only pure image formats at this time.
Happy2Play 9811 Posted June 5, 2024 Posted June 5, 2024 (edited) 19 minutes ago, Luke said: Svg is not supported. Only pure image formats at this time. Hmm image applies fine but do see all these same encoing errors. Must be a platform variable on display issue. Or just a timing issue and will disappear later. Edited June 5, 2024 by Happy2Play
